Home » Archived » OHF » Implementing OHF
Implementing OHF [message #30983] |
Mon, 02 July 2007 09:46  |
Originally posted by: tsoutherland.digichart.com
My company is looking to implement the OHF Bridge for our .NET
application for the 2008 Connectathon. Do we need to support our own
Apache/Tomcat environment to support the web services that are available?
Tone Southerland
Re: Implementing OHF [message #31088 is a reply to message #31054] |
Tue, 10 July 2007 12:25   |
> I understand that you are recommending that we have our own Tomcat
> instance for Connectathon 2008.
Looks like it will be a requirement from IHE, though it would be better to use a
central one. For testing before the connectathon (MESA tests) we'll have a
public instance of Tomcat on the open web for everyone to test with.
> we'll need to setup and support our own Tomcat for our production
> environment as well (post Connectathon).
True. The bridge holds the RHIO configurations which are specific to your
specific RHIO (IP address, codes, etc). In addition for security reasons you
would probably want all of your communication to be local and behind the same
firewall.
Eishay
Tone Southerland <tsoutherland@digichart.com> wrote:
> Hi Eishay,
> Thanks for your response.
> instance for Connectathon 2008. Understanding that, I'm also assuming
> that we'll need to setup and support our own Tomcat for our production
> environment as well (post Connectathon). Am I correct in my assumption?
> Eishay Smith wrote:
>> Hi Tone,
>> Sorry for the late response.
>> We're still not sure how wold it be at the 2008 conectathon.
>> This year each of the bridge users had his own instance of Tomcat, we'll try
>> to convince the connectathon testers to let us use a shared infrastructure
>> but please don't count on it.
>> Maintaining and installing the bridge is very straight forward. In the
>> connectathon we can provide a full Tomcat and bridge runtime in a zip file
>> and all the uses needs to do is to unzip and run a batch file. We also had a
>> central server with a central configuration file containing relevant IP
>> addresses of the IHE servers your Bridge needs to communicate with.
>> As for the testing phase, we maintain a bridge instance with the latest bug
>> fixes up and running configured to the MESA test servers.
>> Regards,
>> Eishay
>>> Hi,
>>> Thanks,
>>> Tone Southerland
Re: Implementing OHF [message #31230 is a reply to message #31088] |
Wed, 11 July 2007 14:23   |
Are there any .NET shops out there who have implemented this scenario
successfully? Any input from such companies would be very helpful.
> firewall.
> Eishay
>> Hi Eishay,
>> Eishay Smith wrote:
>>> Hi Tone,
>>> Regards,
>>> Eishay
>>>> Hi,
>>>> Thanks,
>>>> Tone Southerland
Re: Implementing OHF [message #31264 is a reply to message #31230] |
Wed, 11 July 2007 14:57   |
I know of at least CapMed and PracticePartners, we supported both in the last
Connectathon (supported CapMed also in the year before).
Try to contact Donnie Gooch (he got a record number of tests done in the last
Connectathon), and Corey Spears.
I know that this year there will be more .NET users in the community.
Eishay
use a
>> firewall.
>> Eishay
>>> Hi Eishay,
>>> Eishay Smith wrote:
>>>> Hi Tone,
try
a
>>>> Regards,
>>>> Eishay
>>>>> Hi,
>>>>> Thanks,
>>>>> Tone Southerland
Re: Implementing OHF [message #31473 is a reply to message #30983] |
Thu, 12 July 2007 14:44   |
Originally posted by: donnie.gooch.pointclearsolutions.com
Yes, we were required to run our own Bridge last year, tomcat/ohf bride on
windows. The IBM team were awesome and resolved issues in the bridge as
they came up and made a local site available during connectathon to get
updates to the bridge, plus they, I think Matthew, put a config file that
included all the important combinations of registries, repo, pix/pdq, and
audit servers.
I have been out of the Java camp for a while, so once Eishay and Matthew
set me straight on how to configure and update the necessary config files
I was good to go.
thanks
Donnie
Re: Implementing OHF [message #31543 is a reply to message #31473] |
Thu, 12 July 2007 15:34   |
Thanks for your input, Donnie.
You mentioned that you ran your own Tomcat/OHF Bridge on Windows, I had
understood that running the bridge required an Apache (non-windows)
environment. Did I misunderstand something?
Tone
> on windows. The IBM team were awesome and resolved issues in the bridge
> as they came up and made a local site available during connectathon to
> get updates to the bridge, plus they, I think Matthew, put a config file
> that included all the important combinations of registries, repo,
> pix/pdq, and audit servers.
> files I was good to go.
