Home » Archived » OHF » STEM integration Mac
STEM integration Mac [message #30315] Thu, 14 June 2007 16:44 Go to next message
Originally posted by: vega42.gmail.com
--------------090004030801090403070902
I'm migrating this discussion from the [ohf-dev] mailing-list, where I
have discussed problems getting STEM running under MacOsX. After some
initial problems integrating STEM with the SWT I'am able to start
stem.ui for test purposes in the mean time.
However, it appears that although the simulation runs in the
background the ui doesn't refresh properly.
Dan: Your suggestion to turn up the cycle delay in the preference pane
hasn't worked - same situation. Also exporting stem.ui instead of
running it as RCP results in the same problems.
I have attached the stem.iu error log for further insight. There
appears to be I considerable amount of errors logged here although I
have to admit that I can hardly make sense out of half of them.
Perhaps someone (Dan?), who's deeper into the project might understand more.
thx
Vincent
BTW: How far should X11 help? I'm under the impression, that it makes a
difference, if it's on or not (although using swt.carbon), but I would
need to check.
Content-Type: text/plain; x-mac-type="0"; x-mac-creator="0";
name="log.log"
Content-Disposition: inline;
filename="log.log"
!SESSION 2007-06-12 18:39:26.844 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_07
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
Framework arguments: -product org.eclipse.ohf.stem.ui.product
Command-line arguments: -product org.eclipse.ohf.stem.ui.product -data /Users/vincent/Documents/STEM/../runtime-stem.product -dev file:/Users/vincent/Documents/STEM/.metadata/.plugins/org.ec lipse.pde.core/stem.product/dev.properties -os macosx -ws carbon -arch x86 -debug -consoleLog
!ENTRY org.eclipse.osgi 2 0 2007-06-12 18:39:29.420
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:39:29.421
!MESSAGE Bundle update@plugins/org.eclipse.jdt.compiler.apt_1.0.0.v20070510-2000.jar [369] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-12 18:39:29.421
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.tool_0.0.0.
!MESSAGE Bundle update@plugins/org.eclipse.jdt.compiler.tool_1.0.0.v_770.jar [370] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-12 18:39:29.422
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: JavaSE-1.6
!ENTRY org.eclipse.osgi 4 0 2007-06-12 18:39:29.536
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: no swt-carbon-3345 or swt-carbon in swt.library.path, java.library.path or the jar file
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:21 9)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:15 1)
at org.eclipse.swt.internal.C.<clinit>(C.java:21)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:9 43)
at org.eclipse.swt.widgets.Display.create(Display.java:937)
at org.eclipse.swt.graphics.Device.<init>(Device.java:119)
at org.eclipse.swt.widgets.Display.<init>(Display.java:749)
at org.eclipse.swt.widgets.Display.<init>(Display.java:740)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:498)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
at org.eclipse.ohf.stem.core.common.presentation.CoreEditorAdvi sor$Application.start(CoreEditorAdvisor.java:109)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
!ENTRY org.eclipse.osgi 2 0 2007-06-12 18:39:29.545
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:39:29.545
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-12 18:39:29.546
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:39:29.546
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-12 18:39:29.547
!SESSION 2007-06-12 18:50:22.200 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2007-06-12 18:50:25.002
!STACK 1
!ENTRY org.eclipse.osgi 2 0 2007-06-12 18:50:25.024
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:50:25.024
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-12 18:50:25.024
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:50:25.025
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-12 18:50:25.025
!SESSION 2007-06-13 10:27:11.555 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2007-06-13 10:27:14.257
!STACK 1
java.lang.UnsatisfiedLinkError: PTR_sizeof
at org.eclipse.swt.internal.C.PTR_sizeof(Native Method)
at org.eclipse.swt.internal.C.<clinit>(C.java:24)
!ENTRY org.eclipse.osgi 2 0 2007-06-13 10:27:14.287
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 10:27:14.287
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-13 10:27:14.288
