Home » Eclipse Projects » Eclipse Platform » eclipse hang when exec program
eclipse hang when exec program [message #309601] |
Thu, 02 November 2006 04:41  |
Originally posted by: joneo_ytk81.hotmail.com
hi all,
i'm having problem with eclipse where it hang when execute a program using
the ProcessBuilder. Below is actually how i create the process and print
out the process details in console view. FYI, i didnt implements any
interfaces or classes. i just create a class which extend from Action. Do
i miss out anything? Please advice. thanks.
ProcessBuilder pb = new ProcessBuilder(EXECUTE.toString(),"-g");
pb.directory(path.toFile());
Process p = pb.start();
InputStream is = p.getInputStream();
int c;
StringBuffer sb = new StringBuffer();
while((c=is.read()) != -1)
sb.append((char)c);
System.out.println(sb.toString());
Re: eclipse hang when exec program [message #309756 is a reply to message #309720] |
Tue, 07 November 2006 10:07   |
Dear Joneo,
joneo schrieb:
> sorry i'm new to java and eclipse. may i know what do you mean with
> sub-process? is it creating another thread? do you mind to provide more
> guidelines? where should i create the thread? where should i put the
> code you have shown me? i've tried the below code but is not working. it
> does not go in the while loop.can anyone give some guidance? thanks.
A sub-process is a new program started by your program. It runs in its
own memory space and the only way to communicate with is via input,
output and error streams. As an example type in a Windows command line
"cmd" and you get a sub-process. The parent waits until the termination
of the sub-process (sometimes also named as child process).
> Process p = null;
> Thread t = new Thread(){
> public void run(){
> p = pb.start();
> t.start();
The ProcessBuilder is just a convenience class to set-up a new
sub-process and you do not need a separate thread to create the process.
After that you have to handle the Process p you got back from
ProcessBuilder.start().
> InputStream es = p.getErrorStream();
> OutputStream os = p.getOutputStream();
Yes, these are the streams you need to read from and write to for
communicating with your sub-process. Now you have to check four conditions:
1) Data available on error stream? read and report error message
2) Data available on input stream? read and work with the output
3) Data needed on the output stream? write new data, line by line
4) Sub-process terminated: check exit code,
read all from is and es; done
> while(t.isAlive()){
> if(es.available())
> es.read();
> else if (is.available())
> is.read();
> else
> os.write();
// If you insist on some code, here it comes...
int length;
int resultCode;
while(true)
if ((length = es.available()) > 0)
byte[] b = new byte[length];
es.read(b);
// report error
else if (length = is.available()) > 0)
// same as above
else
try
resultCode = p.exitValue();
break;
catch(IllegalThreadStateException e)
Thread.sleep(100);
Loop over all streams. Try to read the exit value which fails if the
process is still alive.
Check the documentation of Process, Runtime.exec and search the Internet
for some tutorials how to start processes and handle the inter-process
communication... You may need to read some additional documentation
about processes in general as the API documentation explains typically
how to do it but not how things work together.
Bye,
Günther
Re: eclipse hang when exec program [message #309764 is a reply to message #309756] |
Tue, 07 November 2006 13:13   |
Thanks for the guidance.Actually the reason i'm doing so is to be able to
pipe the process executions to the console view. is it possible?
Guenther Koegel wrote:
> Dear Joneo,
>> Process p = null;
>> public void run(){
>> p = pb.start();
>> t.start();
>> while(t.isAlive()){
>> if(es.available())
>> es.read();
>> is.read();
>> else
>> os.write();
> int length;
> int resultCode;
> while(true)
> es.read(b);
> // report error
> // same as above
> else
> try
> break;
> Thread.sleep(100);
> Bye,
> Günther
Re: eclipse hang when exec program [message #309796 is a reply to message #309764] |
Thu, 09 November 2006 03:18   |
Dear Joneo,
Am I right by assuming that you want to read the output (and error
messages) from the sub-process and print it to your console?
Then your part of the implementation is marked with the comment
// report error
and
// same as above
Read data into the byte array, convert to String and forward it where
you want it and you are done! On "How to send it to the console view" I
have no clue...
Bye
Günther
> to pipe the process executions to the console view. is it possible?
