Home » Eclipse Projects » Eclipse Platform » Is it advisable to subclass ComboBoxCellEditor?
| Is it advisable to subclass ComboBoxCellEditor? [message #315366] |
Wed, 09 May 2007 07:10  |
Originally posted by: inliner683.gmx.de
I am wondering if it is good advice to subclass ComboBoxCellEditor?
I read about the issues when subclassing widgets, so what would happen
to my subclass, if in next release the ComboBoxCellEditor fundamentally
changes?
In particular I want to make ComboBoxCelleditor deal with other values
than Integers.
The other way would be to write an own "SpecialComboBoxCellEditor"
dealing with my data objects.
What would you suggest? Thanks in advance.
| Re: Is it advisable to subclass ComboBoxCellEditor? [message #315376 is a reply to message #315368] |
Wed, 09 May 2007 08:30   |
OK I looked at the ComboBoxViewerCellEditor.
Althoug i set a LabelProvider(), the box is empty (only the labels).
The returned value is correct, e.g. it returns my object which is
provided by a call to setInput() on the viewer. I don't know why the
labels are empty even if i provide a static string as label in the
labelprovider.
Nevertheless, this does do nothing other, as provide handling of custom
objects in the box via the label and content interfaces, which I wanted
to achieve by using e.g. a HashMap and implement the CellEditor
analogous to ComboBoxCellEditor, am I right?
Tom Schindl schrieb:
> Why don't you write a Viewer around your ComboBox? This would be the
> cleanest solution and we will eventually provide such a thing in 3.4
> hopefully.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=104225
> Tom
> inliner683 schrieb:
>> Hello,
>> changes?
>> than Integers.
| Re: Is it advisable to subclass ComboBoxCellEditor? [message #315382 is a reply to message #315376] |
Wed, 09 May 2007 09:30   |
After investigating more in ComboBoxViewerCellEditor, i still can't
display any Labels! I set the LabelProvider and tried different
implementations and the LabelProvider which defaults to the
toString()-method.
In debug mode i can see the the method setItems is called on the
underlying Combo wiht the correct array of labels, but in the view I see
nothing. If it would work, it would fit well in my context, so
thanks for the hint so far.
But what am I missing to let it work properly?
> labelprovider.
>> Hi,
>> hopefully.
>> Tom
>> inliner683 schrieb:
>>> Hello,
>>> changes?
>>> than Integers.
| Re: Is it advisable to subclass ComboBoxCellEditor? [message #315388 is a reply to message #315382] |
Wed, 09 May 2007 10:05   |
Can you provide me a standalone easy snippet to track this down?
Tom
> toString()-method.
>> labelprovider.
>> custom objects in the box via the label and content interfaces, which
>> I wanted to achieve by using e.g. a HashMap and implement the
>> CellEditor analogous to ComboBoxCellEditor, am I right?
>>> Hi,
>>> hopefully.
>>> Tom
>>> inliner683 schrieb:
>>>> Hello,
>>>> changes?
>>>> than Integers.
| Re: Is it advisable to subclass ComboBoxCellEditor? [message #315397 is a reply to message #315388] |
Wed, 09 May 2007 10:53   |
--------------090602080804090700080402
Yes I can, see the attached files.
> Tom
>> toString()-method.
>> see nothing. If it would work, it would fit well in my context, so
>>> labelprovider.
>>>> Hi,
>>>> hopefully.
>>>> Tom
>>>> inliner683 schrieb:
>>>>> Hello,
>>>>> fundamentally
>>>>> changes?
