Home » Eclipse Projects » Eclipse Platform » update syntax coloring in a texteditor
update syntax coloring in a texteditor [message #310612] |
Mon, 11 December 2006 15:45  |
Originally posted by: drojomar.notes.banesto.es
I have a texteditor, with syntax coloring. I have a scanner that scan
the document, and assign a different color depending on the token type.
Besides, I have a preference page that allow users to choose the color
of each token. My problem is after I change a color (in the preference
page), I don't know how to refresh the color in the document.
I have created an IPropertyChangeListener, but I don't know how to scann
the document again in order to change to the new colors.
any ideas?
Re: update syntax coloring in a texteditor [message #310616 is a reply to message #310612] |
Mon, 11 December 2006 17:31   |
> any ideas?
> Thanks
Dave,
Once you get the notification of the preference change, do something
like the below. This way all the editor instances will automatically
change to the color you want.
Now if your editor has colored keywords, then all you have to do is to
change the color to those tokens you assigned in your rules.
Below is just to show you how to change the background and forground
colors when a preference change occurs. The key is to get the
getSourceViewer().
// setBackgroundColor
private void setBackgroundColor()
IPreferenceStore ps =
EditorPlugin.getInstance().getPreferenceStore();
boolean hasValues =
ps.contains(IPreferenceConstants.MY_EDITOR_BG_COLOR_PREF);
if (hasValues == true)
String rgbStr =
ps.getString(IPreferenceConstants.MY_EDITOR_BG_COLOR_PREF);
try
RGB rgb = StringConverter.asRGB(rgbStr);
getSourceViewer().getTextWidget().setBackground(new
Color(Display.getCurrent(), rgb));
catch (Exception e)
// Nothing
// setSelectionBackgroundColor
private void setSelectionBackgroundColor()
boolean hasValues =
ps.contains(IPreferenceConstants.MY_SELECTION_BG_COLOR_PREF) ;
String rgbStr =
ps.getString(IPreferenceConstants.MY_SELECTION_BG_COLOR_PREF );
try
getSourceViewer().getTextWidget().setSelectionBackground(new
catch (Exception e)
// Nothing
Re: update syntax coloring in a texteditor [message #310618 is a reply to message #310616] |
Mon, 11 December 2006 18:20   |
One more thing...Make sure you're color set for the tokens are
statically declared, so that ALL your editor instances share the same
color set. This will save lots of memory and work. For each preference
notification, check to see first if the color is already is the same
color before changing.
>> scann the document again in order to change to the new colors.
>> any ideas?
>> Thanks
> Dave,
> getSourceViewer().
> boolean hasValues =
> String rgbStr =
> try
> catch (Exception e)
> // Nothing
> boolean hasValues =
> String rgbStr =
> try
> catch (Exception e)
> // Nothing
Re: update syntax coloring in a texteditor [message #310810 is a reply to message #310618] |
Fri, 15 December 2006 14:36   |
I'm sorry but I can't see it. I have differents colors for differents
token types.
I use a scanner that I can't control, it gives me a token types list so
I create a dinamic preference page. When the scanner find a token,
returns me the token id, i go to the preference page, check the colour
and assign to the token (only the color).
I've been looking a way to ask the scanner to scan the page again but I
couldn't find anything.....
>>> color of each token. My problem is after I change a color (in the
>>> preference page), I don't know how to refresh the color in the document.
>>> any ideas?
>>> Thanks
>> Dave,
>> getSourceViewer().
>> boolean hasValues =
>> String rgbStr =
>> try
>> catch (Exception e)
>> // Nothing
>> boolean hasValues =
>> String rgbStr =
>> try
>> catch (Exception e)
>> // Nothing
Re: update syntax coloring in a texteditor [message #310815 is a reply to message #310809] |
Sat, 16 December 2006 07:07  |
I found the problem...when I initialize the editor, I miss the line
setPreferenceStore(MyEditorPlugin.getDefault().getPreference Store());
now it works perfectly,
thanks
David Rojo escribió:
> I have overrided the method, but it is not called when I change the
> preferences. Do I have to do something special to get it??
>> The only thing you need to do is implement override
>> affectsTextPresentation(...) in your editor. This will kick the
>> scanner to do its work (assuming it has been correctly fed with the
>> new preferences).
>> Dani
>>> any ideas?
>>> Thanks
Current Time: Sun Jul 20 03:31:15 EDT 2025
Powered by FUDForum. Page generated in 0.03881 seconds
