[PDE Build] separate JDKs for build and test? [message #308077] |
Mon, 11 September 2006 20:47  |
Can one, e.g., build sources with a 1.4 JDK and run BVT with a 1.5
JDK? If so, what properties would need set, and where?
Please reply directly to me (as well as the newsgroup) if possible,
feel free to forward, and TIA.
Re: [PDE Build] separate JDKs for build and test? [message #308099 is a reply to message #308077] |
Tue, 12 September 2006 11:51  |
Tom,
I don't know how tests are run, but a build can compile against
arbitrary JDKs independent of which jre is used to run the build.
By default, the boot classpath for compiling is just
${java.home}\lib\*.jar, but the builder configuration build.properties
can change the default with the property "bootclasspath".
As well, the JDK to compile against can be controlled on a per bundle
basis, see details here:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. pde.doc.user/guide/tasks/pde_compilation_env.htm
-Andrew
FUDForum. Page generated in 1.12266 seconds
