Home » Archived » EPF » Published Process Issues
Published Process Issues [message #30054] Fri, 16 February 2007 02:07 Go to next message
1) The navigation path (Top of each screen) is created only for the
framework view. For rest of the standard category view or the custom
categories view, we are able to see the navigation path generated. How to
get this?
2) We created a discipline view and when the task page is opened from this
view for a discipline the information for a particular task say 'X' is
different of the same what we see in the Delivery process or the framework
view. But when we looked in detail, the delivery process shows the task as
task descriptor and the discipline views shows as TASKS. Information that
gets lost is ASSITED ROLES, EXTERNAL Inputs. But ideally in the published
output for a same task if I navigate through any view we should be landing
in the same task page.
3) Similarly when we don’t give step descriptions, we hope it's not
required to display the expand buttons. What happens now is, it publishes
with the expand and collapse buttons for each step and on expansion it
shows a line for empty descriptions.
4) There should be an option to change the table section heading
names,specific to the orgaisation. EX: Illustrations is some thing we dont
use in our organisation. But If I need to change, currently i need to open
every individual html page and do the changes. I am not sure if there is a
easy way to do it.
Re: Published Process Issues [message #30483 is a reply to message #30054] Thu, 01 March 2007 21:48 Go to previous messageGo to next message
Originally posted by: phaumer.xxx.com
(2) A Task Descriptor is an occurrence of a Task in a process. The Task
itself is defined independent of a particular process. A Task's
relationships represent defaults for their occurrence in the process.
However, the descriptor has additional relationships that we felt only make
sense in a particular process context. For example, that an artifact is an
external input for a task descriptor (i.e. it is not produced by any other
task in the same process) is context specific. The default task just
defines the general inputs required in general to do the work. Only the
process can define if these inputs are provided by other tasks in the
process or made available through external sources.
(4) Currently there is no way to not publish information that was entered
into the forms. If a form field is empty it will not publish it, but if
content was provided, it will publish it. To remove fields you could modify
the XSL files in the code.
Thanks and best regards,
Peter Haumer.
____________________________________________________________ __
PETER HAUMER
IBM | Eclipse Process Framework Committer
"Sarav" <Saravanan.Sankar@cognizant.com> wrote in message
news:aa4e50931b6d578ef160d967747fcedf$1@www.eclipse.org...
> get this?
Re: Published Process Issues [message #30826 is a reply to message #30483] Thu, 15 March 2007 05:49 Go to previous message
I would not agree completely with point 4 reply. It works only for Form
fields. But when we dont select the Check boxes for propoerties like
Optional/Multiple Occurence etc for Tasks....and publish the process, it
just publishes for all the tasks with a table with all these properties as
empty cells.
How will we disable this before publishing.
Re: Published Process Issues [message #576741 is a reply to message #30054] Thu, 01 March 2007 21:48 Go to previous message
Peter Haumer.
PETER HAUMER
> get this?
Re: Published Process Issues [message #577084 is a reply to message #30483] Thu, 15 March 2007 05:49 Go to previous message
empty cells.
Previous Topic:Can't get update manager to function correctly
Next Topic:Problems when exporting data (WBS, actors) from EPF composer
Current Time: Fri Jul 18 19:55:54 EDT 2025
Powered by FUDForum. Page generated in 0.04135 seconds
