eclipse-jee-ganymede link with subversive [message #30898] |
Sun, 10 August 2008 10:46  |
I want to add subversive to eclipse-jee-ganymede by link way.
After download the two zip
file:Subversive-connectors-2.0.1.I20080612-1500.zip and
Subversive-incubation-0.7.1.I20080612-1500.zip and copy them to my plugins
repository and write the link file.
I add the two link file to the dropins floder but I didn't find the SVN
perspective in eclipse.
The repository dir like
d:/opt/eclipse-plugins/Subversive-connectors-2.0.1.I20080612 -1500/eclipse/plugins
and the link file
:path=d:/opt/eclipse-plugins/Subversive-connectors-2.0.1.I20 080612-1500
When I used eclipse 3.3 before ,it works.
How can this be fixed?
Re: eclipse-jee-ganymede link with subversive [message #31814 is a reply to message #31307] |
Thu, 14 August 2008 04:57  |
Radoslaw Jozwik wrote:
> Alexander Gurov wrote:
>> because AFAIK Eclipse 3.4 does not support anymore installing
>> of plug-ins by simple copy, i.e. Eclipse 3.4 Update Manager (p2) requires
>> explicit installing of plug-ins.
> There is new "dropins" folder for manual installation of plugins.
> Gloves,
> Maybe these documents will help you in some way:
> http://wiki.eclipse.org/Equinox_p2_Getting_Started
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/p2_dropins_format.html
> Regards,
> Radoslaw Jozwik
Thanks Alexander Gurov and Radoslaw Jozwik,
I've already try it in that way use 'dropins' folder, but it also doesn't
work. After that I come here to ask for solutions, before add this plug-in
for eclipse-3.4 ,I've added the eclipse-ecf on it used 'links' folder, and
the Eclipse Communication Framework works good, simple copy to 'dropins'
folder is works too. and follow the same way I tried the subvisive¡¡
I think eclipse-3.4 would alse support the "links" folder,but it add the
"dropins" folder, maybe the "links" folder will deprecated but it's the
things after version 3.4
I want to ask that does the subversive support plugin for eclipse by link
way in eclipse version 3.4, because I can't find the Subversive SVN
Connectors plug-in download url now, from the following
url:http://www.polarion.com/products/svn/subversive.php?src= eclipseproject
and maybe I downloaded it form this url before.
Gloves
FUDForum. Page generated in 0.09816 seconds
