Home » Eclipse Projects » Eclipse Platform » EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor)
EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308643] |
Sat, 30 September 2006 08:45  |
Folks,
Am really trying hard to save a model by editing a raw text and there by
updating the MODEL . All my attempts are in vain .
My Scenario:
The editing domain and model is same for both the editors i mean to say
am sharing the same common EMF model.
I have an Multipage editor with two pages 1. TreeViewer to edit the
model 2. TextEditor to view the model source
I am able to view the changes made to the TreeViewer in the TextEditor
but am struck up with the reverse scenario i.e when i make any textual
changes to the model in form text in TextEditor i should synchronize
that with the underlying model file , I am using the XML editor created
out of eclipse platform samples.
My issues are ,
1. How to track the textual changes in the Text Editor?
2. How to fire the model commands based on the Textual Changes?
I dont know how to do this ? can anyone help me please . I dont mind
even the model file gets corrupted as am not enforcing any validations
now , all that i want is to make both work in sync changes to Model
reflected in Source and Changes to source should be reflected in model.
I am trying to do exactly like the PDE editor. I even saw the PDE editor
source but its really long and very confusing to me.
Any pointers will be really helpful.
Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308645 is a reply to message #308643] |
Sat, 30 September 2006 09:50   |
Kamesh,
Probably the best you will get is pointers to existing source code (Eric
Gamma's monkey-see-monkey-do principle) and it will typically be quite
complex. The XSDEditor is a relatively simple (i.e., crude) example.
It will reparse the text whenever the text changes. It uses an
IDocumentListener with a delay to avoid responding to every key stroke.
For the reverse, the command stack listener calls
handleStructuredModelChange whenever a command has been executed, which
serializes the resource in memory and updates the text in the text
editor. This is quite a brute force approach, but should serve as a
starting point.
Kamesh Sampath wrote:
> Folks,
> by updating the MODEL . All my attempts are in vain .
> My Scenario:
> say am sharing the same common EMF model.
> created out of eclipse platform samples.
> My issues are ,
> editor source but its really long and very confusing to me.
> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308647 is a reply to message #308645] |
Sat, 30 September 2006 11:35   |
Ed,
Thats right ! thats y i sought to see the PDE Editor , but for my
requirement its quite complex hence i asked for somthing much simpler.
Will try the XSD editor.
Thanks .
Kamesh
Ed Merks wrote:
> Kamesh,
> (Eric Gamma's monkey-see-monkey-do principle) and it will typically be
> quite complex. The XSDEditor is a relatively simple (i.e., crude)
> example. It will reparse the text whenever the text changes. It uses
> an IDocumentListener with a delay to avoid responding to every key
> stroke. For the reverse, the command stack listener calls
> which serializes the resource in memory and updates the text in the
> text editor. This is quite a brute force approach, but should serve
> as a starting point.
>> Folks,
>> My Scenario:
>> textual changes to the model in form text in TextEditor i should
>> synchronize that with the underlying model file , I am using the XML
>> editor created out of eclipse platform samples.
>> My issues are ,
>> validations now , all that i want is to make both work in sync
>> changes to Model reflected in Source and Changes to source should be
>> reflected in model.
>> Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308651 is a reply to message #308647] |
Sat, 30 September 2006 13:21   |
Originally posted by: stepper.sympedia.de
Kamesh Sampath schrieb:
> Ed,
> simpler. Will try the XSD editor.
Doesn't WTP have an XML editor? I don't use it but I'd expect that they
have text/model sync...
Cheers
/Eike
> Thanks .
> Kamesh
> Ed Merks wrote:
>> Kamesh,
>> be quite complex. The XSDEditor is a relatively simple (i.e., crude)
>> uses an IDocumentListener with a delay to avoid responding to every
>> key stroke. For the reverse, the command stack listener calls
>>> Folks,
>>> there by updating the MODEL . All my attempts are in vain .
>>> My Scenario:
>>> My issues are ,
>>> reflected in model.
>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308655 is a reply to message #308651] |
Sat, 30 September 2006 13:37   |
Eike,
Yes, WTP has a very cool SED DOM that incrementally synchronizes a DOM
structure with the textual source view of it. This in combination with
something that incrementally synchronizes an EMF model with that DOM
would be an extremely cool combination. A generated EMF editor with a
source view would be possible...
>> Ed,
> they have text/model sync...
> Cheers
> /Eike
>> Thanks .
>> Kamesh
>> Ed Merks wrote:
>>> Kamesh,
>>> crude) example. It will reparse the text whenever the text
>>> changes. It uses an IDocumentListener with a delay to avoid
>>> responding to every key stroke. For the reverse, the command stack
>>> listener calls handleStructuredModelChange whenever a command has
>>> been executed, which serializes the resource in memory and updates
>>> the text in the text editor. This is quite a brute force approach,
>>> but should serve as a starting point.
>>>> Folks,
>>>> My Scenario:
>>>> XML editor created out of eclipse platform samples.
