Home » Modeling » OCL » OCL on meta-models
OCL on meta-models [message #30917] Wed, 27 June 2007 06:04 Go to next message
Originally posted by: anquiroe101.hotmail.com
Hi all :D
Can someone show me code examples using OCL on meta-models (other example
different to "OCL Interpreter").
Anne
Re: OCL on meta-models [message #30987 is a reply to message #30917] Wed, 27 June 2007 10:41 Go to previous messageGo to next message
Hi, Anne,
Ecore is both a model and a meta-model, so any constraint defined in an
Ecore instance constitutes an example. Thus, the
org.eclipse.ocl.ecore.tests JUnit test suite has numerous examples
demonstrating pretty nearly everything you can do with OCL.
That's about it for examples that you will find in the OCL component,
itself. Other Eclipse projects such as GMF use OCL (GMF uses it to a
fairly considerable degree). You might have a look, there.
Christian
Anne wrote:
> Hi all :D
> Thanks
> Cheers,
> Anne
Re: OCL on meta-models [message #31022 is a reply to message #30987] Wed, 27 June 2007 12:15 Go to previous message
ok. I will read all examples you say me.
Thanks :D
Anne
Previous Topic:OCL query
Next Topic:Re: [OCL] String Operations
Current Time: Sat Jul 26 07:50:21 EDT 2025
Powered by FUDForum. Page generated in 0.05676 seconds