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 10:27:14.288
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-13 10:27:14.288
!SESSION 2007-06-13 11:30:19.806 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2007-06-13 11:30:21.462
!STACK 1
!ENTRY org.eclipse.osgi 2 0 2007-06-13 11:30:21.486
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 11:30:21.487
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-13 11:30:21.487
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-13 11:30:21.487
!SESSION 2007-06-13 11:56:50.023 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 0 2007-06-13 11:56:51.736
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 11:56:51.736
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-13 11:56:51.737
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 11:56:51.737
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-13 11:56:51.737
!SESSION 2007-06-13 12:47:29.441 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 0 2007-06-13 12:47:31.952
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 12:47:31.952
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-13 12:47:31.953
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 12:47:31.953
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-13 12:47:31.953
!ENTRY org.eclipse.ui 4 0 2007-06-13 12:47:34.910
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NoClassDefFoundError: org/eclipse/swt/internal/carbon/OS)
at org.eclipse.swt.SWT.error(SWT.java:3563)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3212)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2956)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ohf.stem.core.common.presentation.CoreEditorAdvi sor$Application.start(CoreEditorAdvisor.java:111)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/internal/carbon/OS
at org.eclipse.ui.carbon.CarbonUIEnhancer.hookApplicationMenu(C arbonUIEnhancer.java:242)
at org.eclipse.ui.carbon.CarbonUIEnhancer.access$2(CarbonUIEnha ncer.java:228)
at org.eclipse.ui.carbon.CarbonUIEnhancer$1.run(CarbonUIEnhance r.java:136)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockL istener.java:155)
at org.eclipse.ui.internal.UISynchronizer$2.run(UISynchronizer. java:126)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 23 more
!SESSION 2007-06-13 12:50:01.004 -----------------------------------------------
!ENTRY org.eclipse.ui 4 0 2007-06-13 12:50:06.156
!STACK 0
... 23 more
!SESSION 2007-06-14 16:21:14.868 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 0 2007-06-14 16:21:19.061
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-14 16:21:19.061
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-14 16:21:19.062
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-14 16:21:19.062
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-14 16:21:19.063
!SESSION 2007-06-14 17:03:50.132 -----------------------------------------------
!ENTRY org.eclipse.ohf.stem.ui.ge 1 0 2007-06-14 17:04:33.427
!MESSAGE EXCEPTION java.io.IOException: Server returned HTTP response code: 500 for URL: http://127.0.0.1:56259/STEM/verify: Server returned HTTP response code: 500 for URL: http://127.0.0.1:56259/STEM/verify
!ENTRY org.eclipse.ohf.stem.ui.ge 4 0 2007-06-14 17:04:33.445
!MESSAGE StemKml: Unable to communicate with web server @ http://127.0.0.1:56259
!ENTRY org.eclipse.ohf.stem.ui.ge 4 0 2007-06-14 17:04:33.464
!MESSAGE GoogleEarth Servlet support disabled
--------------090004030801090403070902--
Re: STEM integration Mac [message #30350 is a reply to message #30315] Fri, 15 June 2007 07:42 Go to previous messageGo to next message
since it's kind of quit around here I will try to help myself and let
you know! :)
Soooo, my plan is now to check out a the gtk-engine instead of the
standard MacOsX carbon engine. I figure since I'm dealing with ui
problems here and know, that they don't appear under Linux using gtk
this might be a good idea.
Furthermore I'm aware of other product such as Matlab from Mathworks,
which take this track (also Java-based).
Looking forward to a flourishing discussion regarding my home-grown
problems. ;-)
Vincent
> more.
> thx
> Vincent
> need to check.
Re: STEM integration Mac [message #30386 is a reply to message #30350] Fri, 15 June 2007 11:55 Go to previous messageGo to next message
yay,
I made it. It appears that they're issues regarding the integration of
swt under MacOsX. These can be solved by either patching JavaSDK 1.5 or
switching entirely to JavaSDK 1.6.