>>>> My issues are ,
>>>> mind even the model file gets corrupted as am not enforcing any
>>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308657 is a reply to message #308655] |
Sat, 30 September 2006 13:57   |
Ed Merks schrieb:
> Eike,
> with something that incrementally synchronizes an EMF model with that
> DOM would be an extremely cool combination. A generated EMF editor
> with a source view would be possible...
Indeed. But personally I'd prefer to see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108470 addressed before ;-)
Cheers
/Eike
>>> Ed,
>> Cheers
>> /Eike
>>> Thanks .
>>> Kamesh
>>> Ed Merks wrote:
>>>> Kamesh,
>>>>> Folks,
>>>>> My Scenario:
>>>>> to say am sharing the same common EMF model.
>>>>> the model 2. TextEditor to view the model source
>>>>> TextEditor
>>>>> My issues are ,
>>>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308659 is a reply to message #308651] |
Sat, 30 September 2006 14:05   |
Ed and Eike,
Thanks for further Information . Actually i thoght of looking in to that
.. Let me do it . If am successfull i shall contribue a patch to EMF
editor generation to have an Text editor that will edit the source .
Thanks for the info .
Kamesh
>> Ed,
> Cheers
> /Eike
>> Thanks .
>> Kamesh
>> Ed Merks wrote:
>>> Kamesh,
>>>> Folks,
>>>> My Scenario:
>>>> My issues are ,
>>>> Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308661 is a reply to message #308659] |
Sat, 30 September 2006 14:57   |
Ed and Eike,
The WTP SED is cool one . We have something called the
StrucutredTextEditor , we can use that i guess. I am just looking in to
that option , once am successful i shall post the message.
Thanks.
Kamesh
> Ed and Eike,
> that .. Let me do it . If am successfull i shall contribue a patch to
> EMF editor generation to have an Text editor that will edit the source .
> Kamesh
>>> Ed,
>> Cheers
>> /Eike
>>> Thanks .
>>> Kamesh
>>> Ed Merks wrote:
>>>> Kamesh,
>>>>> Folks,
>>>>> My Scenario:
>>>>> TextEditor
>>>>> My issues are ,
>>>>> Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308663 is a reply to message #308661] |
Sat, 30 September 2006 16:01   |
Ed and Eike,
I am able to successully integrate the WTP SED with my Editor . Lots of
redundant stuff has been removed from the common TextEditor that we
develop. But am facing a peculiar problem with the same , whenever we
want to fire the PROP_DIRTY with StructuredTextEditor(WTP Text Editor)
we need to implement the Property Change listener and register the same
with WTP SED , when i do a == comparison between the source and my
initialised text editor inside my propertyChanged(Object source, int
propId) is failing , though when i print the same in the console its
same object name
* (non-Javadoc)
* @see
org.eclipse.ui.IPropertyListener#propertyChanged(java.lang.O bject,
* int)
public void propertyChanged(Object source, int propId) {
System.out.println("Source : " + source + " propID :" + propId
+ "PROP_Dirty=" + IEditorPart.PROP_DIRTY);
System.out.println("Source Editor :" + sourceEditor);
switch (propId) {
case IEditorPart.PROP_DIRTY:
case IEditorPart.PROP_INPUT: {
if (source == sourceEditor) {
if (sourceEditor.getEditorInput() != getEditorInput()) {
System.out.println("2.1");
setInput(sourceEditor.getEditorInput());
Runnable runnable = new Runnable() {
public void run() {
firePropertyChange(IEditorPart.PROP_DIRTY);
postOnDisplayQue(runnable);
break;
Can you help me why its failing ??
Kamesh
> Ed and Eike,
> to that option , once am successful i shall post the message.
> Thanks.
> Kamesh
>> Ed and Eike,
>> Kamesh
>>>> Ed,
>>> Cheers
>>> /Eike
>>>> Thanks .
>>>> Kamesh
>>>> Ed Merks wrote:
>>>>> Kamesh,
>>>>> typically be quite complex. The XSDEditor is a relatively simple
>>>>> (i.e., crude) example. It will reparse the text whenever the text
>>>>> stack listener calls handleStructuredModelChange whenever a
>>>>> command has been executed, which serializes the resource in memory
>>>>> and updates the text in the text editor. This is quite a brute
>>>>> force approach, but should serve as a starting point.
>>>>>> Folks,
>>>>>> My Scenario:
>>>>>> TextEditor
>>>>>> My issues are ,
>>>>>> Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #308666 is a reply to message #308663] |
Sat, 30 September 2006 17:12   |
Kamesh,
Should use be using .equals verses ==?
> Ed and Eike,
> same object name
> * (non-Javadoc)
> * @see
> * int)
> switch (propId) {
> getEditorInput()) {
> public void run() {
> break;
> Kamesh
>> Ed and Eike,
>> Thanks.
>> Kamesh
>>> Ed and Eike,
>>> to EMF editor generation to have an Text editor that will edit the
>>> source .
>>> Kamesh
>>>>> Ed,
>>>> Cheers
>>>> /Eike
>>>>> Thanks .
