Home » Modeling » OCL » Syntax helper for OCL undefined type
Syntax helper for OCL undefined type [message #31734] Mon, 02 July 2007 08:17 Go to next message
Originally posted by: firstname.name.gmail.com
I get a NullPointerException with the syntax helper when one of the typed
element has a undefined type.
For example, my class A has a property p. The type of p is not defined. I
select the class A, use the console OCL interpreter, ask a completion with
'self.' It triggers:
at org.eclipse.ocl.uml.UMLReflectionImpl.getDescription(UMLRefl ectionImpl.java:92)
A quick look at the source gives:
org.eclipse.ocl.uml UMLReflectionImpl
public String getDescription(Object namedElement) {
if (namedElement instanceof TypedElement) {
return ((TypedElement) namedElement).getType().getName();
Now I am not able to state if its a bug or not, because I don't know how to deal
with a undefined type.
F. Lagarde
Re: Syntax helper for OCL undefined type [message #31875 is a reply to message #31734] Wed, 04 July 2007 11:23 Go to previous message
Hi, François,
In UML, TypedElements can be well-formed without having a type. The syntax
helper should handle this more gracefully, probably by showing some kind of
"(untyped)" string or such.
This is a bug.
Christian
François Lagarde wrote:
> Hello,
> at
> to deal with a undefined type.
Previous Topic:About adding new predefined propertys
Next Topic:problem with multiStatus
Current Time: Sat Jul 26 20:56:10 EDT 2025
Powered by FUDForum. Page generated in 0.03952 seconds
