Re: OCL plugin [message #31369] |
Fri, 29 June 2007 07:56  |
--------------000207010508010302060205
Marina,
You'd be best to use the OCL newsgroup, which I've added to the "to"
list of this reply.
The org.eclipse.ui.ide should come installed in Eclipse itself and
org.eclipse.emf.ecore should come from the appropriate EMF install.
What versions numbers of these are you trying to install and in which
version of Eclipse? The GA versions of all these will be available
today (in maybe an hour or so). I assume you have a 5.0 JVM, because
EMF 2.3 won't work without that. And I assume you've run eclipse.exe
-clean if you are installing by unzipping the zipped distributions.
Using the Europa update site when it goes live with the GA versions
shortly is probably easiest:
<http://www.eclipse.org/europa/>
Marina wrote:
> Hello to everybody!
> My problem is that I want to get the OCL eclipse plugin working, I
> have tried the three last versions of emf sdk to get it installed and
> I always receive an error message of one of these kinds:
> "Configuration problem"
> "Some plugin is missed:"
> org.eclipse.emf.ecore or org.eclipse.ui.ide
> I included the first one but the second one is not findable surfing
> the net.
> Anyway, could someone send all the files I would need for running the
> plugin to me (I only want to test its functionalities!!) and a
> "step-by-step" installation algorithm of what I have to do to be able
> to use the plugin?
> As I said, I don't want (by now) to develop anything but to test the
> "goodness" of the OCL tool.
> Thank you very much!!!
> Best Regards!
<html>
<head>
http-equiv="Content-Type">
</head>
Marina,<br>
<br>
list of this reply.<br>
<br>
Re: OCL plugin [message #31452 is a reply to message #31369] |
Fri, 29 June 2007 09:56  |
Hi, Marina, Ed,
The only thing that I can add to Ed's excellent reply is that the
org.eclipse.ui.ide plug-in is included in the Eclipse *SDK* download, not
the Eclipse Platform. The first of the special packages on the
http://www.eclipse.org/downloads/ should have what you need.
Christian
Ed Merks wrote:
> Marina,
> list of this reply.
> Marina wrote:
>> Hello to everybody!
>> the net.
>> to use the plugin?
>> Best Regards!
FUDForum. Page generated in 0.08409 seconds
