Home » Eclipse Projects » Eclipse Platform » Extension points: get attributes info from definition
Extension points: get attributes info from definition [message #314514] Mon, 16 April 2007 11:35 Go to next message
Originally posted by: deam_38.yahoo.fr
If I define an extension point like this (Extension Point Creation Wizard):
- extension
'----- sequence
' '-----myPoint (1-*)
'----- point
'----- id
'----- name
- myPoint
'----- id (type = string)
'----- class (type = java)
'----- icon (type = resource)
'----- info (type = string)
If class is the user defined class (name) which extends an abstract class
(MyClass) that I defined.
I would like to know how can I get the informations entered by the user of
my extension point (id, icon, info) from the source code of the abstract
class (MyClass).
Thank you for any help.
And if you have links to any interresting documents about extension
points...
Re: Extension points: get attributes info from definition [message #314584 is a reply to message #314514] Wed, 18 April 2007 05:39 Go to previous messageGo to next message
deam wrote:
> - extension
> '----- sequence
> '----- point
> '----- id
> '----- name
> - myPoint
> class (MyClass).
> points...
I did find a way to answer to my problem but it musn't be THE good way
since I use internal / deprecated methods. I've added the following piece
of code in the start() method of my plugin Activator.
IExtensionPoint[] extensionPoints = getDescriptor().getExtensionPoints();
ViewRegistry viewRegistry =
(ViewRegistry)getWorkbench().getViewRegistry();
for(IExtensionPoint extensionPoint : extensionPoints){
IConfigurationElement[] configurationElements =
extensionPoint.getConfigurationElements();
for(int i=0; i<configurationElements.length; i++){
String[] attributeNames = configurationElements[i].getAttributeNames();
String class = configurationElements[i].getAttribute("class");
String icon = configurationElements[i].getAttribute("icon");
String info = configurationElements[i].getAttribute("info");
After that, the 3 variables (class, icon, info) have the value that the
user which implements my extension point did enter in its plugin.xml file
Re: Extension points: get attributes info from definition [message #314648 is a reply to message #314584] Thu, 19 April 2007 03:14 Go to previous message
deam wrote:
> deam wrote:
>> Hi,
>> - extension
>> '----- sequence
>> '----- point
>> '----- id
>> '----- name
>> - myPoint
>> class (MyClass).
>> points...
The following article explains just what I was looking for :
http://www.eclipse.org/articles/Article-Plug-in-architecture /plugin_architecture.html
esspecialy in the following section:
3.1. Obtaining References to the Extensions of an Extension-Point
Previous Topic:Team Synchronize Resource Filtering
Next Topic:Hiding certain portions of text
Current Time: Sat Jul 19 16:36:10 EDT 2025
Powered by FUDForum. Page generated in 0.23850 seconds
