Home » Eclipse Projects » Eclipse Platform » Get the number of lines in a Java file
Get the number of lines in a Java file [message #318831] Tue, 07 August 2007 12:23 Go to next message
Originally posted by: malnatij.lu.unisi.ch
Hi, I need to know the number of lines contained in a java class.
I have my IType object modeling the "class".. now I'm getting its lines of code simply doing:
type.getSource().split("\n").length;
this is (slow and) not accurate and is prone to cross-platform over-simplification...(some uses /n, some /n/r, etc..) are there other ways?
Eclipse itself computes it (in the editor), therefore there should be another, better way.
Any ideas?
Thanks! :)
Re: Get the number of lines in a Java file [message #318852 is a reply to message #318831] Wed, 08 August 2007 03:16 Go to previous messageGo to next message
>Any ideas?
See methods in IDocument.
Dani
>Thanks! :)
Re: Get the number of lines in a Java file [message #318874 is a reply to message #318852] Wed, 08 August 2007 08:03 Go to previous messageGo to next message
Thanks, I've tried:
int linesOfCode = new Document(type.getSource()).getNumberOfLines();
I've also tried the other way around, initialize an empty document and computing the lines of code of a given set of lines, but the result is the same as it was with my stupid split :(. It gives me less lines than the ones shown by the eclipse editor.. am I missing something?
ciao :)
Re: Get the number of lines in a Java file [message #318920 is a reply to message #318874] Thu, 09 August 2007 05:27 Go to previous messageGo to next message
Jappo wrote:
>Thanks, I've tried:
Probably. The editor is backed by the document hence it should be the
same if you do everything right.
Dani
>ciao :)
Re: Get the number of lines in a Java file [message #318946 is a reply to message #318874] Thu, 09 August 2007 08:51 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Maybe the IDocument calculates it based on the document's line encoding, which might be \n. If there's a mixture of \n and \n\r etc. then perhaps the getNumberOfLines() will only do those based on the default line encoding. OTOH an editor might parse any line ending combination.
Just a guess. You could try writing a file with \n\r\r\r\r\r\r\n, and see how many lines the split(), getNumberOfLines(), and the editor gives you?
Alex.
Re: Get the number of lines in a Java file [message #319015 is a reply to message #318946] Thu, 09 August 2007 16:10 Go to previous message
ya, I will investigate and let you all know :)
thanks for the replies :)
Previous Topic:Why is WriteableSet not serializable ?
Next Topic:CommonNavigator and Properties View
Current Time: Fri Jul 25 17:31:53 EDT 2025
Powered by FUDForum. Page generated in 0.25967 seconds