>> Dear Joneo,
>>> more guidelines? where should i create the thread? where should i put
>>> the code you have shown me? i've tried the below code but is not
>>> working. it does not go in the while loop.can anyone give some
>>> guidance? thanks.
>> termination of the sub-process (sometimes also named as child process).
>>> Process p = null;
>>> public void run(){
>>> p = pb.start();
>>> t.start();
>> process. After that you have to handle the Process p you got back from
>> conditions:
>>> while(t.isAlive()){
>>> if(es.available())
>>> es.read();
>>> is.read();
>>> else
>>> os.write();
>> int length;
>> int resultCode;
>> while(true)
>> es.read(b);
>> // report error
>> // same as above
>> else
>> try
>> break;
>> Thread.sleep(100);
>> Internet for some tutorials how to start processes and handle the
>> inter-process communication... You may need to read some additional
>> documentation about processes in general as the API documentation
>> explains typically how to do it but not how things work together.
>> Bye,
>> Günther
Re: eclipse hang when exec program [message #310003 is a reply to message #309796] |
Tue, 14 November 2006 22:13   |
sorry for the late reply. besides reading the output and error messages
from the sub-process, i also want to be able to accept input from user
whenever needed and print at the console. kind of like interactive ways.
i've looked into the debug console but their approach is through the
launchconfig file. but for me i dont have any launchconfig file being
created.
> Dear Joneo,
> // report error
> and
> // same as above
> have no clue...
> Bye
> Günther
>>> Dear Joneo,
>>>> guidance? thanks.
>>>> Process p = null;
>>>> public void run(){
>>>> p = pb.start();
>>>> t.start();
>>> conditions:
>>>> while(t.isAlive()){
>>>> if(es.available())
>>>> es.read();
>>>> is.read();
>>>> else
>>>> os.write();
>>> int length;
>>> int resultCode;
>>> while(true)
>>> es.read(b);
>>> // report error
>>> // same as above
>>> else
>>> try
>>> break;
>>> Thread.sleep(100);
>>> Bye,
>>> Günther
Re: eclipse hang when exec program [message #310981 is a reply to message #310972] |
Fri, 22 December 2006 23:18   |
Guys thanks for the replies. i really appreciate it. i've been waiting for
somebody to come rescue me for long time ago. below are the source code on
what i've done so far to capture the process execution output. temporary i
focus on capturing the output from the process first. well i've tried run
the same execution through the external tools configuration. it run
smoothly without having this kind of problem. i debug the code and found
that it is using the ProcessConsole function which required the
configuration setup. so i'm not able to use it's method. can anybody
explain to me how the debug console process flow is? coz i still not clear
on the magic behind through debugging the code. please....
This is what i've just discover lately and i hope this is useful to you
guys. FYI, my program A is written in C++. Program A will call program B
which is written in Perl. One thing i just discovered is that program B
will call another program C (i've no idea what language it is written in
but it is an .exe program which will check on the file checksum). i've no
access to modify the program C code as it come in exe. so what i've done
it to modify the program B to print out the result return by program C.
through the debugging, i found that it actually did execute the program C
but it stopped for the third time of executing it. all the value return by
program C is able to be print out by program B. but i've no idea why it
stop at the third time calling the program C. it is able to run smoothly
when i execute it through command prompt. one thing miss out from the
execution is that the program C will also print out some
information/comments but it is not captured by the inputStream of the
process. is this the one causing the execution to hang? when execute
through the external tool, all the information/comments that return by the
program C is highlighted in red color. what does it means?
Actually previously there are 2 solution suggested by Guenther Koegel
Solution 1: Use a separate Thread for each channel
and one to monitor sub-process termination (+exit status)
==> use blocking IO and thread termination
Solution 2: Use a single thread
==> Poll each channel with InputStream.available() and read only
if data is available. Error stream has highest priority...
the one i'm using is the solution 2. so how is the solution 1 code looks
like?
i not really understand how can i use separate thread for each stream
channel since i only hav one process. so can anybody guide me on this?
sorry i'm still new to eclipse and java programming. please help me.
thanks in advance.