>>>>> than Integers.
name="ComboBoxViewerCellEditor.java"
Content-Disposition: inline;
filename="ComboBoxViewerCellEditor.java"
import java.text.MessageFormat;
import org.eclipse.core.runtime.Assert;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.ComboBoxCellEditor;
import org.eclipse.jface.viewers.ComboViewer;
import org.eclipse.jface.viewers.IBaseLabelProvider;
import org.eclipse.jface.viewers.IContentProvider;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.jface.viewers.StructuredSelection;
import org.eclipse.jface.viewers.StructuredViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.CCombo;
import org.eclipse.swt.events.FocusAdapter;
import org.eclipse.swt.events.FocusEvent;
import org.eclipse.swt.events.KeyAdapter;
import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.TraverseEvent;
import org.eclipse.swt.events.TraverseListener;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
* A cell editor that presents a list of items in a combo box. In contrast to
* {@link ComboBoxCellEditor} it wraps the underlying {@link CCombo} using a
* {@link ComboViewer}
public class ComboBoxViewerCellEditor extends CellEditor {
* The custom combo box control.
ComboViewer viewer;
Object selectedValue;
* Default ComboBoxCellEditor style
private static final int defaultStyle = SWT.NONE;
* Creates a new cell editor with a combo viewer and a default style
* @param parent
* the parent control
public ComboBoxViewerCellEditor(Composite parent) {
this(parent, defaultStyle);
* Creates a new cell editor with a combo viewer and the given style
* @param parent
* @param style
* the style bits
public ComboBoxViewerCellEditor(Composite parent, int style) {
super(parent, style);
setValueValid(true);
* (non-Javadoc) Method declared on CellEditor.
protected Control createControl(Composite parent) {
CCombo comboBox = new CCombo(parent, getStyle());
comboBox.setFont(parent.getFont());
viewer = new ComboViewer(comboBox);
comboBox.addKeyListener(new KeyAdapter() {
// hook key pressed - see PR 14201
public void keyPressed(KeyEvent e) {
keyReleaseOccured(e);
comboBox.addSelectionListener(new SelectionAdapter() {
public void widgetDefaultSelected(SelectionEvent event) {
applyEditorValueAndDeactivate();
public void widgetSelected(SelectionEvent event) {
ISelection selection = viewer.getSelection();
if (selection.isEmpty()) {
selectedValue = null;
} else {
selectedValue = ((IStructuredSelection) selection)
.getFirstElement();
comboBox.addTraverseListener(new TraverseListener() {
public void keyTraversed(TraverseEvent e) {
if (e.detail == SWT.TRAVERSE_ESCAPE
|| e.detail == SWT.TRAVERSE_RETURN) {
e.doit = false;
comboBox.addFocusListener(new FocusAdapter() {
public void focusLost(FocusEvent e) {
ComboBoxViewerCellEditor.this.focusLost();
return comboBox;
* The <code>ComboBoxCellEditor</code> implementation of this
* <code>CellEditor</code> framework method returns the zero-based index
* of the current selection.
* @return the zero-based index of the current selection wrapped as an
* <code>Integer</code>
protected Object doGetValue() {
return selectedValue;
protected void doSetFocus() {
viewer.getControl().setFocus();
* <code>CellEditor</code> framework method sets the minimum width of the
* cell. The minimum width is 10 characters if <code>comboBox</code> is
* not <code>null</code> or <code>disposed</code> eles it is 60 pixels
* to make sure the arrow button and some text is visible. The list of
* CCombo will be wide enough to show its longest item.
