Export jar file, multiple jar files [message #312735] |
Sun, 18 February 2007 11:46  |
Originally posted by: ilan.tal.gmail.com
A while back I had a question of how to export a jar file.
Then I needed to use a single external jar file which I finally learned to
put in the manifest as:
<code>
Manifest-Version: 1.0
Main-Class: vrp.VRP
Class-Path: or124.jar
</code>
This worked very nicely, but now I want to add on line help.
I have my help in a jar file called VRPHelp.jar and I also need the java
help as jh.jar.
Inside eclipse this all works fine. I imported 3 external jar files:
or124.jar, jh.jar and VRPHelp.jar and when I press the help button, up
comes the help.
Now I want to export it. If I change my manifest to
<code>
Main-Class: vrp.VRP
Class-Path: or124.jar;jh.jar;VRPHelp.jar
</code>
it tells me it can't find the main entry point. If I leave it as it was,
the program never comes up (presumably because it is searching for the
help which it doesn't find).
Thus my question is: how do I put in multiple external jar files?
Ilan
Re: Export jar file, multiple jar files [message #312736 is a reply to message #312735] |
Sun, 18 February 2007 11:56   |
--------------000600060708060500000604
Ilan,
If I add a jar to the MANIFEST.MF using PDE, it formats it like this:
Bundle-ClassPath: .,
extra.jar
So maybe the semicolons aren't the right thing to use...
Ilan
> learned to put in the manifest as:
> <code>
> Main-Class: vrp.VRP
> </code>
> java help as jh.jar.
> comes the help.
> <code>
> Main-Class: vrp.VRP
> </code>
> was, the program never comes up (presumably because it is searching
> for the help which it doesn't find).
> Ilan
<html>
<head>
http-equiv="Content-Type">
</head>
Ilan,<br>
<br>
If I add a jar to the MANIFEST.MF using PDE, it formats it like this:<br>
<blockquote>Bundle-ClassPath: .,<br>
FUDForum. Page generated in 0.03441 seconds
