| Launching a profile configuration opens a new window? [message #31931] |
Mon, 19 September 2005 18:20  |
Originally posted by: vgrishchenko.serena.com
Is there any way to make it open the profiling perspective in the active
workbench window instead of creating a new one? Couldn't find an option that
controls that.
Vladimir.
| Re: Launching a profile configuration opens a new window? [message #32070 is a reply to message #32035] |
Wed, 21 September 2005 00:09   |
No. I'm profiling a simple hello-world like Java application. If I launch
profiling from within Java perspective this opens a new workbench window
that contains only single profiling perspective. This new window belongs to
the original workbench process, not a new workbench process since it doesn't
exist, so I end up with 2 workbench windows that belong to the same process.
However, if profiling is launched from within the profiling perspective it
just starts right there, no new window is opened. Anyway, it is not a big
issue. What's more troubling is that I cannot get UML diagrams working, see
my other post. Thanks.
<Navid_Mehregani_nmehrega@ca.ibm.com> wrote in message
news:dgpnes$s7b$1@news.eclipse.org...
> Are you saying that a new workbench pops up when you profile? This is
> most likely because you're profiling a run-time workbench. i.e. The
> launch configuration you're profiling is for a run-time workbench. RAC
> simply starts up a new workbench when you click on the profile button. To
> avoid this, profile a Java launch configuration instead. If you want your
> current workbench to switch to the profiling and logging perspective when
> you profile, complete the following steps:
> Click on windows -> preferences -> Profiling and Logging -> under 'switch
> to associated perspective when profiling or importing logs', select
> 'always' -> click on OK
> Navid Mehregani
> IBM Canada
| Re: Launching a profile configuration opens a new window? [message #32422 is a reply to message #32105] |
Wed, 21 September 2005 11:50  |
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 00570FAE85257083_=
Content-Type: text/plain; charset="US-ASCII"
I was going to suggest that you use a clean build. This is the first time
I've heard about this problem. With all the interactions involved, it's
hard to tell what was actually causing it. I'm glad you got it working :)
Navid Mehregani
IBM Canada
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">I was going to suggest that you use
a clean build. This is the first time I've heard about this problem.
With all the interactions involved, it's hard to tell what was actually
causing it. I'm glad you got it working :)</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani<br>
IBM Canada</font>
--=_alternative 00570FAE85257083_=--
FUDForum. Page generated in 0.04022 seconds
