Home » Eclipse Projects » Eclipse Platform » leave preference page with invalid values
leave preference page with invalid values [message #313564] Mon, 19 March 2007 11:57 Go to next message
Hi all
I've a preference page and I fill in some invalid value. Then I want to
switch to a second preference page with an implicit 'cancel' of the invalid
value.
Currently, I've to cancel the page explicitly with the button and then
reopen the preference dialog and start again navigating to the page I want
to change.
How is it possible to switch to a second page with implicit cancel?
Martin
Re: leave preference page with invalid values [message #313570 is a reply to message #313564] Mon, 19 March 2007 14:47 Go to previous messageGo to next message
Originally posted by: vb.prismtech.com
The PreferencePage class has a method called
public boolean okToLeave() {
return isValid();
which validates your page when you switch.
Overriding this might help. ie; If the values are invalid, you could clear
them out and return true.
"Martin Skorsky" <Martin.Skorsky@softwareag.com> wrote in message
news:etmbtn$qlh$1@utils.eclipse.org...
> Hi all
> invalid value.
> to change.
> Martin
Re: leave preference page with invalid values [message #313614 is a reply to message #313570] Tue, 20 March 2007 12:56 Go to previous messageGo to next message
My first guess: great, that's exactly what I want. Thanks!
second guess (after debugging and experimenting):
isValid() is called before okToLeave().
And if isValid() returns false, obToLeave() is not called.
Are these methods blocking each other?
AFAIK isValid should be set to false whenever invalid values are detected.
But then I don't have a chance to ignore the invalid values in okToLeave()
and cancel the input.
"Vikram" <vb@prismtech.com> wrote in message
news:etmlrd$s2i$1@utils.eclipse.org...
> return isValid();
>> Hi all
>> invalid value.
>> want to change.
>> Thanks,
>> Martin
Re: leave preference page with invalid values [message #313624 is a reply to message #313614] Tue, 20 March 2007 14:31 Go to previous message
I guess you are right. isValid() does get called before okToLeave();
What if you overrode the isValid() to validate , fix and always return true.
eg
Let's say you had a StringFieldEditor sc.
You would have something like this:
public boolean isValid() {
if( notValid (sc.getStringValue() )
sc.setStringValue(validValue);
return true;
I havent tested this and seems a bit crude :) . If you find something, do
post it.
news:etp3o4$41o$1@utils.eclipse.org...
>> return isValid();
>> clear them out and return true.
>>> Hi all
>>> invalid value.
>>> want to change.
>>> Thanks,
>>> Martin
Previous Topic:[Help Indexing] - Question about Help indxing and 'extradir'
Next Topic:Experimental APIs - CellLabelProvider, ViewerRow, ViewerCell
Current Time: Wed Nov 05 21:07:32 EST 2025
Powered by FUDForum. Page generated in 0.05092 seconds
