| Home » Eclipse Projects » Technology Project and PMC » [Proposal] GUI language
 Goto Forum:|
| [Proposal] GUI language [message #4069] | Tue, 09 July 2002 10:08  |  |
| Eclipse User  |  |  |  |  | Originally posted by: guest.guest.no
 I would suggest to create a GUI language for building graphical
 applications. This language could be a pre-requisite for a GUI builder.
 The intention under this is to create a language integrated with Eclipse
 or not which enables :
 - to create easily windows, panels, buttons, and so on... by abstracting
 at most the concepts,
 - but being more readable than an XML syntax
 - and enabling to express behaviours
 This language would generate java byte code and would be match onto
 swt/jface.
 The purpose of this language is not to make algorithms (which should be
 done in Java) but to describe GUI, and to be able to programm dynamically
 views.
 There exists a simple but powerful syntax to express GUi, and it is named
 TCL/TK. I would propose to use this syntax to build graphical interfaces
 with Java.
 regards
 Jacques
| Re: [Proposal] GUI language [message #4300 is a reply to message #4069] | Tue, 09 July 2002 12:11   |  |
| Eclipse User  |  |  |  |  | Originally posted by: dominic.nospam.com
 I agree with the idea of declarative gui. Now using something other than xml
 will make me throw up. There are so many xml readers that any one can cook
 up an xml2{tcl,swing,swt,mfc,xWindow,etc..) in a week end. There are only 2
 avenues in declarative gui arena.
 1) code in xml and write a gui engine (done by mozilla xul)
 2) code in xml and write a compiler to turn it into real gui. (done by some
 ide).
 "Jacques" <guest@guest.no> wrote in message
 news:ageqpf$p9v$1@rogue.oti.com...
 > Hello,
 > swt/jface.
 > views.
 > with Java.
 > regards
 > Jacques
| Re: [Proposal] GUI language [message #4438 is a reply to message #4300] | Tue, 09 July 2002 12:34   |  |
| Eclipse User  |  |  |  |  | I agree with jacques for my own. I think that a dclarative GUi language in XML is not the \"panacee\". Why that ?
 - it is not readable
 - it is not concise
 - we must also have a behavioral language associated with. Actually if we
 don\'t have this, soon or later we will have to add such a feature like
 javascript with...
 I don\'t know if TK is right choice, but I think defining a small
 declarative language should not be too complicated because the concepts
 are not so many...
 regards
 Xavier
 > ide).
 > \"Jacques\" <guest@guest.no> wrote in message
 > > Hello,
 > > swt/jface.
 > > views.
 > > with Java.
 > > regards
 > > Jacques
| Re: [Proposal] GUI language [message #4508 is a reply to message #4438] | Tue, 09 July 2002 12:38   |  |
| Eclipse User  |  |  |  |  | Another point in favor of the specific language is the ability to have a debugger. It is a major point. has somebody tried to debug a XSLT program?
 So maybe we don't have any more a pure declarative language ;-)..
 > - it is not concise
 > javascript with...
 > are not so many...
 > regards
 > Xavier
 xml
 > > ide).
 > > > Hello,
 > > > swt/jface.
 > > > views.
 > > > with Java.
 > > > regards
 > > > Jacques
| Re: [Proposal] GUI language [message #5265 is a reply to message #4069] | Wed, 10 July 2002 17:12   |  |
| Eclipse User  |  |  |  |  | Originally posted by: eric.rizzo.jibeinc.com
 Jacques wrote:
 > Hello,
 > swt/jface.
 > views.
 There is an existing product/project that uses an XML language to write
 Swing GUIs declaratively.  It does much more than just express widgets
 and layouts, though.  It uses the idea of generic ValueModels (ala
 VisualWorks Smalltalk) to hook models up to the views (widgets).  At
 runtime, the XML UI specification is used to generate Swing objects and
 they are wired together automatically based on the declared
 relationships between the models and the widgets (and between the models
 and each other).  It is extremely powerful - you can develop a UI with
 complex behavior (such as multiple views of the same data,
 tree/card-panel [windoze explorer-type] UIs, etc.) with much less Java
 code than Swing generally requires.