> thanks
> Donnie
Re: Implementing OHF [message #31717 is a reply to message #31543] |
Fri, 13 July 2007 11:09   |
Hi Tone,
Yes, we recommend that the OHF Bridge be run in Apache Tomcat 5.5, which
does have a Windows binary version available. It's actually pretty
straightforward to setup.
http://tomcat.apache.org/download-55.cgi
I think Eishay already gave you a link, but here are the install
instructions for the OHF Bridge:
http://www.eclipse.org/ohf/components/bridge/install.php
-Matt Davis
> Tone
>> bride on windows. The IBM team were awesome and resolved issues in
>> the bridge as they came up and made a local site available during
>> connectathon to get updates to the bridge, plus they, I think Matthew,
>> put a config file that included all the important combinations of
>> registries, repo, pix/pdq, and audit servers.
>> Matthew set me straight on how to configure and update the necessary
>> config files I was good to go.
>> thanks
>> Donnie
Re: Implementing OHF [message #31785 is a reply to message #31543] |
Fri, 13 July 2007 14:15  |
We tested the Bridge on Windows, Linux, MacOS, and AIX.
Since the full environment is 100% Java it should be able to run on any
platform that supports Java.
Eishay
> Tone
>> thanks
>> Donnie
Re: Implementing OHF [message #579501 is a reply to message #30983] |
Mon, 09 July 2007 19:53  |
Hi Tone,
Eishay
> Tone Southerland
Re: Implementing OHF [message #579542 is a reply to message #31020] |
Tue, 10 July 2007 09:45  |
Hi Eishay,
Eishay Smith wrote:
> Hi Tone,
> Regards,
> Eishay
>> Hi,
>> Thanks,
>> Tone Southerland
Re: Implementing OHF [message #579556 is a reply to message #31054] |
firewall.
Eishay
> Hi Eishay,
> Eishay Smith wrote:
>> Hi Tone,
>> Regards,
>> Eishay
>>> Hi,
>>> Thanks,
>>> Tone Southerland
Re: Implementing OHF [message #579615 is a reply to message #31088] |
Tue, 10 July 2007 15:00  |
Anybody who would like to add 'last words' to my OHF presentation at the
end of this week in Amiens, France ?;-)
Due to location and ease of use, I'll definitely include STEM to some
extent (and also cause I just published and article on it in Eclipse
Magazin) but I'll try to cover all sub projects as good as possible...
Re: Implementing OHF [message #579679 is a reply to message #31088] |
> firewall.
> Eishay
>> Hi Eishay,
>> Eishay Smith wrote:
>>> Hi Tone,
>>> Regards,
>>> Eishay
>>>> Hi,
>>>> Thanks,
>>>> Tone Southerland
Re: Implementing OHF [message #579698 is a reply to message #31230] |
Eishay
use a
>> firewall.
>> Eishay
>>> Hi Eishay,
>>> Eishay Smith wrote:
>>>> Hi Tone,
try
a
>>>> Regards,
>>>> Eishay
>>>>> Hi,
>>>>> Thanks,
>>>>> Tone Southerland
Re: Implementing OHF [message #579712 is a reply to message #31158] |
Wed, 11 July 2007 15:03  |
Thanks Werner!
Eishay
Werner Keil <werner.keil@gmx.net> wrote:
Re: Implementing OHF [message #579731 is a reply to message #31296] |
Wed, 11 July 2007 18:38  |
France is going through a major push by the government to implement a
national healthcare portal application and infrastructure. They are
requiring the use of IHE ... so talking about those components would be
impactful, I believe.
- Sarah
Eishay Smith wrote:
> Thanks Werner!
> Eishay
>>Hi,
Re: Implementing OHF [message #579790 is a reply to message #31326] |
Thu, 12 July 2007 04:55  |
> - Sarah
From an NHS perspective one wonders wrt OHF tooling & CEN 13606/OpenEHR.
Given OpenEHR is OSS etc....
Adam
> Eishay Smith wrote:
>> Thanks Werner!
>> Eishay
>>> Hi,
Re: Implementing OHF [message #579826 is a reply to message #30983] |
audit servers.
I was good to go.
thanks
Donnie
Re: Implementing OHF [message #579846 is a reply to message #31264] |
Thu, 12 July 2007 15:22  |
Yes, we are .net platform; there are two sides of the coin here -
interface to the OHF Bridge, which is very easy using the built in proxy
that vs05.net generates. We map the brige objects to ours at the point of
sending and receiving and use the proxy (referene.cs) for this and not any
additional generated .cs classes. Dealing with Documents (CDA etc) is the
other side and we have a very complex interop component that handles IHE
and other document types and is where you spend 80% of the time.
if you need to talk you have my email above.
Donnie
Re: Implementing OHF [message #579876 is a reply to message #31473] |
Tone
> thanks
> Donnie
Re: Implementing OHF [message #579971 is a reply to message #31543] |
Hi Tone,
-Matt Davis
> Tone
>> thanks
>> Donnie
Re: Implementing OHF [message #580006 is a reply to message #31543] |
Eishay
> Tone
>> thanks
>> Donnie
Current Time: Sat Jul 26 18:52:43 EDT 2025
Powered by FUDForum. Page generated in 0.33735 seconds