public LayoutData getLayoutData() {
LayoutData layoutData = super.getLayoutData();
if ((viewer.getControl() == null) || viewer.getControl().isDisposed()) {
layoutData.minimumWidth = 60;
} else {
// make the comboBox 10 characters wide
GC gc = new GC(viewer.getControl());
layoutData.minimumWidth = (gc.getFontMetrics()
.getAverageCharWidth() * 10) + 10;
gc.dispose();
return layoutData;
* Set a new value
* @param value
* the new value
protected void doSetValue(Object value) {
Assert.isTrue(viewer != null);
viewer.setSelection(new StructuredSelection(value));
* @param labelProvider
* the label provider used
* @see StructuredViewer#setLabelProvider(IBaseLabelProvider)
public void setLabelProvider(IBaseLabelProvider labelProvider) {
viewer.setLabelProvider(labelProvider);
* @param provider
* the content provider used
* @see StructuredViewer#setContentProvider(IContentProvider)
public void setContenProvider(IStructuredContentProvider provider) {
viewer.setContentProvider(provider);
* @param input
* the input used
* @see StructuredViewer#setInput(Object)
public void setInput(Object input) {
viewer.setInput(input);
* @return get the viewer
public ComboViewer getViewer() {
return viewer;
* Applies the currently selected value and deactiavates the cell editor
void applyEditorValueAndDeactivate() {
// must set the selection before getting value
} else {
.getFirstElement();
Object newValue = doGetValue();
markDirty();
boolean isValid = isCorrect(newValue);
setValueValid(isValid);
if (!isValid) {
MessageFormat.format(getErrorMessage(),
new Object[] { selectedValue });
fireApplyEditorValue();
deactivate();
* (non-Javadoc)
* @see org.eclipse.jface.viewers.CellEditor#focusLost()
protected void focusLost() {
if (isActivated()) {
* (non-Javadoc)
* @see org.eclipse.jface.viewers.CellEditor#keyReleaseOccured(org.e clipse.swt.events.KeyEvent)
protected void keyReleaseOccured(KeyEvent keyEvent) {
if (keyEvent.character == '\u001b') { // Escape character
