XML output merging [message #30803] |
Tue, 14 August 2007 08:30  |
Given the following example structure of a model:
<module name="A">
<component name="1"/>
<component name="2"/>
</module>
I should be able to generate the components individually (transformations
are invoked separately). But I also need to generate a common XML file.
For example:
1. Generate component 1.
2. The output of the common XML file is:
<root>
<componentlist module="A">
<app>1</app>
</componentlist>
</root>
3. Generate component 2.
4. The expected output of the common XML file is:
<root>
<app>1</app>
<app>2</app>
</componentlist>
</root>
Question: How do I achieve this in JET? Is it possible to do xml merging?
I'm using version 0.7.1.
Francis
Re: XML output merging [message #30979 is a reply to message #30909] |
Tue, 14 August 2007 11:01   |
Ed,
Thanks for the reply. If I understood it correctly, the solution below
works when the module-level model is available in the transformation, or
when all components are available. But in the case where only the specific
component is available in the model passed to the template as input, can
that entry be merged if the common xml file is already existing?
BR,
Francis
Ed Merks wrote:
> Francis,
> It would seem that for the common thing, you'd have module A as the
> input and that would invoke that once for the module, while for the
> component-level thing, you'd have each component as the input to the
> template and do it once per component...
>> <module name="A">
>> </module>
>> (transformations are invoked separately). But I also need to generate
>> a common XML file. For example:
>> <root>
>> <app>1</app>
>> </componentlist>
>> </root>
>> <root>
>> <app>1</app>
>> <app>2</app>
>> </componentlist>
>> </root>
>> merging? I'm using version 0.7.1.
>> Thanks,
>> Francis
Re: XML output merging [message #31052 is a reply to message #30979] |
Tue, 14 August 2007 13:13   |
Francis,
Nothing generic is going to be smart enough to know how to merge the
specific results properly.
Francis wrote:
> Ed,
> or when all components are available. But in the case where only the
> specific component is available in the model passed to the template as
> input, can that entry be merged if the common xml file is already
> existing?
> BR,
> Francis
> Ed Merks wrote:
>> Francis,
>>> <module name="A">
>>> </module>
>>> generate a common XML file. For example:
>>> <root>
>>> <app>1</app>
>>> </componentlist>
>>> </root>
>>> <root>
>>> <app>1</app>
>>> <app>2</app>
>>> </componentlist>
>>> </root>
>>> Thanks,
>>> Francis
Re: XML output merging [message #31744 is a reply to message #31644] |
Tue, 28 August 2007 12:45  |
Thanks Paul and Ed, I agree that merging specific xml content needs
specific logic. At first I thought it was possible to use something
similar to jmerge with regular expressions. Thanks for the tip about the
load-and-modify approach.
Francis
FUDForum. Page generated in 0.04621 seconds
