Howto invoke an antfile through transformation? [message #31346] |
Mon, 20 August 2007 07:12  |
Originally posted by: Thalya79.web.de
Hello everyone!
Is it possible to pass any arguments to the transformation to invoke any
ant build-files during/after transformation?
I generate several files which after generating are used by an antfile. It
would be great, if I could invoke the ant automatically within the
jet-transformation.
I hope anyone can understand what I mean. For a java-project for example
it is possible to define arguments in the run configurations - I hope
something like that ist also possible for jet!
Thank you for any help.
Re: Howto invoke an antfile through transformation? [message #31711 is a reply to message #31438] |
Tue, 28 August 2007 05:18   |
Thank you, Paul.
My first idea was to write a ant-file which would start both ant-tasks -
for the jet-transformation and for the other.
But I wasn't able to get the jet-ant-task running, so I tried to do it
another way.
But I guess, I should try it the other way again.
Paul Elder wrote:
> Yasmin:
> There isn't a JET tag to invoke ant, but it would certainly be possible to
> write one. If you decide to go that route, the only trick would be that JET
> defers all its IO until all templates have executed, the ant tag would have
> to defer its actions, too.
> The other possibility is to invoke your JET transformation from ANT, and
> then invoke the other ANT scripts. Personally, I think this would be easier.
> JET includes an ANT task for invoking a transformation. The only catch is
> that the ANT build must be invoked with the Eclipse ant runner. The JET ant
> task looks like:
> <jet.transform transformid="my.transform.id"
> resource="myProject/path-to-input-file"/>
> You can use Eclipse as an ant runner by using the Eclipse ant runner
> application:
> eclipse -application org.eclipse.ant.core.antRunner ...ant command line..
> Paul
> "Yasmin Stoesser" <Thalya79@web.de> wrote in message
> news:0825fd1bf0a4131145c55cbe25f4ccd9$1@www.eclipse.org...
>> Hello everyone!
>> jet-transformation.
Re: Howto invoke an antfile through transformation? [message #32303 is a reply to message #32235] |
Fri, 31 August 2007 06:42  |
It is the plugin-id, which you'll find in on the General tab of the plug-in
manifest editor, or in MANIFEST.MF, as Bundle-SymbolicName
The JET project will either have to be in the workspace your headless build
is running on, or it will have to be Exported via the Deployable plug-ins
and fragments wizard, and then placed in the plugins directory of you
Eclipse installation.
Paul
news:823280912ff910b6a34e0f8ea035f076$1@www.eclipse.org...
> Sorry to ask such silly questions...
> Please forget the PDE-question.
> If I start the buildfile like you suggested, I get the Error "could not
> find transformation with id..."
> Now my question is where the transformId is set. In the plugin.xml? I
> can't find it.
> If I start the generator within eclipse, the Id in the run configurations
> is the same I used in the build-file.
FUDForum. Page generated in 0.07649 seconds
