Home » Language IDEs » Java Development Tools (JDT) » How to set absolute Debug configuration VM args relative to the project path?
How to set absolute Debug configuration VM args relative to the project path? [message #26903] Fri, 16 May 2003 18:06 Go to next message
My debug configuration requires several VM -D arguments. Is there a way to
specify a path relative the project which is then converted to the correct
absolute path for the VM?
Some thing like
-D XXX={project}\myFolder
which gets expanded to
-D XXX=C:\x\y\z\myFolder
Second request: How to set Debug configuration VM args relative to the project path? [message #31942 is a reply to message #26903] Tue, 20 May 2003 14:23 Go to previous messageGo to next message
"Paul Duffy" <paduffy@cisco.com> wrote in message
news:ba3nd0$9gi$1@rogue.oti.com...
to
> Some thing like
> Thanks
Re: How to set absolute Debug configuration VM args relative to the project path? [message #32123 is a reply to message #26903] Tue, 20 May 2003 15:16 Go to previous messageGo to next message
Originally posted by: jared-eclipse.mn.rr.com
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37241
https://bugs.eclipse.org/bugs/show_bug.cgi?id=10035
> to specify a path relative the project which is then converted to the
> correct absolute path for the VM?
> Some thing like
> Thanks
Re: How to set absolute Debug configuration VM args relative to the project path? [message #32645 is a reply to message #32123] Tue, 20 May 2003 17:31 Go to previous messageGo to next message
Please clarify. This is not currently possible, correct?
So each user of our team needs to explictly set the launch configuration -
absolute to their particular install folder structure - correct?
"Jared Burns" <jared-eclipse@mn.rr.com> wrote in message
news:baduua$t1i$1@rogue.oti.com...
> > Some thing like
> > Thanks
Re: How to set absolute Debug configuration VM args relative to the project path? [message #33705 is a reply to message #32645] Wed, 21 May 2003 10:22 Go to previous messageGo to next message
That's right. If the below feature requests (which I'm working on) don't
address your problem (I'm pretty sure they do), open another bug.
- Jared
Re: How to set absolute Debug configuration VM args relative to the project path? [message #33840 is a reply to message #32645] Wed, 21 May 2003 10:46 Go to previous messageGo to next message
You could create a template launch configuration that you share. Have the
other team members duplicate the configuration in their workspace and make
changes where appropriate.
> > > Some thing like
> > > Thanks
Re: How to set absolute Debug configuration VM args relative to the project path? [message #49328 is a reply to message #33840] Wed, 04 June 2003 18:15 Go to previous message
Thanks Dave, but this is exactly what we do now and it is a real pain. I've
opened a bug.
If Eclipse allows checking out a project to an abritrary folder (which is
needed...a good thing), it should be possible to set all paths relative to
that folder.
Thanks again,
"Dave Wegener" <wegener@cboenospam.com> wrote in message
news:bag3gd$kdo$1@rogue.oti.com...
configuration -
> > Thanks,
way
the
> > > > Some thing like
> > > > Thanks
Previous Topic:eclipse deadlock detection tools
Next Topic:Checkstyle plugins
Current Time: Sat May 24 05:13:55 EDT 2025
Powered by FUDForum. Page generated in 0.03026 seconds