fireCancelEditor();
} else if (keyEvent.character == '\t') { // tab key
name="ComboViewerCellEditorDemo.java"
filename="ComboViewerCellEditorDemo.java"
aW1wb3J0IGphdmEudXRpbC5BcnJheUxpc3Q7DQppbXBvcnQgamF2YS51dGls Lkxpc3Q7DQoN
CmltcG9ydCBvcmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJzLkNlbGxFZGl0b3I7 DQppbXBvcnQg
b3JnLmVjbGlwc2UuamZhY2Uudmlld2Vycy5JQ2VsbE1vZGlmaWVyOw0KaW1w b3J0IG9yZy5l
Y2xpcHNlLmpmYWNlLnZpZXdlcnMuSUxhYmVsUHJvdmlkZXI7DQppbXBvcnQg b3JnLmVjbGlw
c2UuamZhY2Uudmlld2Vycy5JTGFiZWxQcm92aWRlckxpc3RlbmVyOw0KaW1w b3J0IG9yZy5l
Y2xpcHNlLmpmYWNlLnZpZXdlcnMuSVN0cnVjdHVyZWRDb250ZW50UHJvdmlk ZXI7DQppbXBv
cnQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vycy5JVGFibGVMYWJlbFByb3Zp ZGVyOw0KaW1w
b3J0IG9yZy5lY2xpcHNlLmpmYWNlLnZpZXdlcnMuTGFiZWxQcm92aWRlcjsN CmltcG9ydCBv
cmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJzLlRhYmxlVmlld2VyOw0KaW1wb3J0 IG9yZy5lY2xp
cHNlLmpmYWNlLnZpZXdlcnMuVGV4dENlbGxFZGl0b3I7DQppbXBvcnQgb3Jn LmVjbGlwc2Uu
amZhY2Uudmlld2Vycy5WaWV3ZXI7DQppbXBvcnQgb3JnLmVjbGlwc2Uuc3d0 LlNXVDsNCmlt
cG9ydCBvcmcuZWNsaXBzZS5zd3QuZ3JhcGhpY3MuSW1hZ2U7DQppbXBvcnQg b3JnLmVjbGlw
c2Uuc3d0LmxheW91dC5GaWxsTGF5b3V0Ow0KaW1wb3J0IG9yZy5lY2xpcHNl LnN3dC53aWRn
ZXRzLkRpc3BsYXk7DQppbXBvcnQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMu U2hlbGw7DQpp
bXBvcnQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuVGFibGU7DQppbXBvcnQg b3JnLmVjbGlw
c2Uuc3d0LndpZGdldHMuVGFibGVDb2x1bW47DQoNCnB1YmxpYyBjbGFzcyBD b21ib1ZpZXdl
ckNlbGxFZGl0b3JEZW1vIHsNCg0KCXB1YmxpYyBzdGF0aWMgdm9pZCBtYWlu KFN0cmluZ1td
IGFyZ3MpIHsNCgkJRGlzcGxheSBkaXNwbGF5ID0gbmV3IERpc3BsYXkoKTsN CgkJU2hlbGwg
c2hlbGwgPSBuZXcgU2hlbGwoZGlzcGxheSk7DQoJCXNoZWxsLnNldExheW91 dChuZXcgRmls
bExheW91dCgpKTsNCg0KCQlUYWJsZSB0YWJsZSA9IG5ldyBUYWJsZShzaGVs bCwgU1dULlNJ
TkdMRSB8IFNXVC5CT1JERVIgfCBTV1QuSF9TQ1JPTEwgfCBTV1QuVl9TQ1JP TEwgfCBTV1Qu
RlVMTF9TRUxFQ1RJT04gfCBTV1QuSElERV9TRUxFQ1RJT04pOw0KCQl0YWJs ZS5zZXRIZWFk
