Home » Eclipse Projects » Nebula » [CompositeTable] 0.9.2.1 released
[CompositeTable] 0.9.2.1 released [message #26733] Mon, 05 February 2007 23:00 Go to next message
2/5/2007 Version 0.9.2.1. This is a development release to get new APIs
out as quickly as possible.
* Added delete handler method per John Ye's observation (thanks John)
* Added DeleteAdapter to help implement IDeleteHandler
* Added command API in preparation for having pluggable key bindings.
Thanks to those who have been filing bug reports! It's really appreciated.
I'm not able to get much time on Linux/GTK right now and there are some
bugs in the column moving code and in the column resizing code on that
platform. I also have *no* access to MacOS. If anyone has access to
those platforms and can help debug on those platforms, everyone would
really appreciate your help!
Thanks much again to *everyone* around here. You all are great!
Dave
Senior Consultant, Trainer
Coconut Palm Software, Inc.
http://www.coconut-palm-software.com
Re: [CompositeTable] 0.9.2.1 released [message #30848 is a reply to message #26733] Mon, 05 March 2007 19:39 Go to previous message
David,
I have played with moving/resizing on Linux/GTK (CompositeTableSnippet5).
1) Moving
The Move event is skipped in the HeaderLayout$HeaderControlListener
class after the Resize event.
This doesn't work correctly on Linux/GTK.
This is the solution:
HeaderLayout$HeaderControlListener.java
private class HeaderControlListener implements ControlListener {
public void controlMoved(ControlEvent e) {
// Eat the move event that is fired after resize events
// on non-gtk platforms
if (! SWT.getPlatform().equals("gtk") && wasResized) {
wasResized = false;
return;
Table table = header.headerTable;
fireColumnMovedEvent(table.getColumnOrder());
storeLastWidths(table);
2) Resizing and showing
Linux/GTK (and XWindows) handles scrolling events in a specific way and
the solution which works on Windows, doesn't work on Linux.
There is a solution which, maybe, isn't elegant (extending Table), but
it works.
Linux/GTK supports non-scrollable tables. In order to create header (in
the constructor of the AbstractNativeHeader class),we can use the
following control instead of the SWT Table control:
package org.eclipse.swt.widgets;
import org.eclipse.swt.SWT;
public class GtkTableHeader extends Table {
int originalStyle;
public GtkTableHeader(Composite parent, int style) {
super(parent, style);
originalStyle = style;
protected void checkSubclass() {
void createWidget(int index) {
style = originalStyle;
style |= SWT.FULL_SELECTION;
style = checkBits(style, SWT.SINGLE, SWT.MULTI, 0, 0, 0, 0);
super.createWidget(index);
This class won't be compiled against win32 swt (win32 swt controls use
the createWidget() method instead of createWidget(int index)).
Snjeza
> Regards,
> Dave
Re: [CompositeTable] 0.9.2.1 released [message #579536 is a reply to message #26733] Mon, 05 March 2007 19:39 Go to previous message
David,
1) Moving
wasResized = false;
return;
it works.
int originalStyle;
Snjeza
> Regards,
> Dave
Previous Topic:Cancelling PShelf selection
Next Topic:Grid column resizing
Current Time: Sun Jun 22 17:03:33 EDT 2025
Powered by FUDForum. Page generated in 0.07729 seconds
