Home » Language IDEs » PHP Development Tools (PDT) » Impossible to install PDT using the Eclipse updater
Impossible to install PDT using the Eclipse updater [message #30816] Fri, 22 June 2007 09:54 Go to next message
Originally posted by: pobox.verysmall.org
I am fighting with this issue the last 1-2 weeks. Here are the steps to
reproduce -
1. Get Eclipse 3.2.2, unzip and run
2. Update all installed features (this downloaded 3 patches today)
3. Add PDT (http://download.eclipse.org/tools/php/updates/) to the
Updater and ask to install it
The Updater tells me that PDT Feature (1..0.0) depends on
org.eclipse.wst (2.0.0). The problem is that the officially accessible
via the Updater version of WST is 1.5.4 - so as result PDT can not be
installed with the Updater. It can be installed via manual download of
packages, but that's not the point.
Am I doing something wrong or is there something messed up?
Iavor
Re: Impossible to install PDT using the Eclipse updater [message #30851 is a reply to message #30816] Fri, 22 June 2007 10:09 Go to previous messageGo to next message
PDT 1.0.0 probably only works on Eclipse 3.3.
The site shouldn't be showing PDT 1.0.0 for an eclipse 3.2.2 install.
Dave Kelsey
Iavor Raytchev wrote:
> Hello,
> reproduce -
> Iavor
Re: Impossible to install PDT using the Eclipse updater [message #30886 is a reply to message #30851] Fri, 22 June 2007 10:18 Go to previous messageGo to next message
> Dave Kelsey
Yes.
But that's what it does. At least for me.
Iavor
Re: Impossible to install PDT using the Eclipse updater [message #30955 is a reply to message #30816] Fri, 22 June 2007 12:56 Go to previous messageGo to next message
More details -
If one downloads the PDT Runtime v. 0.7 from here -
http://download.eclipse.org/tools/pdt/downloads/?release=S20 070611-M1
And opens the feature.xml file inside, the reported version is actually
1.0.0.
Is this some kind of mess up?
Iavor
Re: Impossible to install PDT using the Eclipse updater [message #30990 is a reply to message #30816] Fri, 22 June 2007 13:07 Go to previous messageGo to next message
It seems other people have the same problem -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192518
Seems quite major. No idea why it hasn't been fixed since June 13. It
seems it is impossible to install PDT under 3.2.2 at the moment.
Iavor
Re: Impossible to install PDT using the Eclipse updater [message #31025 is a reply to message #30816] Fri, 22 June 2007 13:24 Go to previous messageGo to next message
Investigating further -
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.php-fea ture/feature.xml?root=Tools_Project&view=log
End of April and in May the version has been changed from 0.7 to 1.0.0
and dependencies to WST 2.0.0 are added. And somehow this has found its
way under the 0.7 Stable build on the web site - which makes it
impossible to install using the Updater as the Updater has access only
to 1.5.4 of WST.
Re: Impossible to install PDT using the Eclipse updater [message #31128 is a reply to message #30990] Sat, 23 June 2007 09:55 Go to previous message
I believe it's because Eclipse Europa release will be avaible in 6 days
and PDT devs had to switch to WST 2 due to some needed functionality.
Piotr
> Iavor
Previous Topic:Tabs to spaces not working within PHPDoc comments
Next Topic:Xdebug support in PDT 1.0 M1
Current Time: Fri Jul 18 13:55:37 EDT 2025
Powered by FUDForum. Page generated in 0.08074 seconds