################### Source Code ######################################
try
ConsolePlugin plugin = ConsolePlugin.getDefault();
IConsoleManager conMan = plugin.getConsoleManager();
MessageConsole myConsole = new MessageConsole("AA", null);
conMan.addConsoles(new IConsole[]{myConsole});
conMan.showConsoleView(myConsole);
MessageConsoleStream ocons = myConsole.newMessageStream();
p = DebugPlugin.exec(cmd, path.toFile());
is.mark(50);
int rc;
while(true)
if (es.available()>0)
//os.write(es.available());
//System.out.println("die");
else if (is.available()>0)
BufferedReader br = new BufferedReader(new InputStreamReader(is));
String s;
while((s = br.readLine()) != null)
ocons.println(s);
else
System.out.println("Here");
try
rc = p.exitValue();
System.out.println("rC : "+rc);
break;
System.out.println("slp");
Thread.sleep(1000);
//is.reset();
catch (Exception e)
System.out.println(e.getMessage());
e.printStackTrace();
David Wegener wrote:
> joneo wrote:
>> hi,
>> i'm still unable to solve the eclipse hang issue. i just found out that
>> the program that i exec will call another program during the execution.
>> so i wonder will is be detected by the process inputStream which i
>> create earlier to run the 1st program? ok let me explain the execution
>> flow.
>> i execute the program A through the ProcessBuilder. Internally program A
>> will call another program B. i use the inputStream from the
>> ProcessBuilder to capture all the execution process and display it in
>> the console. there is one part before calling the program B i saw a
>> command line call "echo off". when i debug into the eclipse program, i
>> found it actually stop printing when reaching that line and causing the
>> eclipse hang there. i follow the code given where i put an infinite loop
>> ( while(true){ } ) to capture the inputStream/errorStream/outputStream.
>> somehow is just won't continue when reaching that part. does this mean
>> that it failed to detect the inputStream from program B? but when i run
>> it through the external tool configuration, it is able to go through and
>> run the program smoothly and print all the execution process at the
>> console view. but the words is printed in red color in the console. how
>> can i fix this issue. can someone help me?
> It sounds like you are stuck on a blocking call. What is in your
> infinite while loop? You indicate that you are capturing the input,
> error, and output streams. I don't understand how you can capture all
> of these. The Process InputStream (retrieved by calling
> process.getOutputStream()) is used to write data to the processes input
> stream, you can't capture this in a while loop.
> You can capture data from the streams returned by the
> process.getInputStream() and the process.getErrorStream() methods by
> calling one of the read() methods. Note that if there isn't any data
> available on the InputStream when you issue the read() call, the call
> will block until data is available. You can call the available() method
> to see if anything is available to be read in.
Re: eclipse hang when exec program [message #310995 is a reply to message #310981] |
Sat, 23 December 2006 13:15   |
Originally posted by: wegener.cboenospam.com
See comments in code below
> for somebody to come rescue me for long time ago. below are the source
> code on what i've done so far to capture the process execution output.
> temporary i focus on capturing the output from the process first. well
> i've tried run the same execution through the external tools
> configuration. it run smoothly without having this kind of problem. i
> debug the code and found that it is using the ProcessConsole function
> which required the configuration setup. so i'm not able to use it's
> method. can anybody explain to me how the debug console process flow is?
> coz i still not clear on the magic behind through debugging the code.
> please....
> no access to modify the program C code as it come in exe. so what i've
> done it to modify the program B to print out the result return by
> program C. through the debugging, i found that it actually did execute
> the program C but it stopped for the third time of executing it. all the
> value return by program C is able to be print out by program B. but i've
> no idea why it stop at the third time calling the program C. it is able
> to run smoothly when i execute it through command prompt. one thing miss
> out from the execution is that the program C will also print out some
> the program C is highlighted in red color. what does it means?
> like?
> thanks in advance.
Multiple Thread approach:
declare is and es final (final InputStream is = p.getInputStream()).