After doing latter and instructing Eclipse to use the new version in
Preferences->Compiler everything runs nice and smooth.
I will hence close the related bug-report and in case you guys are
interested in any further information to update your installation
procedures just let me know.
Furhert information can be found on developer.apple.com:
http://adcdownload.apple.com/Java/swt_compatibility_librarie s_for_j2se_5.0_release_4/swtcompatibilityreadme.html
and
http://adcdownload.apple.com/Java/java_se_6.0_release_1_deve loper_preview_6/javase6r1dp6releasenotes.html
although I think you need an account to access these sites.
cheers
Vincent
> you know! :)
> problems. ;-)
> Vincent
>> more.
>> thx
>> Vincent
>> a difference, if it's on or not (although using swt.carbon), but I
>> would need to check.
Re: STEM integration Mac [message #30421 is a reply to message #30386] Fri, 15 June 2007 22:54 Go to previous messageGo to next message
Originally posted by: jthomas119_NOSPAM_.gmail.com
Vincent,
That is great. Thank you for pursuing this.
Sorry that we were not of much help. Dan is on a business trip in
France and I am on vacation in Montana. And we are woefully inadequate
when it comes to MacOS. We almost bought a Mac recently for my wife's
movie editing hobby and now I wish we had. I wish eclipse ran on an
IPhone so I could justify buying one of those. :-)
I will update the Installation guide on the OHF Wiki to indicate that
for MacOS, one should install Java 1.6.
I guess that there are also some needed changes to the product file to
pick up the various macos unique files. Could you send me your MacOS
version of stem.product?
Thanks again.
Vincent David wrote:
> yay,
> and
> cheers
> Vincent
>> Hi,
>> you know! :)
>> problems. ;-)
>> Vincent
>>> understand more.
>>> thx
>>> Vincent
Re: STEM integration Mac [message #30455 is a reply to message #30421] Sat, 16 June 2007 16:55 Go to previous messageGo to next message
--------------090901070509020307030708
John Thomas schrieb:
> Vincent,
Sure. You will find a export of stem.product attached. I think all one
really needs besides the new JavaSDK is the swt.carbon plug-in. Let me
know if you guys are interested in a stand-alone version. I think I
could send you something like this.
Vincent
> Thanks again.
>> yay,
>> or switching entirely to JavaSDK 1.6.
>> and
>> cheers
>> Vincent
>>> Hi,
>>> you know! :)
>>> problems. ;-)
>>> Vincent
>>>> understand more.
>>>> thx
>>>> Vincent
>>>> makes a difference, if it's on or not (although using swt.carbon),
>>>> but I would need to check.
Content-Type: text/xml; x-mac-type="0"; x-mac-creator="0";
name="stem.product_MacOSX"
filename="stem.product_MacOSX"
<?pde version="3.1"?>
<product name="STEM (Incubation)" id="org.eclipse.ohf.stem.ui.product" application="org.eclipse.ohf.stem.ui.CoreEditorAdvisorApplication " useFeatures="false">
<aboutInfo>
<image path="/org.eclipse.ohf.stem.ui/branding/ohf64_64_32.gif"/>
<text>
OHF Spatio-Temporal Epidemological/Event Modeler (STEM)
</text>
</aboutInfo>
<configIni use="custom" path="plugin_customization.ini"/>
<launcherArgs>
<programArgs>-debug -consoleLog</programArgs>
<vmArgs>-Xms512M -Xmx512M</vmArgs>
</launcherArgs>
