Home » Eclipse Projects » Eclipse Platform » How General Are Natures ?
How General Are Natures ? [message #306443] Fri, 28 July 2006 17:04 Go to next message
I am developing a plugin that depends on a small amount of persistent
data. I could persist it as a project resource, or as project metadata.
Initially I've chosen the metadata approach and implemented the data as
the X property on a project properties extension page.
A problem with this approach is that the X property appears on every
project, which is redundant. Most projects have no need for the X data.
Can I create and use an 'X' nature to limit presentation of the X
project property to projects that have the X nature?
The docs specify how to customize builds according to natures, but I
suspect/hope that natures are more general than that,
Bill
Re: How General Are Natures ? [message #306471 is a reply to message #306443] Mon, 31 July 2006 08:23 Go to previous messageGo to next message
yes, when you create your property page add a filter, like <filter
name="nature" value="org.eclipse.jdt.core.javanature"/>
Check out the extension point description, the IActionFilter interface,
and examples in the org.eclipse.jdt.ui plugin.
Later,
PW
Re: How General Are Natures ? [message #306807 is a reply to message #306471] Sat, 05 August 2006 15:45 Go to previous messageGo to next message
>> metadata. Initially I've chosen the metadata approach and implemented
>> the data as the X property on a project properties extension page.
> Later,
> PW
Paul, thanks - exactly the guidance I needed, Bill.
Re: How General Are Natures ? [message #307197 is a reply to message #306471] Tue, 15 August 2006 14:01 Go to previous message
Originally posted by: john.eclipsefaq.org
This will work, but if your only requirement is filtering of the
property view, then a nature seems like a bit of overkill. You can get
the same effect by adding a persistent property
(IResource.setPersistentProperty), and then use the
IResourceActionFilter.PERSISTENT_PROPERTY filter name.
> Later,
> PW
Previous Topic:Linked Resource Problem
Next Topic:Launching framework
Current Time: Sat Jul 19 16:41:28 EDT 2025
Powered by FUDForum. Page generated in 0.32390 seconds
