Home » Eclipse Projects » Eclipse Platform » CCombo and FormData
CCombo and FormData [message #314844] Wed, 25 April 2007 08:39 Go to next message
Originally posted by: jan_ryba.interia.pl
Hallo,
I tried to create "Tabbed property" with Clabel, button and Ccombo object. I
have created this object:
Composite composite = getWidgetFactory().createFlatFormComposite(parent);
CLabel fitnessFunctionLabel =
getWidgetFactory().createCLabel(composite, "aaa");
CCombo fitnessFunctionCombo = getWidgetFactory().createCCombo(parent);
Button changeButton = getWidgetFactory().createButton(composite,
"bbb", SWT.PUSH);
and after that I try to configure their positions. Everything is OK except:
data = new FormData();
data.left = new FormAttachment(0, 150);
fitnessFunctionCombo.setLayoutData(data);
I hava an exception:
ava.lang.ClassCastException: org.eclipse.swt.layout.FormData cannot be cast
to org.eclipse.swt.layout.FillData
Can I use formData to Ccombo or should I use somethig else?
regards
Janusz
Re: CCombo and FormData [message #314855 is a reply to message #314844] Wed, 25 April 2007 10:41 Go to previous messageGo to next message
Hi Janusz,
It looks like createFlatFormComposite() is giving you a Composite whose
layout is not pre-set to FormLayout (either it's pre-set to FillLayout, or
there is no layout pre-set on it and FillLayout is set on some other control
higher in the widget hierarchy). I don't think you can assume that
createFlatFormComposite() returns a Composite whose layout is pre-set to
FormLayout.
Grant
"Janusz" <jan_ryba@interia.pl> wrote in message
news:f0ni24$3o0$1@build.eclipse.org...
> Hallo,
I
> "bbb", SWT.PUSH);
except:
cast
> regards
> Janusz
Re: CCombo and FormData [message #314868 is a reply to message #314855] Wed, 25 April 2007 17:21 Go to previous message
Hi Grant,
Thank's. Now it is working. I used example from "The Eclipse Tabbed
Properties View" article and there was everything OK (without Ccombo)
Janusz
> Hi Janusz,
> control
> FormLayout.
> Grant
>> Hallo,
>> object.
> I
>> "bbb", SWT.PUSH);
> except:
> cast
>> regards
>> Janusz
Previous Topic:PatternRule with startSequence '\n'
Next Topic:Bug with the remote debugger ?
Current Time: Mon Nov 10 02:42:44 EST 2025
Powered by FUDForum. Page generated in 0.04352 seconds