Replace the infinite loop below with the following:
Thread isThread = new Thread() {
public void run() {
BufferedReader isReader = new BufferedReader(new
String isString;
// You don't care that the readLine will block
// because it is running in a different thread.
while ((isString = isReader.readLine()) != null) {
// This may need to be executed on the Display
// Thread. If so, you need to wrap the
// ocons.println call in a Display.asyncExec() call.
ocons.println(isString);
isThread.start();
Thread esThread = new Thread() {
public void run() {
byte[] buffer = new byte[100];
while (es.read(buffer) != -1) {
esThread.start();
There may be some exception handling missing from this. I haven't
actually tried the code, so there could be some other syntax errors as well.
> try
> is.mark(50);
> int rc;
> while(true)
Most likely, you problem is here. You never read anything from the
ErrorStream of the process. The processes error stream is a buffer.
When it fills up, the process (any any subprocess) will block if it
attempts to write to the error stream. Once the error stream has data
in it, you will never read from the input stream because you have that
processing in the else of es.available().
From your description, it sounds like program C is writing its data to
the error stream. That is why it shows up in red when run as an
external application. Within this if block, you need to read data from
the error stream. Something like this should work.
byte[] buffer = new byte[es.available()];
es.read(buffer);
This block of code will also cause you problems. The
BufferedReader.readLine method will block until a complete line (with
terminating line end) is available. Your while loop below will never
exit. The readLine method only returns null if at end of file. This
will only occur if the process exits and closes the input stream you are
reading. Once you enter the loop, you will block on the readLine method
when all of the available data has been read. When the second process
blocks on the error stream mentioned above, there will never be any
additional data writen to the input stream you are blocked on.
Instead of the BufferedReader, I would read the data into a byte array
like shown above.
> String s;
> ocons.println(s);
> else
> try
> rc = p.exitValue();
> break;
> Thread.sleep(1000);
> //is.reset();
> catch (Exception e)
>> joneo wrote:
>>> hi,
>>> that the program that i exec will call another program during the
>>> execution. so i wonder will is be detected by the process inputStream
>>> which i create earlier to run the 1st program? ok let me explain the
>>> execution flow.
>>> program A will call another program B. i use the inputStream from the
>>> i found it actually stop printing when reaching that line and causing
>>> the eclipse hang there. i follow the code given where i put an
>>> infinite loop ( while(true){ } ) to capture the
>>> inputStream/errorStream/outputStream. somehow is just won't continue
>>> when reaching that part. does this mean that it failed to detect the
>>> inputStream from program B? but when i run it through the external
>>> tool configuration, it is able to go through and run the program
>>> smoothly and print all the execution process at the console view. but
>>> the words is printed in red color in the console. how can i fix this
>> input stream, you can't capture this in a while loop.
>> method to see if anything is available to be read in.
Re: eclipse hang when exec program + console tips [message #311008 is a reply to message #310995] |
Sun, 24 December 2006 19:19   |
hi David Wegener,
thanks for the help. is working now. i guess you are right. i've added in
to capture the error stream. and its running smoothly now. i've include my
source code as well in case others would need it as reference. but i got
one question. how can i print the execution process instantly by not
waiting till the process end then only print out the whole things? is it
required to use different thread for that?
try
int rc;
while(true)
byte [] bes = new byte[es.available()];
es.read(bes);
for (int i = 0; i<bes.length; i++)
sb.append((char)bes[i]);
byte [] bis = new byte[is.available()];
is.read(bis);
for (int i = 0; i<bis.length; i++)
sb.append((char)bis[i]);
else
try
rc = p.exitValue();
break;
Thread.sleep(10);
ocons.println(sb.toString());
catch (Exception e)
>> please....
>> like?
>> thanks in advance.
> public void run() {
> String isString;
> isThread.start();
> public void run() {
> esThread.start();
>> try
>> is.mark(50);
>> int rc;
>> while(true)
> es.read(buffer);
> like shown above.
>> String s;
>> ocons.println(s);
>> else
>> try
>> rc = p.exitValue();
>> break;
>> Thread.sleep(1000);
>> //is.reset();
>> catch (Exception e)
>>> joneo wrote:
>>>> hi,
>>>> execution flow.
Re: eclipse hang when exec program + console tips [message #311013 is a reply to message #311008] |
Sun, 24 December 2006 22:35   |
joneo wrote:
> hi David Wegener,
> in to capture the error stream. and its running smoothly now. i've
> include my source code as well in case others would need it as
> reference. but i got one question. how can i print the execution process
> instantly by not waiting till the process end then only print out the
> whole things? is it required to use different thread for that?