ZXJWaXNpYmxlKHRydWUpOw0KCQl0YWJsZS5zZXRMaW5lc1Zpc2libGUodHJ1 ZSk7DQoNCgkJ
VGFibGVDb2x1bW4gdGMgPSBuZXcgVGFibGVDb2x1bW4odGFibGUsIFNXVC5O T05FKTsNCgkJ
dGMuc2V0VGV4dCgiZmlyc3QiKTsNCgkJdGMucGFjaygpOw0KDQoJCVRhYmxl Q29sdW1uIHRj
MiA9IG5ldyBUYWJsZUNvbHVtbih0YWJsZSwgU1dULk5PTkUpOw0KCQl0YzIu c2V0VGV4dCgi
c2Vjb25kIik7DQoJCXRjMi5wYWNrKCk7DQoNCgkJVGFibGVWaWV3ZXIgdHYg PSBuZXcgVGFi
bGVWaWV3ZXIodGFibGUpOw0KCQl0di5zZXRDb250ZW50UHJvdmlkZXIobmV3 IElTdHJ1Y3R1
cmVkQ29udGVudFByb3ZpZGVyKCkgew0KDQoJCQlwdWJsaWMgdm9pZCBpbnB1 dENoYW5nZWQo
Vmlld2VyIHZpZXdlciwgT2JqZWN0IG9sZElucHV0LCBPYmplY3QgbmV3SW5w dXQpIHsNCgkJ
CQkvLyBUT0RPIEF1dG8tZ2VuZXJhdGVkIG1ldGhvZCBzdHViDQoNCgkJCX0N Cg0KCQkJcHVi
bGljIHZvaWQgZGlzcG9zZSgpIHsNCgkJCQkvLyBUT0RPIEF1dG8tZ2VuZXJh dGVkIG1ldGhv
ZCBzdHViDQoNCgkJCX0NCg0KCQkJcHVibGljIE9iamVjdFtdIGdldEVsZW1l bnRzKE9iamVj
dCBpbnB1dEVsZW1lbnQpIHsNCgkJCQlyZXR1cm4gKChMaXN0KSBpbnB1dEVs ZW1lbnQpLnRv
QXJyYXkoKTsNCgkJCX0NCg0KCQl9KTsNCgkJdHYuc2V0TGFiZWxQcm92aWRl cihuZXcgSVRh
YmxlTGFiZWxQcm92aWRlcigpIHsNCgkJDQoJCQlwdWJsaWMgdm9pZCByZW1v dmVMaXN0ZW5l
cihJTGFiZWxQcm92aWRlckxpc3RlbmVyIGxpc3RlbmVyKSB7DQoJCQkJLy8g VE9ETyBBdXRv
LWdlbmVyYXRlZCBtZXRob2Qgc3R1Yg0KCQkNCgkJCX0NCgkJDQoJCQlwdWJs aWMgYm9vbGVh
biBpc0xhYmVsUHJvcGVydHkoT2JqZWN0IGVsZW1lbnQsIFN0cmluZyBhUHJv cGVydHkpIHsN
CgkJCQkvLyBUT0RPIEF1dG8tZ2VuZXJhdGVkIG1ldGhvZCBzdHViDQoJCQkJ cmV0dXJuIGZh
bHNlOw0KCQkJfQ0KCQkNCgkJCXB1YmxpYyB2b2lkIGRpc3Bvc2UoKSB7DQoJ CQkJLy8gVE9E
TyBBdXRvLWdlbmVyYXRlZCBtZXRob2Qgc3R1Yg0KCQkNCgkJCX0NCgkJDQoJ CQlwdWJsaWMg
dm9pZCBhZGRMaXN0ZW5lcihJTGFiZWxQcm92aWRlckxpc3RlbmVyIGxpc3Rl bmVyKSB7DQoJ
CQkJLy8gVE9ETyBBdXRvLWdlbmVyYXRlZCBtZXRob2Qgc3R1Yg0KCQkNCgkJ CX0NCgkJDQoJ
CQlwdWJsaWMgU3RyaW5nIGdldENvbHVtblRleHQoT2JqZWN0IGVsZW1lbnQs IGludCBhQ29s
dW1uSW5kZXgpIHsNCgkJCQkvLyBUT0RPIEF1dG8tZ2VuZXJhdGVkIG1ldGhv ZCBzdHViDQoJ
CQkJcmV0dXJuIGVsZW1lbnQudG9TdHJpbmcoKTsNCgkJCX0NCgkJDQoJCQlw dWJsaWMgSW1h
Z2UgZ2V0Q29sdW1uSW1hZ2UoT2JqZWN0IGVsZW1lbnQsIGludCBhQ29sdW1u SW5kZXgpIHsN
CgkJCQkvLyBUT0RPIEF1dG8tZ2VuZXJhdGVkIG1ldGhvZCBzdHViDQoJCQkJ cmV0dXJuIG51
