Home » Eclipse Projects » Eclipse Platform » Detecing if Eclipse is in high contrast display mode
Detecing if Eclipse is in high contrast display mode [message #308743] Mon, 02 October 2006 15:00 Go to next message
How would I do that? On WINDOWS, I go to "ControlPanels->Accessibility
Options->Display". From there I check the "Use High Contrast" and
"Apply" then "Ok".
I notice that Eclipse detects and ask to re-start Eclipse. Is there an
API that my Eclipse plugins can determine if I am using High Contrast
mode? Thanks. By the way, upon booting up, the text in the Java
editors are not seen, the text with black color originally, now that the
background color is also black.
Re: Detecing if Eclipse is in high contrast display mode [message #308813 is a reply to message #308743] Wed, 04 October 2006 03:37 Go to previous messageGo to next message
Hi AL,
noticed the same problem - there are already some open bug reports to
this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=22243
Best regards, Marion
> "Apply" then "Ok".
Re: Detecing if Eclipse is in high contrast display mode [message #308924 is a reply to message #308743] Tue, 10 October 2006 03:12 Go to previous message
> "ControlPanels->Accessibility Options->Display". From there I check
> the "Use High Contrast" and "Apply" then "Ok".
> an API that my Eclipse plugins can determine if I am using High
> Contrast mode?
Display.getHighContrast()
Dani
> Thanks. By the way, upon booting up, the text in the Java editors are
Previous Topic:Gloabal Actions Handling
Next Topic:TextEditor File Saving
Current Time: Tue Jul 22 06:37:32 EDT 2025
Powered by FUDForum. Page generated in 0.27919 seconds