 This product is named XMLTalk
 ( http://www.trcinc.com/knowledge/software/xmltalk/xmltalk_hom e.asp).  I
 have been a co-developer on it, and I know the original and current
 "owner" is now an Eclipse user who might be interested in developing an
 SWT version and/or a Eclipse plug-in.
 Eric
 Eric Rizzo
 Software Developer
 Jibe, Inc.
 http://www.jibeinc.com
| Re: [Proposal] GUI language [message #6470 is a reply to message #5265] | Thu, 11 July 2002 01:40   |  |
| Eclipse User  |  |  |  |  | Hi Eric, If so, would this plugin be free or commercial? I think the idea is not
 bad, even if my experience on VisualWorks Smalltalk GUI format (a little
 bit like the VA smalltlk one) didn't give me a big satisfaction...
 regards
 Xavier
 Eric Rizzo wrote:
 > Jacques wrote:
 > > Hello,
 > > swt/jface.
 > > views.
 > 	Eric
 > Eric Rizzo
 > Software Developer
 > Jibe, Inc.
| Re: [Proposal] GUI language [message #6654 is a reply to message #6470] | Thu, 11 July 2002 11:49   |  |
 xme wrote:
 > Hi Eric,
 > regards
 > Xavier
 1) Since XMLTalk itself is what you might call "semi-commercial" (it's
 free to get and use, but not open-source) I suspect a plug-in written by
 its owner ((TRC/Perot Systems) would likely be the same.  If however,
 someone were to write a plug-in that generated XMLTalk UI specs (XML
 files) and helped with the Java code that is needed to support a given
 XMLTalk application, that kind of tool could be open-source, independent
 of TRC/Perot Systems.  I know that the original developer (Frank) has
 been lobbying within his company to get XMLTalk released as open-source,
 but has met some resistance so far.
 2) XMLTalk currently sits on top of Swing.  Writing an SWT version of it
 would require some serious changes to the inner workings of it -
 probably making the pieces that build the widget objects pluggable so
 you could have a Swing builder, an SWT builder, etc.  Making it
 pluggable like that has been discussed, but not started (yet?).  That
 said, an SWT version is not all that useful right now because SWT usage
 is not widespread outside of Eclipse plug-in developers.  If SWT becomes
 popular for non-Eclipse apps, then an SWT XMLTalk would be more worth
 the effort.
 3) Not sure what you mean by "VisualWorks Smalltalk GUI format", but
 XMLTalk only borrows the idea of ValueModels.  It does not borrow any of
 the view side of things from VisualWorks.  Generic models that can be
 tied to any type of view are very powerful - a concept that Swing's MVC
 implementation sorely misses.
 BTW, if you have more questions about XMLTalk, I encourage you to join
 the developer's forum at http://groups.yahoo.com/group/xmltalk-dev/
 Eric
 Eric Rizzo
 Software Developer
 Jibe, Inc.
| Re: [Proposal] GUI language [message #6670 is a reply to message #4508] | Thu, 11 July 2002 12:27   |  |
| Eclipse User  |  |  |  |  | Originally posted by: bob.objfac.com
 XSLT isn't pure declarative, it is merely functional (stateless). You can
 write programs in XSLT if you try hard enough. ;-}
 Bob
 "xme" <xmehaut@apri-group.com> wrote in message
 news:agf3i6$a8$1@rogue.oti.com...
 in
 > > - it is not concise
 we
 > > javascript with...
 > > are not so many...
 > > regards
 > > Xavier
 than
 > xml
 cook
 only 2
 some
 > > > ide).
 > > > > Hello,
 builder.
 Eclipse
 abstracting
 > > > > swt/jface.
 be
 dynamically
 > > > > views.
 named
 interfaces
 > > > > with Java.