bGw7DQoJCQl9DQoJCQ0KCQl9KTsNCgkJdHYuc2V0Q29sdW1uUHJvcGVydGll cyhuZXcgU3Ry
aW5nW10geyAiZmlyc3QiLCAic2Vjb25kIiB9KTsNCgkJQ2VsbEVkaXRvcltd IGNlbGxFZGl0
b3JzID0gbmV3IENlbGxFZGl0b3JbMl07DQoJCWNlbGxFZGl0b3JzWzBdID0g bmV3IFRleHRD
ZWxsRWRpdG9yKHRhYmxlKTsNCg0KCQlDb21ib0JveFZpZXdlckNlbGxFZGl0 b3IgY3YgPSBu
ZXcgQ29tYm9Cb3hWaWV3ZXJDZWxsRWRpdG9yKHRhYmxlKTsNCgkJY3Yuc2V0 Q29udGVuUHJv
dmlkZXIobmV3IElTdHJ1Y3R1cmVkQ29udGVudFByb3ZpZGVyKCkgew0KDQoJ CQlwdWJsaWMg
dm9pZCBpbnB1dENoYW5nZWQoVmlld2VyIHZpZXdlciwgT2JqZWN0IG9sZElu cHV0LCBPYmpl
Y3QgbmV3SW5wdXQpIHsNCgkJCQkvLyBUT0RPIEF1dG8tZ2VuZXJhdGVkIG1l dGhvZCBzdHVi
DQoNCgkJCX0NCg0KCQkJcHVibGljIHZvaWQgZGlzcG9zZSgpIHsNCgkJCQkv LyBUT0RPIEF1
dG8tZ2VuZXJhdGVkIG1ldGhvZCBzdHViDQoNCgkJCX0NCg0KCQkJcHVibGlj IE9iamVjdFtd
IGdldEVsZW1lbnRzKE9iamVjdCBpbnB1dEVsZW1lbnQpIHsNCgkJCQlyZXR1 cm4gKChMaXN0
KSBpbnB1dEVsZW1lbnQpLnRvQXJyYXkoKTsNCgkJCX0NCg0KCQl9KTsNCgkJ Y3Yuc2V0TGFi
ZWxQcm92aWRlcihuZXcgSUxhYmVsUHJvdmlkZXIoKSB7DQoJCQ0KCQkJcHVi bGljIHZvaWQg
cmVtb3ZlTGlzdGVuZXIoSUxhYmVsUHJvdmlkZXJMaXN0ZW5lciBsaXN0ZW5l cikgew0KCQkJ
CS8vIFRPRE8gQXV0by1nZW5lcmF0ZWQgbWV0aG9kIHN0dWINCgkJDQoJCQl9 DQoJCQ0KCQkJ
cHVibGljIGJvb2xlYW4gaXNMYWJlbFByb3BlcnR5KE9iamVjdCBlbGVtZW50 LCBTdHJpbmcg
YVByb3BlcnR5KSB7DQoJCQkJLy8gVE9ETyBBdXRvLWdlbmVyYXRlZCBtZXRo b2Qgc3R1Yg0K
CQkJCXJldHVybiBmYWxzZTsNCgkJCX0NCgkJDQoJCQlwdWJsaWMgdm9pZCBk aXNwb3NlKCkg
ew0KCQkJCS8vIFRPRE8gQXV0by1nZW5lcmF0ZWQgbWV0aG9kIHN0dWINCgkJ DQoJCQl9DQoJ
CQ0KCQkJcHVibGljIHZvaWQgYWRkTGlzdGVuZXIoSUxhYmVsUHJvdmlkZXJM aXN0ZW5lciBs
aXN0ZW5lcikgew0KCQkJCS8vIFRPRE8gQXV0by1nZW5lcmF0ZWQgbWV0aG9k IHN0dWINCgkJ
DQoJCQl9DQoJCQ0KCQkJcHVibGljIFN0cmluZyBnZXRUZXh0KE9iamVjdCBl bGVtZW50KSB7
DQoJCQkJLy8gVE9ETyBBdXRvLWdlbmVyYXRlZCBtZXRob2Qgc3R1Yg0KCQkJ CXJldHVybiBl
bGVtZW50LnRvU3RyaW5nKCk7DQoJCQl9DQoJCQ0KCQkJcHVibGljIEltYWdl IGdldEltYWdl
KE9iamVjdCBlbGVtZW50KSB7DQoJCQkJLy8gVE9ETyBBdXRvLWdlbmVyYXRl ZCBtZXRob2Qg
c3R1Yg0KCQkJCXJldHVybiBudWxsOw0KCQkJfQ0KCQkNCgkJfSk7DQoJCUxp c3QgY29tYm9J