<windowImages i16="/org.eclipse.ohf.stem.ui/branding/ohf16_16_32.gif" i32="/org.eclipse.ohf.stem.ui/branding/ohf32_32_32.gif" i48="/org.eclipse.ohf.stem.ui/branding/ohf48_48_32.gif" i64="/org.eclipse.ohf.stem.ui/branding/ohf64_64_32.gif" i128="/org.eclipse.ohf.stem.ui/branding/ohf128_128_32.gif"/ >
<splash
location="org.eclipse.ohf.stem.ui"
startupProgressRect="0,413,431,15"
startupMessageRect="10,380,431,20"
startupForegroundColor="FFFFFF" />
<launcher name="STEM">
<solaris/>
<win useIco="false">
<bmp
winSmallLow="/org.eclipse.ohf.stem.ui/branding/ohf16_16_8.bmp "
winMediumLow="/org.eclipse.ohf.stem.ui/branding/ohf32_32_8.bmp "
winLargeLow="/org.eclipse.ohf.stem.ui/branding/ohf48_48_8.bmp "/>
</win>
</launcher>
<vm>
</vm>
<plugins>
<plugin id="com.ibm.icu"/>
<plugin id="com.lowagie.itext"/>
<plugin id="javax.servlet"/>
<plugin id="javax.servlet.jsp"/>
<plugin id="org.apache.ant"/>
<plugin id="org.apache.batik.pdf"/>
<plugin id="org.apache.commons.codec"/>
<plugin id="org.apache.commons.el"/>
<plugin id="org.apache.commons.logging"/>
<plugin id="org.apache.jasper"/>
<plugin id="org.apache.lucene"/>
<plugin id="org.apache.lucene.analysis"/>
<plugin id="org.apache.xerces"/>
<plugin id="org.apache.xml.resolver"/>
<plugin id="org.eclipse.ant.core"/>
<plugin id="org.eclipse.birt.chart.device.extension"/>
<plugin id="org.eclipse.birt.chart.device.svg"/>
<plugin id="org.eclipse.birt.chart.device.swt"/>
<plugin id="org.eclipse.birt.chart.engine"/>
<plugin id="org.eclipse.birt.chart.engine.extension"/>
<plugin id="org.eclipse.birt.chart.ui"/>
<plugin id="org.eclipse.birt.chart.ui.extension"/>
<plugin id="org.eclipse.birt.core"/>
<plugin id="org.eclipse.birt.core.ui"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.core.filesystem"/>
<plugin id="org.eclipse.core.filesystem.macosx" fragment="true"/>
<plugin id="org.eclipse.core.filesystem.win32.x86"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.net"/>
<plugin id="org.eclipse.core.resources"/>
<plugin id="org.eclipse.core.resources.compatibility" fragment="true"/>
<plugin id="org.eclipse.core.resources.win32"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility.auth"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry" fragment="true"/>
<plugin id="org.eclipse.core.variables"/>
<plugin id="org.eclipse.emf.common"/>
<plugin id="org.eclipse.emf.common.ui"/>
<plugin id="org.eclipse.emf.ecore"/>
<plugin id="org.eclipse.emf.ecore.change"/>
<plugin id="org.eclipse.emf.ecore.xmi"/>
<plugin id="org.eclipse.emf.edit"/>
<plugin id="org.eclipse.emf.edit.ui"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.http.jetty"/>
<plugin id="org.eclipse.equinox.http.registry"/>
<plugin id="org.eclipse.equinox.http.servlet"/>
<plugin id="org.eclipse.equinox.jsp.jasper"/>
<plugin id="org.eclipse.equinox.jsp.jasper.registry"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.help.appserver"/>
<plugin id="org.eclipse.help.base"/>
<plugin id="org.eclipse.help.ui"/>
<plugin id="org.eclipse.help.webapp"/>
<plugin id="org.eclipse.jdt.compiler.apt" fragment="true"/>
<plugin id="org.eclipse.jdt.compiler.tool" fragment="true"/>
<plugin id="org.eclipse.jdt.core"/>
<plugin id="org.eclipse.jface"/>
<plugin id="org.eclipse.jface.databinding"/>
<plugin id="org.eclipse.jface.text"/>
<plugin id="org.eclipse.ohf.stem.core"/>
