Home » Archived » EPF » Activity Diagram
Activity Diagram [message #31535] |
Fri, 13 April 2007 03:16  |
Originally posted by: jean-noel.guyot.tectosages.com
I'm using the Activity Diagram, and I was wondering how to see links
that connect a Phase with a Task (or something not at the same level)?
Someone could show me how to do it?
Thanks.
Jean-Noel Guyot
Tectosages
Re: Activity Diagram [message #31847 is a reply to message #31777] |
Thu, 26 April 2007 17:30   |
My understanding of Activity diagramming is that you can use the
synchronization bars to achieve this. You are also able to nest
synchronization bars and activities within other synchronization bars. The
net effect is identical to what you would see on a Gantt chart. It caters
for all cases of S2S, S2F, F2F, etc.
I suppose the assumption is that any parallel activities between two
synchronization bars are totally independent, but by using nested
synchronization you can manage quite adequately.
Or am I missing something? :-)
regards Charles
"Peter Haumer" <phaumer@us.ibm.com> wrote in message
news:f0irsu$avh$1@build.eclipse.org...
> That is a great question that I am researching for a while now. The only
> semantical mapping that fits at least a little bit between wbs
> dependencies and control flow amongst activities is the Finish-Start
> dependency. The other three really have quite different semantics and need
> to be modeled differently in UML. It is actually strange that neither
> UML2 nor BPMN talk about these at all as they are so popular in the
> project management world. The closest we came on this was the diagram I go
> from a SPEM2 contributor that modeled this using events. If you know of
> any literature source that maps these elements against each other, please
> let me know. I would like to get this right in the future. Currently, we
> a ignoring these types for the diagrams, really. We did this by following
> the "principle of the least surprise" as not creating control flow for
> these other types could have been more confusing. It would be more correct
> to only show control flow amongst Finish-Start, though, but again this
> needs more research. Community, please help.
> Peter.
> "Jean-Noel Guyot" <jean-noel.guyot@tectosages.com> wrote in message
> news:f01ndj$b18$1@build.eclipse.org...
>> Thanks.
>> Do you know how to make the difference beetween links with ptoperties
>> FinishToStart and FinishToFinish (or other) on the diagram ?
>> If one can define this option so there is a way to distinguish it ...
>> Jean-Noel Guyot
>> Tectosages
>> Peter Haumer a
Re: Activity Diagram [message #32024 is a reply to message #31777] |
Thu, 03 May 2007 05:59   |
You can find at the following address
(http://www.eclipse.org/m2m/atl/usecases/SimplePDL2Tina/) a translation
from SimplePDL (an enactment dedicated SPEM2 subset) to Petri nets
(thus, give a clear and formal execution semantics from a translational
one) which takes into account of each type of WorkSequence (S2F, F2S,
F2F, ...).
I also agree with Charles Edwards on using the synchronization bars to
manage it.
Jean-Noel Guyot
Tectosages
> semantical mapping that fits at least a little bit between wbs dependencies
> and control flow amongst activities is the Finish-Start dependency. The
> other three really have quite different semantics and need to be modeled
> differently in UML. It is actually strange that neither UML2 nor BPMN talk
> about these at all as they are so popular in the project management world.
> The closest we came on this was the diagram I go from a SPEM2 contributor
> that modeled this using events. If you know of any literature source that
> maps these elements against each other, please let me know. I would like to
> get this right in the future. Currently, we a ignoring these types for the
> diagrams, really. We did this by following the "principle of the least
> surprise" as not creating control flow for these other types could have been
> more confusing. It would be more correct to only show control flow amongst
> Finish-Start, though, but again this needs more research. Community, please
> help.
> Peter.
>> Thanks.
>> Jean-Noel Guyot
>> Tectosages
>>> Hello Jean.
>>> That is currently not possible. You can only show elements from the same
>>> level of breakdown.
>>> Best regards,
>>> Peter.
>>> news:evnarg$rgr$1@build.eclipse.org...
