Home » Eclipse Projects » Eclipse Platform » File Handlers with White Space
File Handlers with White Space [message #313918] Wed, 28 March 2007 04:34 Go to next message
Hallo,
My SWT File Browser returns me the file handlers for the selected files. But
i am not able to make a write access to the files that have empty spaces in
the file path.
For example.
f:\New Folder\foo.txt is not accessible. I am aware of the unicodes being
used in the file path. Is there a work around for this issue.
with regards,
Madanagopal.
Re: File Handlers with White Space [message #313924 is a reply to message #313918] Wed, 28 March 2007 06:33 Go to previous messageGo to next message
Madanagopal,
Are you talking about org.eclipse.swt.widgets.FileDialog? What
specifically are you trying to do that doesn't seem to be working?
(More detail in the question usually results in better detail in the
answer.)
Madanagopal wrote:
> Hallo,
> the file path.
> For example.
> with regards,
> Madanagopal.
Re: File Handlers with White Space [message #313927 is a reply to message #313924] Wed, 28 March 2007 08:53 Go to previous message
I was mentioning about the swt File Dialog. I have managed to find a
solution. With the File handler i get from this dialog, i can decode this
handler using URLDecoder.decode(). With this i am able to handle the decoded
handler that previously had the white spaces which are represented with
Unicodes.
Thanks Ed.
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag
news:eudga0$g1k$1@utils.eclipse.org...
> Madanagopal,
> specifically are you trying to do that doesn't seem to be working? (More
> detail in the question usually results in better detail in the answer.)
> Madanagopal wrote:
>> Hallo,
>> But
>> in
>> the file path.
>> For example.
>> with regards,
>> Madanagopal.
Previous Topic:Project and ActionSets
Next Topic:Eclipse Project Caching Help
Current Time: Tue Jul 22 23:57:50 EDT 2025
Powered by FUDForum. Page generated in 0.25385 seconds
