Home » Eclipse Projects » Eclipse Platform » Using a Viewer with multiple views (Providers)
Using a Viewer with multiple views (Providers) [message #306691] Thu, 03 August 2006 11:01 Go to next message
Originally posted by: dennis.rietmann.solnet.ch
I want to use a (eg. Tree-)Viewer in a way that one can switch from one
view to another and back (to display different data but still using
only 1 Viewer). A view consists of the data set with setInput(), a
specific ContentProvider and LabelProvider.
When I trigger the switch (via button) sth. like the following code will
get executed:
if (...) {
/* switch from view 1 to view 2 */
treeViewer.setContentProvider(cp2);
treeViewer.setInput(data2);
treeViewer.setLabelProvider(lp2);
else {
/* switch from view 2 to view 1 */
treeViewer.setContentProvider(cp1);
treeViewer.setInput(data1);
treeViewer.setLabelProvider(lp1);
After _each_ setX() method the treeViewer triggers a refresh and calls
the Providers and some Listeners (like SelectionChangedListener).
Therefore I had to add a lot of ugly checks to determine if everything
is in place, but also performance-wise I think this is far from optimal.
So, my question is: Is there a better way to do this or how would you
improve this? I would appreciate any advice.
Dennis
Re: Using a Viewer with multiple views (Providers) [message #306714 is a reply to message #306691] Thu, 03 August 2006 13:54 Go to previous messageGo to next message
Why not hiding and showing viewers instead of replacing content? I don't
think that there's a better way than you do it now.
Tom
Re: Using a Viewer with multiple views (Providers) [message #306735 is a reply to message #306714] Thu, 03 August 2006 18:10 Go to previous messageGo to next message
Hi Tom,
thanks for the hint, I'll probably use this and trigger a refresh after
switching.
Did you have something like the following in mind, or is there an easier
solution?
private void switchView() {
if (view == ...) {
treeViewer1.setVisible(false);
((GridData)treeViewer1.getLayoutData()).exclude = true;
treeViewer2.setVisible(true);
((GridData)treeViewer2.getLayoutData()).exclude = false;
treeViewer2.refresh();
view = ...
} else {
/* same stuff the other way around */
container.layout();
Dennis
> Tom
Re: Using a Viewer with multiple views (Providers) [message #306745 is a reply to message #306735] Fri, 04 August 2006 01:21 Go to previous message
Yes. Maybe I'd do the refresh before making the dialog visible, hide the
first one.
Tom
Dennis schrieb:
> Hi Tom,
> switching.
> solution?
> if (view == ...) {
> view = ...
> } else {
> container.layout();
> Dennis
>> Tom
Previous Topic:Re: Change TableViewer's Table at runtime
Next Topic:Trouble with branding launcher from PDE builder
Current Time: Sat Jul 19 04:00:57 EDT 2025
Powered by FUDForum. Page generated in 0.04179 seconds