<plugin id="org.eclipse.ohf.stem.definitions"/>
<plugin id="org.eclipse.ohf.stem.diseasemodels"/>
<plugin id="org.eclipse.ohf.stem.diseases"/>
<plugin id="org.eclipse.ohf.stem.geography"/>
<plugin id="org.eclipse.ohf.stem.jobs"/>
<plugin id="org.eclipse.ohf.stem.jobs.nl1" fragment="true"/>
<plugin id="org.eclipse.ohf.stem.sequencers"/>
<plugin id="org.eclipse.ohf.stem.ui"/>
<plugin id="org.eclipse.ohf.stem.ui.diseasemodels"/>
<plugin id="org.eclipse.ohf.stem.ui.ge"/>
<plugin id="org.eclipse.ohf.stem.ui.nl1" fragment="true"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.osgi.util"/>
<plugin id="org.eclipse.pde.runtime"/>
<plugin id="org.eclipse.swt"/>
<plugin id="org.eclipse.swt.carbon.macosx" fragment="true"/>
<plugin id="org.eclipse.swt.gtk.linux.x86" fragment="true"/>
<plugin id="org.eclipse.swt.win32.win32.x86"/>
<plugin id="org.eclipse.team.core"/>
<plugin id="org.eclipse.text"/>
<plugin id="org.eclipse.tomcat"/>
<plugin id="org.eclipse.ui"/>
<plugin id="org.eclipse.ui.carbon" fragment="true"/>
<plugin id="org.eclipse.ui.forms"/>
<plugin id="org.eclipse.ui.ide"/>
<plugin id="org.eclipse.ui.views"/>
<plugin id="org.eclipse.ui.win32"/>
<plugin id="org.eclipse.ui.workbench"/>
<plugin id="org.eclipse.update.configurator"/>
<plugin id="org.eclipse.update.core"/>
<plugin id="org.eclipse.update.core.win32"/>
<plugin id="org.eclipse.update.ui"/>
<plugin id="org.eclipse.xsd"/>
<plugin id="org.junit"/>
<plugin id="org.mortbay.jetty"/>
<plugin id="org.mozilla.rhino"/>
<plugin id="org.w3c.dom"/>
</plugins>
</product>
--------------090901070509020307030708--
Re: STEM integration Mac [message #30629 is a reply to message #30455] Mon, 18 June 2007 14:15 Go to previous messageGo to next message
Vincent,
thanks for your great help! Just another example of the power of open
source. We'll put up a Mac version for download soon thanks to you.
Also, my apologies for the "quiet period", I was traveling back to the USA
from France...
As for the error messages on the console, they magically appeared when we
switched from 3.2.2 to Europa 3.3. I've done some initial investigation
into them, but nothing made much sense and some appeared and some
disappeared. I decided to wait until things are "stable" when 3.3 is
released and then try to kill them off.
Let us know what you think. We're planning some major new features for the
next milestone and would like input to help prioritize our efforts.
Dan
Re: STEM integration Mac [message #30699 is a reply to message #30629] Mon, 18 June 2007 23:19 Go to previous messageGo to next message
I have updated the Installation Guide on the Eclipse OHF STEM Wiki so
that it makes note of the requirement to use Java 1.6 and suggests using
the stemMacOS.product to launch STEM from Eclipse.
http://wiki.eclipse.org/index.php/Installation_Guide#STEM_In stallation_Guide
Hopefully the next person to try out STEM on the Mac will have a more
positive experience.
John
Re: STEM integration Mac [message #30735 is a reply to message #30699] Tue, 19 June 2007 15:21 Go to previous messageGo to next message
I looked at using the new stemMacOS.product file to generate a release for
the Mac, but I'm not being successful...yet. My windows installation is
missing the necessary plugins (e.g., org.eclipse.swt.carbon.macosx, etc.).
