Home » Eclipse Projects » DSDP - Target Management » Hang while loading workspace, possibly related to Target Management.
Hang while loading workspace, possibly related to Target Management. [message #31570] Wed, 28 January 2009 13:32 Go to next message
Hi all,
When restarting after an unclean shutdown (e.g. after Eclipse has crashed
or after I have terminated the process without exiting correctly), I often
find Eclipse hangs while loading my workspace.
I think this may be related to the Target Management plugin: the only way
I have found to successfully load up my workspace again is to temporarily
remove the Target Management metadata from my workspace, i.e.
<workspace>/.metadata/.plugins/org.eclipse.rse.*.
After one successful startup, I can then stop Eclipse, copy my original TM
metadata back to my workspace, start Eclipse again, and continue working
as usual.
Here is a Java dump taken during the hang on startup:
http://soal.org/eclipse/javacore.20090128.175548.4524.0002.t xt
Here are my Eclipse configuration details:
http://soal.org/eclipse/configDetails.txt
Do you have any thoughts on what might be causing this or on how I could
avoid this?
Robin
Re: Hang while loading workspace, possibly related to Target Management. [message #31638 is a reply to message #31570] Sun, 01 February 2009 21:40 Go to previous message
Hi Robin,
there are some existing bugs in bugzilla that might be related.
Are you using EFS linked resources?
At any rate, please file a bug in bugzilla with the information
you have provided, this will allow us to track this much better:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target%2 0Management&component=RSE
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Robin Fernandes wrote:
> Hi all,
> crashed or after I have terminated the process without exiting
> correctly), I often find Eclipse hangs while loading my workspace.
> way I have found to successfully load up my workspace again is to
> temporarily remove the Target Management metadata from my workspace,
> i.e. <workspace>/.metadata/.plugins/org.eclipse.rse.*.
> TM metadata back to my workspace, start Eclipse again, and continue
> working as usual.
> avoid this?
> Regards,
> Robin
Re: Hang while loading workspace, possibly related to Target Management. [message #578867 is a reply to message #31570] Sun, 01 February 2009 21:40 Go to previous message
Hi Robin,
> Hi all,
> working as usual.
> avoid this?
> Regards,
> Robin
Previous Topic:Call for participation: TM 3.1m5 test pass on 1-Feb-2009
Next Topic:'Invalid Project Description' when using RSE file system
Current Time: Sat Jul 26 21:23:15 EDT 2025
Powered by FUDForum. Page generated in 0.25467 seconds
