Tcl Task Tag problems [message #30850] |
Wed, 03 September 2008 07:10  |
We use Eclipse DLTK ganymede to program in Tcl. So, this tool is very
usefull and facilitates us the programming in Tcl.
But, we just have a little problem about Task tag. I explain.
We have a lot of big projects which are saved and referenced by version on
a perforce server. This server permit us to save, modify, download
different files of projects, and to class all projects about their number
of versions. This server permit to centralize all works of peoples on
company.
So, when we want to work with a created project, first of all we have to
check out Tcl changed files of project from perforce server, that makes
these changed files writable on Eclipse but not all project. In fact
entire project is open on Eclipse, but just some files are writable.
So, on no-writable files of eclipse, Task Tag not recongnize "Todo"
comment as a task.
And the other problem is, when we configure Preferences/Tcl/Task Tag,
after a restart of Eclipse this configuration come back per default even
if we saved this configuration.
Thank you for your help
Best regards
Ophelie
Re: Tcl Task Tag problems [message #30920 is a reply to message #30850] |
Thu, 04 September 2008 22:42   |
Hi Ophélie,
I've could not reproduce first problem you specified, could you please provide exact steps you perform and project
structure. May be you could simulate situation on not perforce project.
For a second problem I've created bug in eclipse https://bugs.eclipse.org/bugs/show_bug.cgi?id=246311
Andrei Sobolev.
> Hello,
> on a perforce server. This server permit us to save, modify, download
> number of versions. This server permit to centralize all works of
> peoples on company.
> entire project is open on Eclipse, but just some files are writable. So,
> on no-writable files of eclipse, Task Tag not recongnize "Todo" comment
> as a task.
> Best regards
> Ophelie
Re: Tcl Task Tag problems [message #30954 is a reply to message #30920] |
Fri, 05 September 2008 02:40  |
Thank you for your answer.
In fact, perforce server manages differents projects, and makes all
projects right protected.
I think the problem comes from right protected projects. When we open
right protected projects, task tags not recognize "todo" comment as task.
I tried with unright protected projects and task tag runned well, but the
problem is we cannot change right of projects every time we need a
project, it will be to much heavy.
I am sorry about my English, but I expect you will understand my problem.
Best regards
Ophélie
FUDForum. Page generated in 0.07210 seconds
