Home » Archived » XML Schema Definition (XSD) » Parsing a WSDL with embedded xsd
Parsing a WSDL with embedded xsd [message #31929] |
Tue, 21 October 2003 07:37  |
I have a WSDL file that contains embedded XSD. The approach that I've been
taking is to take the xsd part and parse it as a seperate blob using
Eclipse XSD. This approach works for simple cases, but with the WSDL
below, where the targetNamespace of the file has a prefix called typens,
there is a complication parsing the xsd since it cannot resolve the
typens: prefix for the complex types. In fact I also have a problem with
the wsdl:arrayType but I'm not sure if that can be overcome.
Is there a way that I can set the targetNamespace of the document such
that I can overcome this problem.
<wsdl:definitions xmlns:typens="http://soap.amazon.com"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns="http://schemas.xmlsoap.org/wsdl/"
targetNamespace="http://soap.amazon.com" name="AmazonSearch">
<wsdl:types>
<xsd:schema xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://soap.amazon.com">
<xsd:complexType name="ProductLineArray">
<xsd:complexContent>
<xsd:restriction base="soapenc:Array">
<xsd:attribute ref="soapenc:arrayType"
wsdl:arrayType="typens:ProductLine[]" />
</xsd:restriction>
</xsd:complexContent>
</xsd:complexType>
<xsd:complexType name="ProductLine">
<xsd:all>
<xsd:element name="Mode" type="xsd:string" minOccurs="0" />
<xsd:element name="ProductInfo" type="typens:ProductInfo" minOccurs="0"
</xsd:all>
Re: Parsing a WSDL with embedded xsd [message #31964 is a reply to message #31929] |
Tue, 21 October 2003 15:09   |
--------------5BE33EF585AFEC61B91DDA83
Content-Type: text/plain; charset=us-ascii
Hayden,
I've been thinking about providing a convenience resource implementation for
handling WSDL. Attached are XSDWSDLResourceFactoryImpl and
XSDWSDLResourceImpl. If you register this factory against the "wsdl"
extension, it will create a resource that has all the WSDL contained schemas
in the getContents list. I've only test this a little bit...
> <wsdl:types>
> </xsd:restriction>
> </xsd:complexType>
> <xsd:all>
> </xsd:all>
Content-Type: text/plain; charset=us-ascii;
name="XSDWSDLResourceFactoryImpl.java"
Content-Disposition: inline;
filename="XSDWSDLResourceFactoryImpl.java"
* <copyright>
* Copyright (c) 2002 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Common Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/cpl-v10.html
* Contributors:
* IBM - Initial API and implementation
* </copyright>
* %W%
* @version %I% %H%
package org.eclipse.xsd.util;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.impl.ResourceFactoryImpl;
* The <b>Resource Factory</b> implementation for as WSDL resource.
public class XSDWSDLResourceFactoryImpl extends ResourceFactoryImpl
* Creates an instance.
public XSDWSDLResourceFactoryImpl()
super();
* Creates an {@link XSDResourceImpl}.
* @param uri the URI of the new resource.
* @param extent the extent of the new resource.
* @return an XSDResourceImpl.
public Resource createResource(URI uri)
return new XSDWSDLResourceImpl(uri);
name="XSDWSDLResourceImpl.java"
filename="XSDWSDLResourceImpl.java"
* <copyright>
* Contributors:
* </copyright>
* %W%
* @version %I% %H%
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.ArrayList;
import java.util.Collection;
import java.util.HashMap;
import java.util.Iterator;
import java.util.List;
import java.util.Map;
import javax.xml.parsers.DocumentBuilder;
import javax.xml.parsers.DocumentBuilderFactory;
import javax.xml.parsers.ParserConfigurationException;
import org.apache.xml.serialize.OutputFormat;
import org.apache.xml.serialize.XMLSerializer;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.emf.common.notify.Notification;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceImpl;
import org.eclipse.xsd.*;
import org.eclipse.xsd.XSDDiagnostic;
import org.eclipse.xsd.XSDFactory;
import org.eclipse.xsd.XSDPackage;
import org.eclipse.xsd.XSDPlugin;
import org.eclipse.xsd.XSDSchema;
import org.eclipse.xsd.impl.XSDSchemaImpl;
import org.w3c.dom.Document;
import org.w3c.dom.Element;
import org.w3c.dom.Node;
import org.xml.sax.EntityResolver;
import org.xml.sax.ErrorHandler;
import org.xml.sax.InputSource;
import org.xml.sax.Locator;
import org.xml.sax.SAXException;
import org.xml.sax.SAXParseException;
import org.xml.sax.helpers.DefaultHandler;
* The <b>Resource</b> implementation for a WSDL resource.
public class XSDWSDLResourceImpl extends XSDResourceImpl
protected Document document;
public XSDWSDLResourceImpl()
super();
public XSDWSDLResourceImpl(URI uri)
super(uri);
protected void doSave(OutputStream os, Map options) throws IOException
if (document != null)
doSerialize(os, document, options == null ? null : (String)options.get(XSD_ENCODING));
* Loads a new {@link XSDResourceImpl} into the resource set.
* @param resourceSet the resource set to hold the new resource.
* @param inputStream the contents of the new resource.
* @param options any options to influence loading behavior.
* @return a new XSDResourceImpl.
protected void doLoad(InputStream inputStream, Map options) throws IOException
// This pattern avoids loading the IProgressMonitor class when there is no progress monitor.
// This is important for stand-alone execution to work correctly.