 > > > > regards
 > > > > Jacques
| Re: [Proposal] GUI language [message #31439 is a reply to message #4069] | Wed, 16 October 2002 08:45   |  |
| Eclipse User  |  |  |  |  | Originally posted by: alf.ifb.bv.tu-berlin.de
 I don't want to offend anybody. But that is certainly NOT what we want!
 XML?
 If you really want to do something like that, probably most of us agree
 that XML is 'the choice' to do something like that. Nothing else is that
 easy
 to parse and handle as XML.
 Another language?
 In order to define a gui language that supports as much features as
 Swing (I don't know much about SWT), it will certainly not easier to
 program in that language than programming in Java. You still would be
 overwhelmed with thousands of components, layouts, borders, buttons
 and so on. So what do you really get of it then? Debugging will be worse
 or even unpossible. New plug-ins would be needed that support the
 developper when coding in this language. I am saying that no developer
 would ever want to use your language because it will certainly be more
 complex and less supported by tools than Java.
 It does make sense?
 Your idea does make sense in a way as XMLTalk or XUL, where the
 available features in your GUI are limited in order to fullfill some GUI
 guidelines or for Rapid Prototyping.
 And it does make sense as a format to exchange GUI descriptions between
 GUI Builders.
 Too much Java code?
 What is so bad about much Java code, with all the tool support that is
 available?
 What you really want?
 Is a powerful and still easy to use GUI-Builder, so that learning the whole
 Swing/SWT Api is needless.
 greetings, alf
 "Jacques" <guest@guest.no> schrieb im Newsbeitrag
 > Hello,
 > swt/jface.
 > views.
 > with Java.
 > regards
 > Jacques
| Re: [Proposal] GUI language [message #31885 is a reply to message #31439] | Thu, 17 October 2002 13:51   |  |
| Eclipse User  |  |  |  |  | > Your idea does make sense in a way as XMLTalk or XUL, where the > available features in your GUI are limited in order to fullfill some GUI
 What limitations are you referring to here? Don't know much about XUL,
 but XMLTalk does not prevent you from using the underlying Swing API
 to do whatever you want to the widgets constructed from XML if needed.
 My experience is that it is almost never needed though.
 Frank Sauer
 "Alf Schiefelbein" <alf@ifb.bv.tu-berlin.de> wrote in message
 news:aojlh0$at4$1@rogue.oti.com...
 > XML?
 > easy
 > Another language?
 > It does make sense?
 > GUI Builders.
 > Too much Java code?
 > available?
 whole
 > greetings, alf
 > > Hello,
 > > swt/jface.
 dynamically
 > > views.
 named
 > > with Java.
 > > regards
 > > Jacques
| Re: [Proposal] GUI language [message #31991 is a reply to message #31885] | Fri, 18 October 2002 17:20   |  |
 "Frank Sauer" <frank.sauer@trcinc.com> schrieb im Newsbeitrag
 news:aomriq$bu8$1@rogue.oti.com...
 > Frank Sauer
 Hello Frank!
 I have to admit that I am not too familar (never used it) with XUL and
 XMLTalk.
 What I meant is that if you offer all the options of gui designing that you
 have
 in Java for XML, coding in XML will not be any easier. Defining your gui
 in XML only makes sense if you are agreeing on some default values, i.e.
 border=5, backgroundcolor=grey, and so on. If you want to specify all those
 values in XML the same as you usually have to in Java, the XML will not be
 any
 prettier.
 And here it comes to one of my big critics of Swing/AWT. A concept of
 reasonable
 default values is missing or at least not documented well enough! Why do I
 always
 have to set the border of my panels by hand in order to make the gui a
 little pretty?
 And so on ... Understand what I mean?
 Although I don't know XUL and XMLTalk, I am pretty sure that there strength
 is not the XML but some other concept behind, like the assignment of
 reasonable
 default values or some other concept that makes it possible to define a
 pretty gui
 with as few statements as possible.
 greetings, alf
| Re: [Proposal] GUI language [message #39056 is a reply to message #4069] | Thu, 19 December 2002 21:49  |  |
| Eclipse User  |  |  |  |  | Jacques wrote: > Hello,
 <snip>
 Please pardon my ignorance, as I've only been using Eclipse with any
 vigor for about a month...
