Home » Eclipse Projects » Eclipse Platform » PDE - change qualifier
PDE - change qualifier [message #317668] Wed, 11 July 2007 11:05 Go to next message
this is a question about plug-in deployement and Im not sure if I'm in the
right newsgroup.
During a build of a feature I use the "qualifier" for version numbering.
The "qualifier" is replaced by YYYYMMDDHHMM. I'd like to change it so it
doesn't append hours and minutes to the version number i.e. YYYYMMDD.
Where can I do this ?
Thank you,
Tex.
Re: PDE - change qualifier [message #317678 is a reply to message #317668] Wed, 11 July 2007 14:23 Go to previous messageGo to next message
Tex,
If you are using map files to fetch your features out of cvs (or some other
repository) then the Tag from the map files will be used in the qualifier.
If you are not doing that, there are 2 other ways to set the qualifier:
1) In the feature's build.properties, set qualifier=YYYYMMDD
2) In the build configuration build.properties set forceContextQualifier=YYYYMMDD
I would suggest method (2), which can also be achieved by adding
-DforceContextQualifier=YYYYMMDD to your command line
-Andrew
Tex Twil wrote:
> Hello,
> the right newsgroup.
> Thank you,
> Tex.
Re: PDE - change qualifier [message #317702 is a reply to message #317678] Thu, 12 July 2007 03:14 Go to previous messageGo to next message
yes my project is on a SVN server. Can you point me to this map file
'cos I dont really know what it is.
thanks,
Tex.
Andrew Niefer wrote:
> Tex,
> other repository) then the Tag from the map files will be used in the
> qualifier.
> -Andrew
> Tex Twil wrote:
>> Hello,
>> numbering. The "qualifier" is replaced by YYYYMMDDHHMM. I'd like to
>> change it so it doesn't append hours and minutes to the version number
>> i.e. YYYYMMDD.
>> Thank you,
>> Tex.
Re: PDE - change qualifier [message #317759 is a reply to message #317702] Thu, 12 July 2007 10:17 Go to previous message
There are some docs on fetching from a repository here:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. pde.doc.user/guide/tasks/pde_fetch_phase.htm
Note however, that SVN is not supported by default. There is however, an
extension point for other repos, and someone wrote an SVN plugin which you can
find here: (there may be others I don't know of)
http://sourceforge.net/projects/svn-pde-build/
The specific format of the map files for SVN will be dependent on that plug-in.
-Andrew
Tex Twil wrote:
> thanks,
> Tex.
>> Tex,
>> qualifier.
>> -Andrew
>> Tex Twil wrote:
>>> Hello,
>>> in the right newsgroup.
>>> Thank you,
>>> Tex.
Previous Topic:Host bundle 'xxx.xxx.xxx.common' exists but is unresolved
Next Topic:Eclipse 3.3 starts Eclipse 3.2.2
Current Time: Sat Nov 08 14:37:02 EST 2025
Powered by FUDForum. Page generated in 0.03610 seconds
