Home » Eclipse Projects » Eclipse Platform » Plug-in not available as bundle
Plug-in not available as bundle [message #318248] Mon, 23 July 2007 18:51 Go to next message
Originally posted by: davidhuebel.example.net
At run-time I need to access the bundles for some of my plug-in
dependencies. I can access all the bundles loaded in the Eclipse framework
using the following code:
ArrayList<Bundle> bundleList = new ArrayList<Bundle>();
for(IBundleGroupProvider provider : Platform.getBundleGroupProviders()) {
for(IBundleGroup group : provider.getBundleGroups()) {
for(Bundle bundle : group.getBundles()) {
bundleList.add(bundle);
// debugging code:
System.out.println("bundle: " + bundle.getSymbolicName());
One of the plugins I'm using doesn't show up as a bundle in this list. It
is one of several plugins I've created to wrap external jar files. The
others show up as plugins, but this one (which wraps the Apache Derby lib
jar derby.jar) does not. I have verified that the Derby plugin is present
at runtime by checking Help/About Eclipse SDK/Plug-in Details, and I have
carefully compared the MANIFEST.MF and layouts of the working and
nonworking plugins without finding any meaningful differences.
I'm pretty stuck. Any suggestions?
David
Re: Plug-in not available as bundle [message #318260 is a reply to message #318248] Tue, 24 July 2007 03:52 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
They're almost certainly not in an IBundleGroup, which is why you're not seeing them. You should be able to get a list of all bundles using BundleContext.getBundles(), which is handed to you during start() of the bundle itself.
Alex.
Re: Plug-in not available as bundle [message #318281 is a reply to message #318260] Tue, 24 July 2007 11:01 Go to previous message
> bundle itself.
> Alex.
Thanks; this did the trick.
-David
Previous Topic:[Compare] Change Request
Next Topic:Missing Resource Exception
Current Time: Tue Jul 22 02:21:55 EDT 2025
Powered by FUDForum. Page generated in 0.04356 seconds