 Is a GUI language necessary?  Couldn't something like the GEF function
 as a base for creating a visual layout editor, then pipe it's output
 through a code generator?  I ask, because I have no clue if it's
 possible with the framework; I only know it's there because a plugin I
 use requires it.  IMHO, if that is possible, why not leverage a
 tool/framework that was developed specifically for handling graphics
 within Eclipse?
 Randy
| Re: [Proposal] GUI language [message #566704 is a reply to message #4069] | Tue, 09 July 2002 10:11  |  |
| Eclipse User  |  |  |  |  | or Ruby ;-)
 Jacques wrote:
 > Hello,
 > swt/jface.
 > views.
 > with Java.
 > regards
 > Jacques
| some examples [message #566733 is a reply to message #4069] | Tue, 09 July 2002 10:15  |  |
| Eclipse User  |  |  |  |  | here are some examples defined in TK : * List box
 listbox .list -width 20 -height 10 -setgrid 1
 pack .list -fill x
 list insert 0 yellow gray green blue red black white
 * Check button
 proc print_v {} {
 global v_top v_middle v_bottom
 puts [format "top: %s middle: %s bottom: %s" $v_top $v_middle $v_bottom]
 checkbutton .top -text top -anchor w -variable v_top
 checkbutton .middle -text middle -anchor w -variable v_middle
 checkbutton .bottom -text bottom -anchor w -variable v_bottom
 pack .top .middle .bottom -side top -fill x
 button .b -text Quit -command exit
 pack .b
 bind all <1> {print_v}
 * Frames
 frame .f1
 frame .f2
 pack .f1 .f2 -side left
 button .f1.b1 -text "Button1" -command {puts "push button1!!"}
 button .f1.b2 -text "Button2" -command {puts "push button2!!"}
 button .f2.b -text "Quit" -command exit
 pack .f1.b1 .f1.b2 .f2.b -fill x
 * labels
 label .l -text "Hello World!"
 pack .l -fill x
 *Menus
 frame .mbar -relief raised -bd 2
 pack .mbar -fill x
 menubutton .mbar.file -text {File} -underline 0 -menu .mbar.file.menu
 menubutton .mbar.help -text {Help} -underline 0 -menu .mbar.help.menu
 pack .mbar.file .mbar.help -side left -padx 1m
 mbar.file.menu add command -label "New..." -underline 0 \
 -command {puts "opening new file"}
 mbar.file.menu add command -label "Quit" -underline 0 \
 -command exit
 mbar.help.menu add command -label "About" -underline 0 \
 -command {puts "This is menu example."}
 and so on...
| Re: [Proposal] GUI language [message #566782 is a reply to message #4069] | Tue, 09 July 2002 12:11  |  |
| Eclipse User  |  |  |  |  | I agree with the idea of declarative gui. Now using something other than xml will make me throw up. There are so many xml readers that any one can cook
 ide).
 > Hello,
 > swt/jface.
 > views.
 > with Java.
 > regards
 > Jacques
| Re: [Proposal] GUI language [message #566822 is a reply to message #4300] | Tue, 09 July 2002 12:34  |  |
 - it is not concise
 javascript with...
 are not so many...
 regards
 Xavier
 > ide).
 > > Hello,
 > > swt/jface.
 > > views.
 > > with Java.
 > > regards
 > > Jacques
| Re: [Proposal] GUI language [message #566842 is a reply to message #4438] | Tue, 09 July 2002 12:38  |  |
 > - it is not concise
 > javascript with...
 > are not so many...
 > regards
 > Xavier
 xml
 > > ide).
 > > > Hello,
 > > > swt/jface.
 > > > views.
 > > > with Java.
 > > > regards
 > > > Jacques
| Re: [Proposal] GUI language [message #566994 is a reply to message #4369] | Wed, 10 July 2002 06:28  |  |
| Eclipse User  |  |  |  |  | Originally posted by: unknown.dot.not
 >> some
 >> ide).
