Home » Eclipse Projects » Eclipse Platform » ant editor returns class cast exception
ant editor returns class cast exception [message #316260] Mon, 04 June 2007 04:26 Go to next message
Hi all,
When I open any of my ant build scipt files (build.xml, sub-build.xml, etc)
I get a class cast exception:
org.apache.xerces.parsers.XIncludeAwareParserConfiguration cannot be cast to
org.apache.xerces.xni.parser.XMLParserConfiguration.
The strange thing is that right after eclipse startup, the files can be
opened properly. After a certain period (can be a full day of labor or a few
minutes),
suddenly the error pops up and from then on, non of the other ant files can
be opened anymore.
The following trace is printed on console
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:114)
at java.util.zip.ZipFile.<init>(ZipFile.java:131)
at
org.apache.tools.ant.AntClassLoader.getResourceURL(AntClassL oader.java:1014)
at
org.apache.tools.ant.AntClassLoader$ResourceEnumeration.find NextResource(AntClassLoader.java:146)
at
org.apache.tools.ant.AntClassLoader$ResourceEnumeration.<init >(AntClassLoader.java:108)
at
org.apache.tools.ant.AntClassLoader.findResources(AntClassLo ader.java:958)
at java.lang.ClassLoader.getResources(ClassLoader.java:1015)
at
org.apache.tools.ant.taskdefs.Definer.resourceToURLs(Definer .java:364)
at org.apache.tools.ant.taskdefs.Definer.execute(Definer.java:2 56)
at
org.apache.tools.ant.ComponentHelper.checkNamespace(Componen tHelper.java:802)
at
org.apache.tools.ant.ComponentHelper.getDefinition(Component Helper.java:259)
at
org.apache.tools.ant.ComponentHelper.createComponent(Compone ntHelper.java:236)
at
org.apache.tools.ant.ComponentHelper.createComponent(Compone ntHelper.java:215)
at
org.apache.tools.ant.UnknownElement.makeObject(UnknownElemen t.java:411)
at
org.apache.tools.ant.UnknownElement.maybeConfigure(UnknownEl ement.java:160)
at
org.eclipse.ant.internal.ui.model.AntDefiningTaskNode.config ure(AntDefiningTaskNode.java:85)
at
org.eclipse.ant.internal.ui.model.AntModel.resolveBuildfile( AntModel.java:504)
at
org.eclipse.ant.internal.ui.model.AntModel.parseDocument(Ant Model.java:329)
at
org.eclipse.ant.internal.ui.model.AntModel.reconcile(AntMode l.java:265)
at
org.eclipse.ant.internal.ui.model.AntModel.getProjectNode(An tModel.java:1386)
at
org.eclipse.ant.internal.ui.model.AntModel.getProjectNode(An tModel.java:1396)
at
org.eclipse.ant.internal.ui.editor.text.AntFoldingStructureP rovider.updateFoldingRegions(AntFoldingStructureProvider.jav a:88)
at
org.eclipse.ant.internal.ui.editor.AntEditor.projectionEnabl ed(AntEditor.java:1210)
at
org.eclipse.jface.text.source.projection.ProjectionViewer.fi reProjectionEnabled(ProjectionViewer.java:481)
at
org.eclipse.jface.text.source.projection.ProjectionViewer.en ableProjection(ProjectionViewer.java:529)
at
org.eclipse.jface.text.source.projection.ProjectionViewer.do Operation(ProjectionViewer.java:1419)
at
org.eclipse.ant.internal.ui.editor.AntEditor$StatusLineSourc eViewer.doOperation(AntEditor.java:213)
at
org.eclipse.ant.internal.ui.editor.AntEditor.createPartContr ol(AntEditor.java:944)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at
org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2688)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2602)
at
org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2594)
at
org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2546)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2541)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2525)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2516)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
at
org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:98)
at
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:98)
at
org.eclipse.cdt.internal.ui.cview.OpenFileGroup.runDefaultAc tion(OpenFileGroup.java:150)
at
org.eclipse.cdt.internal.ui.cview.MainActionGroup.runDefault Action(MainActionGroup.java:280)
at
org.eclipse.cdt.internal.ui.cview.CView.handleOpen(CView.jav a:229)
at org.eclipse.cdt.internal.ui.cview.CView$8.open(CView.java:49 3)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:850)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at
org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at
at
at
org.apache.tools.ant.AntClassLoader$ResourceEnumeration.next Element(AntClassLoader.java:129)
at
org.apache.tools.ant.util.CollectionUtils$CompoundEnumeratio n.nextElement(CollectionUtils.java:198)
at
sun.misc.CompoundEnumeration.nextElement(CompoundEnumeration .java:43)
at org.apache.tools.ant.taskdefs.Definer.execute(Definer.java:2 60)
at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at
org.eclipse.ant.internal.ui.model.AntDefiningTaskNode.config ure(AntDefiningTaskNode.java:86)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
I checked the bug list for this issue, but found no entry that desribes
this behaviour.
Is this a known bug? Is there a workaround available?
Thanks in advance
Yves Willems
Re: ant editor returns class cast exception [message #316281 is a reply to message #316260] Mon, 04 June 2007 20:55 Go to previous messageGo to next message
Which Eclipse version are you using?
We had and fixed https://bugs.eclipse.org/bugs/show_bug.cgi?id=143008
(workaround in https://bugs.eclipse.org/bugs/show_bug.cgi?id=143008#c6)
We still have
https://bugs.eclipse.org/bugs/show_bug.cgi?id=152793
same workarounds...
HTH
Darins
"Yves Willems" <ywillems@maia-scientific.com> wrote in message
news:f40ib8$6pc$1@build.eclipse.org...
> Hi all,
> etc)
> to
> few minutes),
> can
> be opened anymore.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> this behaviour.
> Thanks in advance
> Yves Willems
Re: ant editor returns class cast exception [message #316319 is a reply to message #316281] Wed, 06 June 2007 02:59 Go to previous messageGo to next message
I had an separate version of ant installed (together with ant-contrib). Now
that I direct the ANT_HOME to the eclipse distributed version of ant it
seems to go OK.
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:f42ced$dh6$1@build.eclipse.org...
> We still have
> same workarounds...
> HTH
> Darins
>> Hi all,
>> etc)
>> to
>> few minutes),
>> can
>> be opened anymore.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> this behaviour.
>> Thanks in advance
>> Yves Willems
Re: ant editor returns class cast exception [message #316338 is a reply to message #316319] Wed, 06 June 2007 18:44 Go to previous messageGo to next message
Removing the xerces jars from your separate installation or from the Ant
runtime classpath would fix it up as well (as outlined in the bugs).
Darins
news:f45m0f$sc6$1@build.eclipse.org...
>seems to go OK.
> Thanks
>> We still have
>> same workarounds...
>> HTH
>> Darins
>>> Hi all,
>>> etc)
>>> cast to
>>> few minutes),
>>> can
>>> be opened anymore.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> this behaviour.
>>> Thanks in advance
>>> Yves Willems
Re: ant editor returns class cast exception [message #319490 is a reply to message #316260] Wed, 22 August 2007 17:21 Go to previous message
Originally posted by: chris.beels.gmail.com
I was able to fix this by Preferences...Ant...Runtime...Restore Defaults.
Previous Topic:Any efficient way to display a huge amount of items?
Next Topic:[DataBinding] How to handle Date and Timestamp conversion?
Current Time: Sat Nov 08 02:23:12 EST 2025
Powered by FUDForum. Page generated in 0.05604 seconds