>>>> Hi,
>>>> Thanks.
>>>> Jean-Noel Guyot
>>>> Tectosages
Re: Activity Diagram [message #32164 is a reply to message #32094] |
Mon, 07 May 2007 16:54  |
Hello Charles and Jean-Noel.
Thanks a lot for all the references. Interesting reads. I still not sure
though how to do this with the UML activity meta-model. The first paper
shows this with Petri Nets, but how would you translate it to UML
activities? Do you suggest that we map every UMA Task and Activities into
action combinations with the states NotStarted, Started, InProgress,
Finished? Looks a bit like you are combining state charts with activity
diagrams. Or would you do this with Send Signal Actions? Could you send me
an example how this would looks like in UML2?
I am also not sure I understand the nesting of synchronization bars
approach. To my knowledge of UML this is not possible. As I understand it
you cannot nest Activity Nodes (the superclass of fork and join), only
Activities. Can you send me an example?
The second article seems to be doing what we do: It creates a FS predecessor
for a control flow. The example shows a fork which means that the two
actions in the middle cannot start until the first one finished. The same
with the last one: it cannot start until the two in the middle finish. How
would you model a SS (an action can start when another action starts; i.e.
the start of the action already triggers the control flow without the need
of the action to be completed)? Would you be able to model this with events
without making the diagrams look overly complex?
Peter.
"Charles Edwards" <charles.edwards@processwave.com> wrote in message
news:f1gbpe$t3s$1@build.eclipse.org...
>> manage it.
> Shown here with one simple level of synchronization bars:
> http://www.eclipse.org/m2m/atl/usecases/UML2MsProject/
> regards Charles
> news:f1cbtf$jm8$1@build.eclipse.org...
>> from SimplePDL (an enactment dedicated SPEM2 subset) to Petri nets (thus,
>> give a clear and formal execution semantics from a translational one)
>> which takes into account of each type of WorkSequence (S2F, F2S, F2F,
>> Regards,
>> Jean-Noel Guyot
>> Tectosages
>> Peter Haumer a
Re: Activity Diagram [message #577638 is a reply to message #31535] |
Mon, 16 April 2007 16:17  |
Hello Jean.
level of breakdown.
Peter.
> I'm using the Activity Diagram, and I was wondering how to see links that
> Thanks.
> Jean-Noel Guyot
> Tectosages
Re: Activity Diagram [message #577673 is a reply to message #31602] |
Tue, 17 April 2007 01:51  |
Thanks.
Jean-Noel Guyot
Tectosages
> Hello Jean.
> level of breakdown.
> Best regards,
> Peter.
>> Hi,
>> Thanks.
>> Jean-Noel Guyot
>> Tectosages
Re: Activity Diagram [message #577805 is a reply to message #31635] |
Mon, 23 April 2007 13:54  |
help.
Peter.
> Thanks.
> Jean-Noel Guyot
> Tectosages
> Peter Haumer a
Re: Activity Diagram [message #577851 is a reply to message #31777] |
regards Charles
> Peter.
>> Thanks.
>> Jean-Noel Guyot
>> Tectosages
>> Peter Haumer a
Re: Activity Diagram [message #578053 is a reply to message #31777] |
F2F, ...).
manage it.
Jean-Noel Guyot
Tectosages
> help.
> Peter.
>> Thanks.
>> Jean-Noel Guyot
>> Tectosages
>>> Hello Jean.
>>> level of breakdown.
>>> Best regards,
>>> Peter.
>>>> Hi,
>>>> Thanks.
>>>> Jean-Noel Guyot
>>>> Tectosages
Re: Activity Diagram [message #578132 is a reply to message #32094] |
Peter.
>> manage it.
> regards Charles
>> Regards,
>> Jean-Noel Guyot
>> Tectosages
>> Peter Haumer a
Current Time: Sat Jul 19 03:06:31 EDT 2025
Powered by FUDForum. Page generated in 0.06012 seconds