>>>>> Kamesh
>>>>> Ed Merks wrote:
>>>>>> Kamesh,
>>>>>> code (Eric Gamma's monkey-see-monkey-do principle) and it will
>>>>>> text changes. It uses an IDocumentListener with a delay to avoid
>>>>>> memory and updates the text in the text editor. This is quite a
>>>>>> brute force approach, but should serve as a starting point.
>>>>>>> Folks,
>>>>>>> My Scenario:
>>>>>>> TextEditor
>>>>>>> My issues are ,
>>>>>>> PDE editor source but its really long and very confusing to me.
>>>>>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #322402 is a reply to message #308663] |
Thu, 15 November 2007 18:19   |
Originally posted by: vasanthv16.yahoo.com
Kamesh, Ed,
I know it has been over a year since the last post on this topic, but,
any updates on this? As of now, the generated EMF multipage editor still
lacks a source editor.
Vasanth
> Ed and Eike,
> same object name
> * (non-Javadoc)
> * @see
> * int)
> switch (propId) {
> public void run() {
> break;
> Kamesh
>> Ed and Eike,
>> Thanks.
>> Kamesh
>>> Ed and Eike,
>>> Kamesh
>>>>> Ed,
>>>> Cheers
>>>> /Eike
>>>>> Thanks .
>>>>> Kamesh
>>>>> Ed Merks wrote:
>>>>>> Kamesh,
>>>>>>> Folks,
>>>>>>> My Scenario:
>>>>>>> TextEditor
>>>>>>> My issues are ,
>>>>>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #322403 is a reply to message #322402] |
Thu, 15 November 2007 18:33   |
Vasanth,
It's highly unlikely that that without active contributors from the
community this issue will get addressed directly by the vanishingly
small EMF team. It would make a great EMFT component.
Vasanth Velusamy wrote:
> Kamesh, Ed,
> still lacks a source editor.
> Vasanth
>> Ed and Eike,
>> same object name
>> * (non-Javadoc)
>> * @see
>> * int)
>> switch (propId) {
>> getEditorInput()) {
>> public void run() {
>> break;
>> Kamesh
>>> Ed and Eike,
>>> Thanks.
>>> Kamesh
>>>> Ed and Eike,
>>>> source .
>>>> Kamesh
>>>>>> Ed,
>>>>> Cheers
>>>>> /Eike
>>>>>> Thanks .
>>>>>> Kamesh
>>>>>> Ed Merks wrote:
>>>>>>> Kamesh,
>>>>>>> simple (i.e., crude) example. It will reparse the text whenever
>>>>>>> the text changes. It uses an IDocumentListener with a delay to
>>>>>>> avoid responding to every key stroke. For the reverse, the
>>>>>>> command stack listener calls handleStructuredModelChange
>>>>>>> whenever a command has been executed, which serializes the
>>>>>>> resource in memory and updates the text in the text editor.
>>>>>>> starting point.
>>>>>>>> Folks,
>>>>>>>> My Scenario:
>>>>>>>> mean to say am sharing the same common EMF model.
>>>>>>>> TextEditor
>>>>>>>> should synchronize that with the underlying model file , I am
>>>>>>>> using the XML editor created out of eclipse platform samples.
>>>>>>>> My issues are ,
>>>>>>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #322409 is a reply to message #322405] |
Fri, 16 November 2007 05:56   |
--------------060404030403070404040004
David,
Trying to usurp EMFT contributors are you?! :-P
It would be very helpful for WTP to provide SSE in a form that's more
easily consumable (i.e., with minimal dependencies).
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205892
I suspect that would require some fundamental restructuring that would
break APIs, so that's not so likely to happen even with contributor
involvement...
David Williams wrote:
> On Thu, 15 Nov 2007 18:33:53 -0500, Ed Merks <merks@ca.ibm.com> wrote:
>> Vasanth,
> Well, it's make an even better component in the WTP Incubator! :)
> But Ed's point is just as valid. It will take someone from the community several
> months of full time work to put together all the pieces we have, which
> we know is no volunteer-in-your-free-time sort of effort.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
David,<br>
<br>
Trying to usurp EMFT contributors are you?! :-P<br>
<br>
easily consumable (i.e., with minimal dependencies).<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=205892">https://bugs.eclipse.org/bugs/show_bug.cgi?id=205892</a><br>
</blockquote>
involvement...<br>
<br>
<br>
<blockquote cite="mid:op.t1vih2otac05ss@dmw2t23.ibm.com" type="cite">
<pre wrap="">On Thu, 15 Nov 2007 18:33:53 -0500, Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Vasanth,
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------060404030403070404040004--
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #322424 is a reply to message #322422] |
Fri, 16 November 2007 09:13  |
Vasanth,
I think so.
> Given that a generated Source Editor cannot be expected in the
> immediate future, what would the best way for me to implement it
> myself? Earlier in this thread, Ed mentioned using IDocumentListener.
> Is that the way to go?
> Vasanth
>>> Vasanth,
>> community several
Current Time: Fri Sep 19 09:41:05 EDT 2025
Powered by FUDForum. Page generated in 0.06084 seconds
