Home » Eclipse Projects » Eclipse Platform » Hot key can't work!
Hot key can't work! [message #310431] Sat, 02 December 2006 12:12 Go to next message
hi,
Recently, I downloaded the newest Eclipse v3.2.1, but Ctrl + Alt + Up/Down
can't work properly!
The type of My notebook is ThinkPad X60s.
Can anyone provide some direction for troubleshooting?
Thanks for any help you can give.
Re: Hot key can't work! [message #310433 is a reply to message #310431] Sat, 02 December 2006 22:30 Go to previous messageGo to next message
Any chance you have used "customize perspective" to remove toolbar
buttons? To my surprise removing buttons also removes keybindings!
John.
xldelphi wrote:
> hi,
> Up/Down can't work properly!
Re: Hot key can't work! [message #310575 is a reply to message #310433] Sat, 09 December 2006 04:28 Go to previous messageGo to next message
Thanks for your answer.
but the setting of eclipse is default.
"John J. Barton" <johnjbarton@johnjbarton.com> wrote in message
news:ektgcs$o02$1@utils.eclipse.org...
> John.
> xldelphi wrote:
>> hi,
Re: Hot key can't work! [message #310578 is a reply to message #310575] Sat, 09 December 2006 12:41 Go to previous messageGo to next message
To determine if the keys are being trapped before they get to eclipse
you can run a simple Java application to print the keys you press. See
for example
http://www.java2s.com/Code/JavaAPI/org.eclipse.swt.widgets/T extaddKeyListenerKeyListenerlis.htm
or
http://www.cs.umanitoba.ca/~eclipse/2-Basic.pdf
If such a program prints normal keys but not C-A-Up, then chances are
good that the OS or BIOS gets them first.
>> John.
>> xldelphi wrote:
>>> hi,
Re: Hot key can't work! [message #310606 is a reply to message #310578] Mon, 11 December 2006 11:43 Go to previous messageGo to next message
As local test, the keys are being trapped properly by windows sdk in
windows xp + sp2,
but can't be trapped by jdk1.5.0_9(without swt). I think it seem to be a bug
of j2se.
news:elesga$qi$1@utils.eclipse.org...
> for example
> or
>>> John.
>>> xldelphi wrote:
>>>> hi,
Re: Hot key can't work! [message #310608 is a reply to message #310606] Mon, 11 December 2006 12:32 Go to previous message
no problem with the newest jdk 6!
Thanks a lot!
"xldelphi" <xldelphi@gmail.com> wrote in message
news:elk1qs$m9a$1@utils.eclipse.org...
> windows xp + sp2,
> bug of j2se.
>> for example
>> or
>>>> John.
>>>> xldelphi wrote:
>>>>> hi,
Previous Topic:How to do additional test for popup menu?
Next Topic:Responding to the enabling/disabling of a Project's Builder
Current Time: Fri Jul 18 15:36:24 EDT 2025
Powered by FUDForum. Page generated in 0.06001 seconds