bnB1dCA9IG5ldyBBcnJheUxpc3QoKTsNCgkJY29tYm9JbnB1dC5hZGQoImNv bWJvVmFsdWUx
Iik7DQoJCWNvbWJvSW5wdXQuYWRkKCJjb21ib1ZhbHVlMiIpOw0KCQljb21i b0lucHV0LmFk
ZCgiY29tYm9WYWx1ZTMiKTsNCgkJY3Yuc2V0SW5wdXQoY29tYm9JbnB1dCk7 DQoJCQ0KCQlj
ZWxsRWRpdG9yc1sxXSA9IGN2Ow0KDQoJCXR2LnNldENlbGxFZGl0b3JzKGNl bGxFZGl0b3Jz
KTsNCg0KCQl0di5zZXRDZWxsTW9kaWZpZXIobmV3IElDZWxsTW9kaWZpZXIo KSB7DQoNCgkJ
CXB1YmxpYyB2b2lkIG1vZGlmeShPYmplY3QgZWxlbWVudCwgU3RyaW5nIHBy b3BlcnR5LCBP
YmplY3QgdmFsdWUpIHsNCgkJCQkvLyBUT0RPIEF1dG8tZ2VuZXJhdGVkIG1l dGhvZCBzdHVi
DQoNCgkJCX0NCg0KCQkJcHVibGljIE9iamVjdCBnZXRWYWx1ZShPYmplY3Qg ZWxlbWVudCwg
U3RyaW5nIHByb3BlcnR5KSB7DQoJCQkJLy8gVE9ETyBBdXRvLWdlbmVyYXRl ZCBtZXRob2Qg
c3R1Yg0KCQkJCXJldHVybiBlbGVtZW50LnRvU3RyaW5nKCk7DQoJCQl9DQoN CgkJCXB1Ymxp
YyBib29sZWFuIGNhbk1vZGlmeShPYmplY3QgZWxlbWVudCwgU3RyaW5nIHBy b3BlcnR5KSB7
DQoJCQkJLy8gVE9ETyBBdXRvLWdlbmVyYXRlZCBtZXRob2Qgc3R1Yg0KCQkJ CXJldHVybiB0
cnVlOw0KCQkJfQ0KDQoJCX0pOw0KDQoJCUxpc3QgaW5wdXQgPSBuZXcgQXJy YXlMaXN0KCk7
DQoJCWlucHV0LmFkZCgidmFsdWUxIik7DQoJCWlucHV0LmFkZCgidmFsdWUy Iik7DQoJCWlu
cHV0LmFkZCgidmFsdWUzIik7DQoJCWlucHV0LmFkZCgidmFsdWU0Iik7DQoJ CWlucHV0LmFk
ZCgidmFsdWU1Iik7DQoJCWlucHV0LmFkZCgidmFsdWU2Iik7DQoJCWlucHV0 LmFkZCgidmFs
dWU3Iik7DQoJCXR2LnNldElucHV0KGlucHV0KTsNCg0KCQlzaGVsbC5wYWNr KCk7DQoJCXNo
ZWxsLm9wZW4oKTsNCgkJd2hpbGUgKCFzaGVsbC5pc0Rpc3Bvc2VkKCkpIHsN CgkJCWlmICgh
ZGlzcGxheS5yZWFkQW5kRGlzcGF0Y2goKSkNCgkJCQlkaXNwbGF5LnNsZWVw KCk7DQoJCX0N
CgkJZGlzcGxheS5kaXNwb3NlKCk7DQoJfQ0KfQ==
--------------090602080804090700080402--
| Re: Is it advisable to subclass ComboBoxCellEditor? [message #315407 is a reply to message #315397] |
Wed, 09 May 2007 11:43   |
--------------050206040002080206060509
For me this works like a charme although I had to modify your snippet a
bit to select the correct values. What version of eclipse are you
running? To make this work you need 3.3-stream because before the
ComboViewer could not deal with CCombo and that might be your problem.
