Home » Eclipse Projects » Eclipse Platform » Feature uninstall popup menu item is disabled
Feature uninstall popup menu item is disabled [message #313347] Wed, 14 March 2007 02:54 Go to next message
Eclipse 3.2.2
right click on a feaure in Manage Configurations dialog, shows the popup
menu with only Disable, Replace With, Properties enabled. Why is
uninstall item is inactive. any reason ? no errors reported and feature
status from Properties says "This feature is configured properly".
Tried starting Eclipse with -clean option as well.
Anthos
Re: Feature uninstall popup menu item is disabled [message #313369 is a reply to message #313347] Wed, 14 March 2007 11:28 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
Anil T Samuel wrote:
> Hi
> Eclipse 3.2.2
How did you install the feature originally? I think the Unistall
function is only available for plug-ins/features that are installed via
the Update Manager (Software Updates > Find and Install...)
To uninstall manually, you can shut down Eclipse, delete the appropriate
directory(ies) under <eclipse-base>/plugins/ and/or
<eclipse-base>/features/ and the restart Eclipse with -clean.
Hope this helps,
Eric
Re: Feature uninstall popup menu item is disabled [message #313370 is a reply to message #313369] Wed, 14 March 2007 11:30 Go to previous messageGo to next message
>> Hi
>> Eclipse 3.2.2
>> popup menu with only Disable, Replace With, Properties enabled. Why is
>> feature status from Properties says "This feature is configured
>> properly".
Also note that Disabling a feature is just as good as removing it as far
as Eclipse is concerned - Eclipse will not load disabled features and
they take no resources (other than some disk space).
Hope this helps,
Eric
Re: Feature uninstall popup menu item is disabled [message #313440 is a reply to message #313370] Wed, 14 March 2007 19:29 Go to previous message
Thanks Eric; must appreciate your reply.
The feature was manually copied into eclipse/ directory; which is
distributed as zip file; so unzipped to be more precise.
There is still some unexplainable behavior which is sometimes the
feature does not get listed in the Manage Configurations dialog; no
errors reported; even when started with -clean option. I am still
digging to find the reason.
but all works fine if installed using Update Manager.
Anthos
Eric Rizzo wrote:
>>> Hi
>>> Eclipse 3.2.2
>>> is uninstall item is inactive. any reason ? no errors reported and
>>> properly".
>> via the Update Manager (Software Updates > Find and Install...)
>> appropriate directory(ies) under <eclipse-base>/plugins/ and/or
> Hope this helps,
> Eric
Previous Topic:Hover over editor tabs and path on MacOS X
Next Topic:[Databinding] NoClassDefFoundError, missing AbstractTableViewer
Current Time: Sun Jul 27 01:56:08 EDT 2025
Powered by FUDForum. Page generated in 0.05295 seconds