 > I think both options are interesting.
 > With a SWT implementation of the xul-specification
 > (http://mozilla.org/projects/xul/xul.html) and a xul-builder we could
 > have a very nice tool.
 > Stein
 This sounds really exciting. Does xul handle
 all the different layout options that swt
 provides?
 Polle
| Re: [Proposal] GUI language [message #567016 is a reply to message #4855] | Wed, 10 July 2002 09:46  |  |
| Eclipse User  |  |  |  |  | polle@snave wrote: > This sounds really exciting. Does xul handle
 > provides?
 They have something called boxes and grids, but I'm not sure if those
 are sufficient or if we need to add some variants.
 Stein
| Re: [Proposal] GUI language [message #567153 is a reply to message #4069] | Wed, 10 July 2002 17:12  |  |
 > swt/jface.
 > views.
 Eric
 Eric Rizzo
 Software Developer
 Jibe, Inc.
| Re: [Proposal] GUI language [message #567420 is a reply to message #5265] | Thu, 11 July 2002 01:40  |  |
 regards
 Xavier
 Eric Rizzo wrote:
 > Jacques wrote:
 > > Hello,
 > > swt/jface.
 > > views.
 > 	Eric
 > Eric Rizzo
 > Software Developer
 > Jibe, Inc.
| Re: [Proposal] GUI language [message #567760 is a reply to message #6470] | Thu, 11 July 2002 11:49  |  |
| Eclipse User  |  |  |  |  | xme wrote: > Hi Eric,
 > regards
 > Xavier
 the effort.
 Eric
 Eric Rizzo
 Software Developer
 Jibe, Inc.
| Re: [Proposal] GUI language [message #567793 is a reply to message #4508] | Thu, 11 July 2002 12:27  |  |
 Bob
 in
 > > - it is not concise
 we
 > > javascript with...
 > > are not so many...
 > > regards
 > > Xavier
 than
 > xml
 cook
 only 2
 some
 > > > ide).
 > > > > Hello,
 builder.
 Eclipse
 abstracting
 > > > > swt/jface.
 be
 dynamically
 > > > > views.
 named
 interfaces
 > > > > with Java.
 > > > > regards
 > > > > Jacques
| Re: [Proposal] GUI language [message #584756 is a reply to message #4069] | Wed, 16 October 2002 08:45  |  |
| Eclipse User  |  |  |  |  | I don't want to offend anybody. But that is certainly NOT what we want!
 XML?
 easy
 Another language?
 It does make sense?
 GUI Builders.
 Too much Java code?
 available?
 greetings, alf
 > Hello,
 > swt/jface.
 > views.
 > with Java.
 > regards
 > Jacques
| Re: [Proposal] GUI language [message #584944 is a reply to message #31439] | Thu, 17 October 2002 13:51  |  |
 Frank Sauer
 > XML?
 > easy
 > Another language?
 > It does make sense?
 > GUI Builders.
 > Too much Java code?
 > available?
 whole
 > greetings, alf
 > > Hello,
 > > swt/jface.
 dynamically
 > > views.
 named
 > > with Java.
 > > regards
 > > Jacques
| Re: [Proposal] GUI language [message #584996 is a reply to message #31885] | Fri, 18 October 2002 17:20  |  |
| Eclipse User  |  |  |  |  | "Frank Sauer" <frank.sauer@trcinc.com> schrieb im Newsbeitrag news:aomriq$bu8$1@rogue.oti.com...
 > Frank Sauer
 Hello Frank!
 XMLTalk.
 have
 any
 prettier.
 reasonable
 always
 little pretty?
 reasonable
 pretty gui
 greetings, alf
| Re: [Proposal] GUI language [message #587852 is a reply to message #4069] | Thu, 19 December 2002 21:49  |  |
 <snip>
 within Eclipse?
 Randy
 Current Time: Fri Oct 31 15:04:39 EDT 2025
 Powered by FUDForum . Page generated in 0.10366 seconds |