I attach you the modified fully working example. I'll also add it to the
bug so we can later create a snippet from this for our collection
( http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/)
Tom
Content-Type: text/plain; x-mac-type="0"; x-mac-creator="0";
import java.util.ArrayList;
import java.util.List;
import org.eclipse.jface.viewers.ICellModifier;
import org.eclipse.jface.viewers.ILabelProvider;
import org.eclipse.jface.viewers.ILabelProviderListener;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
public class ComboViewerCellEditorDemo {
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
Table table = new Table(shell, SWT.SINGLE | SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL | SWT.FULL_SELECTION | SWT.HIDE_SELECTION);
table.setHeaderVisible(true);
table.setLinesVisible(true);
TableColumn tc = new TableColumn(table, SWT.NONE);
tc.setText("first");
tc.pack();
TableColumn tc2 = new TableColumn(table, SWT.NONE);
tc2.setText("second");
tc2.pack();
final TableViewer tv = new TableViewer(table);
tv.setContentProvider(new IStructuredContentProvider() {
public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
public void dispose() {
public Object[] getElements(Object inputElement) {
return ((List) inputElement).toArray();
tv.setLabelProvider(new ITableLabelProvider() {
public void removeListener(ILabelProviderListener listener) {
public boolean isLabelProperty(Object element, String aProperty) {
return false;
public void addListener(ILabelProviderListener listener) {
public String getColumnText(Object element, int aColumnIndex) {
if( aColumnIndex == 0 ) {
return "Item " + ((ModelObject)element).i;
} else {
return ((ModelObject)element).value.toString();
public Image getColumnImage(Object element, int aColumnIndex) {
return null;
tv.setColumnProperties(new String[] { "first", "second" });
CellEditor[] cellEditors = new CellEditor[2];
cellEditors[0] = new TextCellEditor(table);
ComboBoxViewerCellEditor cv = new ComboBoxViewerCellEditor(table);
cv.setContenProvider(new IStructuredContentProvider() {
// TODO Auto-generated method stub
cv.setLabelProvider(new LabelProvider() {
public String getText(Object element) {
return element.toString();
List comboInput = new ArrayList();
comboInput.add(new DDElement(1));
comboInput.add(new DDElement(2));
comboInput.add(new DDElement(3));
cv.setInput(comboInput);
cellEditors[1] = cv;
tv.setCellEditors(cellEditors);
tv.setCellModifier(new ICellModifier() {
public void modify(Object element, String property, Object value) {
ModelObject modelObject = (ModelObject) ((TableItem)element).getData();
if( property.equals("first") ) {
modelObject.i = Integer.parseInt(value.toString());
} else {
modelObject.value = (DDElement) value;
tv.update(modelObject, null);
public Object getValue(Object element, String property) {
return ((ModelObject)element).i+"";
return ((ModelObject)element).value;
public boolean canModify(Object element, String property) {
return true;
List input = new ArrayList();
input.add(new ModelObject(1,(DDElement) comboInput.get(0)));
input.add(new ModelObject(2,(DDElement) comboInput.get(1)));
input.add(new ModelObject(3,(DDElement) comboInput.get(2)));
input.add(new ModelObject(4,(DDElement) comboInput.get(0)));
input.add(new ModelObject(5,(DDElement) comboInput.get(1)));
input.add(new ModelObject(6,(DDElement) comboInput.get(2)));
input.add(new ModelObject(7,(DDElement) comboInput.get(0)));
input.add(new ModelObject(8,(DDElement) comboInput.get(1)));
tv.setInput(input);
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
private static class DDElement {
private int value;
public DDElement(int value) {
this.value = value;
public String toString() {
return "Combo-"+value;
private static class ModelObject {
private int i = 0;
private DDElement value;
public ModelObject(int i, DDElement value) {
this.i = i;
this.value = value;
--------------050206040002080206060509--
| Re: Is it advisable to subclass ComboBoxCellEditor? [message #315458 is a reply to message #315456] |
Thu, 10 May 2007 07:07  |
Your problem is that 3.2.2 ComboViewer can't deal with CCombo and the
bad thing is that it doesn't event produce an Compiletime-Exception
because the ComboViewer(Composite) is the constructor called in this case.
Any easy work-around would be to copy the ComboViewer from 3.3 into your
3.3 project because it doesn't contain any code not compatible with
eclipse 3.2 and then your are done.
Tom
inliner683 schrieb:
> I am actually working on 3.2.2! I tested it on 3.3 and it works with no
> modification! Didn't think of that.
> As I need to be compliant to 3.2.2 I implemented a custom
> ComboBoxCellEditor dealing with a simple key-value map, and it works fine.
> If you use Combo instead CCombo in the Demo, the ComboViewer works as
> well on 3.2.2 but doesn't look well in a table...
> So thanks for your help!
>> Hi,
>> a bit to select the correct values. What version of eclipse are you
>> the bug so we can later create a snippet from this for our collection
>> Tom
Current Time: Fri Nov 07 22:06:02 EST 2025
Powered by FUDForum. Page generated in 0.03477 seconds