Personally, I would use separate threads for each stream. You can use
blocking IO when you have a dedicated thread and don't need to worry
about putting a sleep into your loop.
As to the issue of waiting till the end to print out the data, you could
call ocons.println() after you have read data in. Instead of appending
all of it to the end of a single StringBuffer, create a String from the
byte array read in each time. Something like this:
es.read(bes);
String besBuffer = new String(bes);
ocons.println(besBuffer);
Another change to consider would be to remove the else from the
is.available() check. It won't cause a big difference, but the way the
code is right now, the InputStream will only be processed if the
ErrorStream has no data on it.
> try
> int rc;
> while(true)
> es.read(bes);
> is.read(bis);
> else
> try
> rc = p.exitValue();
> break;
> Thread.sleep(10);
> catch (Exception e)
>>> waiting for somebody to come rescue me for long time ago. below are
>>> the source code on what i've done so far to capture the process
>>> execution output. temporary i focus on capturing the output from the
>>> process first. well i've tried run the same execution through the
>>> external tools configuration. it run smoothly without having this
>>> kind of problem. i debug the code and found that it is using the
>>> ProcessConsole function which required the configuration setup. so
>>> i'm not able to use it's method. can anybody explain to me how the
>>> debug console process flow is? coz i still not clear on the magic
>>> you guys. FYI, my program A is written in C++. Program A will call
>>> program B which is written in Perl. One thing i just discovered is
>>> that program B will call another program C (i've no idea what
>>> language it is written in but it is an .exe program which will check
>>> on the file checksum). i've no access to modify the program C code as
>>> it come in exe. so what i've done it to modify the program B to print
>>> out the result return by program C. through the debugging, i found
>>> that it actually did execute the program C but it stopped for the
>>> third time of executing it. all the value return by program C is able
>>> to be print out by program B. but i've no idea why it stop at the
>>> third time calling the program C. it is able to run smoothly when i
>>> by the program C is highlighted in red color. what does it means?
>>> looks like?
>>> this? sorry i'm still new to eclipse and java programming. please
>>> help me. thanks in advance.
>> public void run() {
>> String isString;
>> isThread.start();
>> public void run() {
>> esThread.start();
>> well.
>>> try
>>> is.mark(50);
>>> int rc;
>>> while(true)
>> to the error stream. That is why it shows up in red when run as an
>> from the error stream. Something like this should work.
>> es.read(buffer);
>> are reading. Once you enter the loop, you will block on the readLine
>> method when all of the available data has been read. When the
>> second process blocks on the error stream mentioned above, there will
>> never be any additional data writen to the input stream you are
>> blocked on.
>> like shown above.
>>> String s;
>>> ocons.println(s);
>>> else
>>> try
>>> rc = p.exitValue();
>>> break;
>>> Thread.sleep(1000);
>>> //is.reset();
>>> catch (Exception e)
>>>> joneo wrote:
>>>>> hi,
>>>>> inputStream which i create earlier to run the 1st program? ok let
>>>>> me explain the execution flow.
>>>>> the ProcessBuilder to capture all the execution process and display
>>>>> it in the console. there is one part before calling the program B i
>>>>> saw a command line call "echo off". when i debug into the eclipse
>>>>> program, i found it actually stop printing when reaching that line
>>>>> and causing the eclipse hang there. i follow the code given where i
>>>>> put an infinite loop ( while(true){ } ) to capture the
>>>>> continue when reaching that part. does this mean that it failed to
>>>>> detect the inputStream from program B? but when i run it through
>>>>> the external tool configuration, it is able to go through and run
>>>>> how can i fix this issue. can someone help me?
>>>> all of these. The Process InputStream (retrieved by calling
>>>> data available on the InputStream when you issue the read() call,
>>>> the call will block until data is available. You can call the
>>>> available() method to see if anything is available to be read in.
Current Time: Sat Jul 26 17:08:21 EDT 2025
Powered by FUDForum. Page generated in 0.05415 seconds