IProgressMonitor progressMonitor = null;
Object monitor = options == null ? null : options.get("XSD_PROGRESS_MONITOR");
if (monitor != null)
progressMonitor = (IProgressMonitor)monitor;
progressMonitor.setTaskName(XSDPlugin.INSTANCE.getString("_UI_ResourceLoad_progress "));
progressMonitor.subTask(getURI().toString());
XSDParser xsdParser = new XSDParser();
try
if (options != null && Boolean.TRUE.equals(options.get("XSD_TRACK_LOCATION")))
xsdParser.parse(inputStream);
document = xsdParser.getDocument();
else
document = getDocument(inputStream, xsdParser);
if (xsdParser.getEncoding() != null)
getDefaultSaveOptions().put(XSD_ENCODING, xsdParser.getEncoding());
if (document != null && document.getDocumentElement() != null)
ResourceSet globalResourceSet = XSDSchemaImpl.getGlobalResourceSet();
Object oldMonitor = globalResourceSet.getLoadOptions().get("XSD_PROGRESS_MONITOR ");
try
XSDSchemaImpl.getGlobalResourceSet().getLoadOptions().put("XSD_PROGRESS_MONITOR ", progressMonitor);
findSchemas(document.getDocumentElement());
finally
XSDSchemaImpl.getGlobalResourceSet().getLoadOptions().put("XSD_PROGRESS_MONITOR ", oldMonitor);
catch (Exception exception)
XSDPlugin.INSTANCE.log(exception);
for (Iterator i = getContents().iterator(); i.hasNext(); )
XSDSchema xsdSchema = (XSDSchema)i.next();
assignDiagnostics(xsdSchema, xsdParser.getDiagnostics());
for (Iterator diagnostics = xsdParser.getDiagnostics().iterator(); diagnostics.hasNext(); )
XSDDiagnostic xsdDiagnostic = (XSDDiagnostic)diagnostics.next();
switch (xsdDiagnostic.getSeverity().getValue())
case XSDDiagnosticSeverity.FATAL:
case XSDDiagnosticSeverity.ERROR:
getErrors().add(xsdDiagnostic);
break;
case XSDDiagnosticSeverity.WARNING:
case XSDDiagnosticSeverity.INFORMATION:
getWarnings().add(xsdDiagnostic);
break;
if (progressMonitor != null)
progressMonitor.worked(1);
protected void findSchemas(Element element)
if (XSDConstants.nodeType(element) == XSDConstants.SCHEMA_ELEMENT)
XSDSchema xsdSchema = XSDSchemaImpl.createSchema(element);
getContents().add(xsdSchema);
else
for (Node child = element.getFirstChild(); child != null; child = child.getNextSibling())
if (child instanceof Element)
findSchemas((Element)child);
public void attached(EObject eObject)
super.attached(eObject);
if (eObject instanceof XSDSchema)
((XSDSchema)eObject).setSchemaLocation(getURI().toString());
--------------5BE33EF585AFEC61B91DDA83--
Re: Parsing a WSDL with embedded xsd [message #32777 is a reply to message #31964] |
Sun, 09 November 2003 12:44   |
Ed,
Thanks for this utility - nice to know how resource factories can be used.
This doesn't really solve our problem since there are lines in the xsd,
like:
Now, we don't have any explicit import statement for that namespace. All
there is, is the XML Namespace declaration at the head of the WSDL. I
could hack in, and simulate an import statement in the xsd body and then
parse but I was wondering if there was a nicer way.
Ed Merks wrote:
> Hayden,
> > <wsdl:types>
> > </xsd:restriction>
> > </xsd:complexType>
> > <xsd:all>
> > </xsd:all>
Re: Parsing a WSDL with embedded xsd [message #32868 is a reply to message #32777] |
Mon, 10 November 2003 06:51  |
Hayden,
Soap encoding arrays are bit of a hack. It's most certainly invalid to reference
a name in a namespace that isn't explicitly imported, so to make a valid model,
you'll have to do something. You could build the model first, and then use the
model to add the import...
> Ed,
> like:
> Thanks
> Ed Merks wrote:
> > Hayden,
> > > <wsdl:types>
> > > </xsd:restriction>
> > > </xsd:complexType>
> > > <xsd:all>
> > > </xsd:all>
Re: Parsing a WSDL with embedded xsd [message #579939 is a reply to message #31929] |
Hayden,
> <wsdl:types>
> </xsd:restriction>
> </xsd:complexType>
> <xsd:all>
> </xsd:all>
* <copyright>
* Contributors:
* </copyright>
* %W%
* @version %I% %H%
super();
* <copyright>
* Contributors:
* </copyright>
* %W%
* @version %I% %H%
super();
super(uri);
try
else
try
finally
break;
break;
else
Re: Parsing a WSDL with embedded xsd [message #580550 is a reply to message #31964] |
Ed,
like:
Ed Merks wrote:
> Hayden,
> > <wsdl:types>
> > </xsd:restriction>
> > </xsd:complexType>
> > <xsd:all>
> > </xsd:all>
Re: Parsing a WSDL with embedded xsd [message #580597 is a reply to message #32777] |
Hayden,
> Ed,
> like:
> Thanks
> Ed Merks wrote:
> > Hayden,
> > > <wsdl:types>
> > > </xsd:restriction>
> > > </xsd:complexType>
> > > <xsd:all>
> > > </xsd:all>
Current Time: Fri Jul 18 19:53:25 EDT 2025
Powered by FUDForum. Page generated in 0.04676 seconds
