Home » Eclipse Projects » Eclipse Platform » Running Eclipse 3.3 on HP-Itanium
Running Eclipse 3.3 on HP-Itanium [message #319318] Thu, 16 August 2007 20:51 Go to next message
Is Eclipse 3.3 supported on HP-Itanium? I didn't see any downloads for
HP-Itanium on the Eclipse downloads page.
Does anyone know if there is any plan to support it and if so, by what date?
Thanks in advance,
-Arvind
Re: Running Eclipse 3.3 on HP-Itanium [message #319444 is a reply to message #319318] Tue, 21 August 2007 09:40 Go to previous messageGo to next message
Hi Arvind,
The last eclipse release that's available for HPUX on Itanium is 3.1.1,
which is available from
http://archive.eclipse.org/eclipse/downloads/drops/R-3.1.1-2 00509290840/index.php .
It was provided by HP.
It looks like they are working on a 3.3 version of this as well, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=194704 .
Grant
"Arvind Parasuram" <arvind.parasuram@siemens.com> wrote in message
news:fa2rf3$6rj$1@build.eclipse.org...
date?
> Thanks in advance,
> -Arvind
Re: Running Eclipse 3.3 on HP-Itanium [message #319462 is a reply to message #319444] Tue, 21 August 2007 18:36 Go to previous messageGo to next message
Thanks, Grant. Do you know if there is an official timeline on this
published somewhere regarding when HP Itanium versions will be released for
Eclipse 3.3, 3.4 etc?
This particular bug link talks about a port for Eclipse 3.3 M3, not the
released version.
-Arvind
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:faeq03$5dq$1@build.eclipse.org...
> Hi Arvind,
> Grant
>> Hi,
> date?
>> Thanks in advance,
>> -Arvind
Re: Running Eclipse 3.3 on HP-Itanium [message #319473 is a reply to message #319462] Wed, 22 August 2007 09:58 Go to previous messageGo to next message
There isn't an official timeline because this is not an OS/arch that is
built by eclipse.org. These builds are posted to the download page whenever
HP contributes them, so perhaps the reporter in the bug can give you more
info about their plans for future contributions (in particular for 3.3).
Grant
news:fafpd6$nq4$1@build.eclipse.org...
for
> released version.
> Regards,
> -Arvind
> > Hi Arvind,
> > Grant
> >> Hi,
> > date?
> >> Thanks in advance,
> >> -Arvind
Re: Running Eclipse 3.3 on HP-Itanium [message #319486 is a reply to message #319473] Wed, 22 August 2007 14:38 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
What about contributing a build on HP-Itanium yourself? Download the native parts (the launcher, SWT etc.) and see if they'll build on the back of the Linux builds that are there. Once you have those, you should be able to use the remainder of the Eclipse 3.3 jars without modification.
Might be a bit of time to get set up and working on it, but the source is there. If you're not sure where to look, I'd suggest filing a bug (or reporting on the other one) explaining that you'd like to help out, and maybe someone will guide you through the list of things that need to be done to build the native code.
Alex.
Re: Running Eclipse 3.3 on HP-Itanium [message #319496 is a reply to message #319473] Thu, 23 August 2007 00:04 Go to previous message
Thanks for the information, Grant.
-Arvind
news:fahfdp$4s5$1@build.eclipse.org...
> whenever
> Grant
> for
>> released version.
>> Regards,
>> -Arvind
>> > Hi Arvind,
>> > 3.1.1,
>> > Grant
>> >> Hi,
>> > date?
>> >> Thanks in advance,
>> >> -Arvind
Previous Topic:[DataBinding] Unable to bind Checkbox control to boolean property on model object.
Next Topic:How to transfer the files????????
Current Time: Sat Nov 08 02:23:17 EST 2025
Powered by FUDForum. Page generated in 0.07005 seconds