I understand that I need to install the RCP delta pack, but I looked and
could not find that for Europa (not released yet?)
Does anyone have any insight?
Dan
Re: STEM integration Mac [message #30948 is a reply to message #30735] Sat, 23 June 2007 08:56 Go to previous messageGo to next message
Hey Dan,
just came back from a trip yesterday, so I can reply only now to your
request.
release for the Mac, but I'm not being successful...yet. My windows
installation is missing the necessary plugins (e.g.,
Additionally to the STEM-plugins I checked out the packages:
org.eclipse.swt
the ...carbon.macosx is deprecated. I'm not aware of any additional RCP
packs. I only needed the basic RC3.3 (called Europe).
If you have any further questions please let me know.
Vincent
and could not find that for Europa (not released yet?)
> Thanks
> Dan
Re: STEM integration Mac [message #31123 is a reply to message #30948] Tue, 10 July 2007 13:19 Go to previous message
Ok, I'm back from vacation. I've got Europa installed and will try to find
a moment to try this again. Of course, I'm back on the road this Thursday
and not back again until next Wed (July 18).
Dan
"Vincent David" <vega42@gmail.com> wrote in message
news:f5j597$1qu$1@build.eclipse.org...
> Hey Dan,
> request.
> org.eclipse.swt
> Vincent
> > Thanks
> > Dan
Re: STEM integration Mac [message #578978 is a reply to message #30315] Fri, 15 June 2007 07:42 Go to previous message
you know! :)
problems. ;-)
Vincent
> more.
> thx
> Vincent
> need to check.
Re: STEM integration Mac [message #579015 is a reply to message #30350] Fri, 15 June 2007 11:55 Go to previous message
yay,
and
cheers
Vincent
> you know! :)
> problems. ;-)
> Vincent
>> more.
>> thx
>> Vincent
Re: STEM integration Mac [message #579033 is a reply to message #30386] Fri, 15 June 2007 22:54 Go to previous message
Vincent,
Thanks again.
> yay,
> and
> cheers
> Vincent
>> Hi,
>> you know! :)
>> problems. ;-)
>> Vincent
>>> understand more.
>>> thx
>>> Vincent
Re: STEM integration Mac [message #579054 is a reply to message #30421] Sat, 16 June 2007 16:55 Go to previous message
> Vincent,
Vincent
> Thanks again.
>> yay,
>> and
>> cheers
>> Vincent
>>> Hi,
>>> you know! :)
>>> problems. ;-)
>>> Vincent
>>>> understand more.
>>>> thx
>>>> Vincent
<aboutInfo>
<text>
</text>
</aboutInfo>
<launcherArgs>
</launcherArgs>
<splash
<solaris/>
<bmp
</win>
</launcher>
<vm>
</vm>
<plugins>
</plugins>
</product>
Re: STEM integration Mac [message #579248 is a reply to message #30455] Mon, 18 June 2007 14:15 Go to previous message
Vincent,
from France...
Dan
Re: STEM integration Mac [message #579301 is a reply to message #30629] Mon, 18 June 2007 23:19 Go to previous message
John
Re: STEM integration Mac [message #579322 is a reply to message #30699] Tue, 19 June 2007 15:21 Go to previous message
Dan
Re: STEM integration Mac [message #579451 is a reply to message #30735] Sat, 23 June 2007 08:56 Go to previous message
Hey Dan,
request.
org.eclipse.swt
Vincent
> Thanks
> Dan
Re: STEM integration Mac [message #579596 is a reply to message #30948] Tue, 10 July 2007 13:19 Go to previous message
Dan
> Hey Dan,
> request.
> org.eclipse.swt
> Vincent
> > Thanks
> > Dan
Previous Topic:Implementing OHF
Next Topic:Reference Sheet or User Guide?
Current Time: Fri Jul 25 21:27:14 EDT 2025
Powered by FUDForum. Page generated in 0.06117 seconds
