Home » Eclipse Projects » Subversive » change sets and create patch problem
change sets and create patch problem [message #27080] Wed, 30 July 2008 18:49 Go to next message
Originally posted by: noah.roberts.eng-software.com
With subclipse I can right click, chose "Create patch..." and put it on
the clipboard. Then I can attach it to a mylyn task in bugzilla.
With subversive this menu item does not appear. When I first start
eclipse I see a Local->Create Patch... menu item. It makes a patch on
the filesystem. Then I never see this menu item again nor the "Local"
tree item where it resides. I therefore have no Branch menu item either.
I have hunted around in google, I'm about the only person that shows in
there mentioning this problem...I posted to "newcomer".
The menu items appear just fine in the Team menu off the project. I
want to integrate this with mylyn and have a sort of code review thing
going on. Developer attaches patch, another looks it over and labels
the bug fix as reviewed. To make sure changes are related to the task
it would be benificial to have the change-set menu working as well.
The documentation says I should see it...I don't. I ran into a few
clues I tried...I upgraded svn, used the 1.2.0 version of subversive,
and installed the JavaHL thingy....1.5 Behavior hasn't changed.
Ideas?
Re: change sets and create patch problem [message #27157 is a reply to message #27080] Thu, 31 July 2008 02:56 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Noah,
The Subversive 1.2.0 version is an very old experimental version which do
not supports Eclipse 3.4 version (but I'm not sure what version of Eclipse
IDE you use because I found no corresponding information in your post).
The latest Subversive version is distributed from the Eclipse.org site.
SVN connectors for this version still distributed from the Polarion.org
site. More about the latest Subversive version you can read at:
http://www.eclipse.org/subversive/downloads.php
But in any case Create Patch menu item must be shown even with the old
Subversive 1.2.0 version. So, please try installing of the latest
Subversive version into the clean Eclipse IDE instance.
Re: change sets and create patch problem [message #27235 is a reply to message #27157] Thu, 31 July 2008 12:33 Go to previous messageGo to next message
Alexander Gurov wrote:
> Hello Noah,
> do not supports Eclipse 3.4 version (but I'm not sure what version of
> Eclipse IDE you use because I found no corresponding information in your
> post).
I'm using the subversion from the ganymede distribution. I had to
download connectors. The SVNKit has two versions, 1.1.7 and 1.2.0 - I
tried both. Everything seems to have a build version of
2.0.1.I20080612-1500. As far as I can tell I'm using the latest version
of everything. The link you provided doesn't have any update sites I'm
not using that I can see.
I get a create patch menu item in the project explorer area. Where I'm
not getting it and want it is in the sych view where I'm using mylyn to
group change-sets by task.
Re: change sets and create patch problem [message #27272 is a reply to message #27235] Fri, 01 August 2008 02:58 Go to previous messageGo to next message
Thank you for detailed information. Yes, Subversive version which is
distributed from the Ganymede update site is 0.7.1.I20080612-1500 and
2.0.1.I20080612-1500 is the version of corresponding connectors).
Subversive provides access to all applicable actions in the Synchronize
View context. So, in order to create patch from the Synchronize View
please first call pop-up menu, then use menu item "Local->Create Patch...".
Re: change sets and create patch problem [message #28077 is a reply to message #27272] Fri, 01 August 2008 11:20 Go to previous messageGo to next message
>> I'm not getting it and want it is in the sych view where I'm using
>> mylyn to group change-sets by task.
Sigh, it just bugs the hell out of me when I get directions to do
something when I've made it clear the problem is NOT my failure to
understand documentation. From my original post:
"With subversive this menu item does not appear. When I first start
tree item where it resides. I therefore have no Branch menu item either."
Re: change sets and create patch problem [message #28116 is a reply to message #28077] Fri, 01 August 2008 12:55 Go to previous messageGo to next message
Noah Roberts <noah.roberts@eng-software.com> writes:
> either."
I am not sure that the original post specifically said that it is the
context (right button) menu in the Synchronize view in the Team
Synchronizing perspective that is the issue.
I can reproduce the problem. The first time I activate the context
menu in the Synchronize view it has "Local" and "Remote" sub-menus. If
I dismiss the menu without selecting anything (click outside it) then
activate it again the "Local" and "Remote" sub-menus do not appear.
You can get them back by closing the Synchronize view and then opening
it again using "Window/Show view". Closing and reopening the
perspective also brings them back. In either case, they vanish again
as soon as the menu has appeared once.
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: change sets and create patch problem [message #28154 is a reply to message #28116] Fri, 01 August 2008 14:28 Go to previous messageGo to next message
>> either."
You don't have to click outside. You can choose to create a patch too.
Perhaps other things, I don't know (I just tried "Show properties" and
it does the same). The whole submenu and everything under it go away.
Furthermore, the create patch menu item in the _context menu of the
synchronize view_ (I've never seen "Local" any other place) won't create
a patch into the clipboard like it should, like subclipse does and
subversive does in the _context menu of the project explorer_. It just
puts you into an output to file dialog.
It's broken, almost completely. It's too bad really, the subversive
interface to branching and tagging is much, much better.
Re: change sets and create patch problem [message #28269 is a reply to message #28154] Mon, 04 August 2008 05:28 Go to previous messageGo to next message
Hello Noah, Owen,
Thank you for the steps to reproduce. The problem really exists in the
Eclipse 3.4 and we will investigate this issue.
Re: change sets and create patch problem [message #29473 is a reply to message #28269] Tue, 05 August 2008 11:33 Go to previous messageGo to next message
Thank you all,
The problem is fixed and fix will be available in the weekly build.
Re: change sets and create patch problem [message #29540 is a reply to message #29473] Tue, 05 August 2008 12:02 Go to previous messageGo to next message
> Thank you all,
Will that be in the update site?
Re: change sets and create patch problem [message #29567 is a reply to message #29540] Tue, 05 August 2008 12:07 Go to previous messageGo to next message
Hello Noah,
The fix will be published on the ".../weekly-site" update sites like and
all other fixes until critical set of fixes is collected or graduation is
complete.
Re: change sets and create patch problem [message #29986 is a reply to message #29567] Tue, 05 August 2008 12:39 Go to previous messageGo to next message
> Hello Noah,
> is complete.
OK, well I'll just have to track that down I guess.
Re: change sets and create patch problem [message #30828 is a reply to message #29473] Fri, 08 August 2008 13:12 Go to previous messageGo to next message
> Thank you all,
Well, I got the update.
The menu appears all the time now but the create patch command from the
synchronize menu still does not give me the option to create it in the
clipboard. It takes me directly to a file save dialog.
In all other places and with other source control plugins you get this
dialog:
http://i42.photobucket.com/albums/e306/nroberts-photos/patch .png
Re: change sets and create patch problem [message #31071 is a reply to message #30828] Mon, 11 August 2008 05:11 Go to previous messageGo to next message
Hello Noah,
Corresponding task was added to the Subversive Bugzilla:
243713: Use standard create patch dialog in Synchronize View
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243713
Re: change sets and create patch problem [message #31208 is a reply to message #31071] Mon, 11 August 2008 11:25 Go to previous messageGo to next message
> Hello Noah,
Thank you.
Re: change sets and create patch problem [message #31989 is a reply to message #31071] Thu, 14 August 2008 14:35 Go to previous message
> Hello Noah,
That was fast. Thanks!
Previous Topic:Install-Problems or Who is responsible for this site
Next Topic:Migration from Polarion version to Eclipse version fails with Eclipse 3.3
Current Time: Sat Jul 26 19:58:09 EDT 2025
Powered by FUDForum. Page generated in 0.06694 seconds
