| Home » Archived » M2M (model-to-model transformation) » [ATL] multiple references to an unique target model element
 Goto Forum:|
| [ATL] multiple references to an unique target model element [message #2801] | Tue, 26 December 2006 09:08  |  |
| Eclipse User  |  |  |  |  | Originally posted by: fsr.cin.ufpe.br
 Is it possible to make multiple references to an unique target pattern
 element in an ATL matched rule?
 For instance, in the following rule, I'd like to have the a_3 target
 element as the respective 'att' elements contained as in the o_1 element
 as in the o_2 element. However, in the generated target model, only the
 o_2 element
 contains an appropriate reference to the a_3 element, that, in turn, is
 not contained it he o_1 element.
 rule C2C{
 from
 i: SM!ClassA
 to
 o_1 : TM!ClassB
 att <- a3;
 name <- 'o_1'),
 o_2 : TM!ClassB(
 att <- a3;
 name <- 'o_2')
 a_3 : TM!ClassC(
 value <- i.name)
 Thanks in advance,
 Franklin Ramalho.
| Re: [ATL] multiple references to an unique target model element [message #2904 is a reply to message #2801] | Wed, 27 December 2006 08:03   |  |
| Eclipse User  |  |  |  |  | Originally posted by: cb.infocity.de
 Hello Franklin,
 "Franklin Ramalho" <fsr@cin.ufpe.br> schrieb im Newsbeitrag
 news:5030f3a834822f0b0100059eddee86e7$1@www.eclipse.org...
 > Hello,
 I would say yes. But it depends on your metamodel.
 In ClassB you got some att attribute. Is this att some reference which can
 "save" ClassC ??
 Is this reference set to [0..*] ??
 Which means that att can save more than one reference of ClassC
 > o_2 element
 > rule C2C{
 >     from
 >       i: SM!ClassA
 >     to
 >       o_1 : TM!ClassB
 >           att <- a3;
 >           name <- 'o_1'),
 >       o_2 : TM!ClassB(
 >           att <- a3;
 >           name <- 'o_2')
 >       a_3 : TM!ClassC(
 >           value <- i.name)
 > Thanks in advance,
 > Franklin Ramalho.
 Camil
| Re: [ATL] multiple references to an unique target model element [message #3065 is a reply to message #2904] | Thu, 28 December 2006 13:41   |  |
 Hello Camil,
 I only would like to generate 3 objects: o_1, o_2 and o_3, where the two
 formers have a reference to the latter (att <- a3). However, this does not
 work: only o_2 objects has been generated appropriately with
 the correct reference to a3. The o_2 object is generated without such
 reference.
 However, if I do something like the rule below, both objects are generated
 with a reference to the ClassC, but for this, as you can see in the rule,
 I need to make use of two different instances of the ClassC meta-element.
 //works
 rule C2C{
 from
 i: SM!ClassA
 to
 o1 : TM!ClassB
 att <- a3;
 name <- 'o_1'),
 o2 : TM!ClassB(
 att <- a4;
 name <- 'o_2')
 a3 : TM!ClassC(
 value <- i.name),
 a4 : TM!ClassC(
 value <- i.name)
 // does not work
 rule C2C{
 from
 i: SM!ClassA
 to
 o1 : TM!ClassB
 att <- a3;
 name <- 'o_1'),
 o2 : TM!ClassB(
 att <- a4;
 name <- 'o_2')
 a3 : TM!ClassC(
 value <- i.name)
 If anybody can help, I'd be grateful!:)
 Franklin.
| Re: [ATL] multiple references to an unique target model element [message #4224 is a reply to message #3065] | Thu, 28 December 2006 19:25   |  |
 Hello Franklin,
 news:b56e753dc7ddce2eb982c3d1aacefdc4$1@www.eclipse.org...
 > Hello Camil,
 > reference.
 > //works
 > rule C2C{
 >     from
 >       i: SM!ClassA
 >     to
 >       o1 : TM!ClassB
 >           att <- a3;
 >           name <- 'o_1'),
 >       o2 : TM!ClassB(
 >           att <- a4;
 >           name <- 'o_2'),
 >       a3 : TM!ClassC(
 >           value <- i.name),
 >       a4 : TM!ClassC(
 >           value <- i.name)
 for sure this works.:-)) because you have created two ClassC "Objects"
 (instances) and you also have two "references" to every of them.
 In java you would say:
 Object ref1 = new ClassC;
 Object ref2 = new ClassC;
 so now ref1 can save "obejcts" of type ClassC and ref2 also can save
 "objects" of type ClassC
 OK
 so what kind of "type" is 'att' able to save.?? if you say
 att <- a3;
 that means that att must be able to "store" objects of ClassC
 OK now what i mean is that att must be set as some reference which can
 And that you need to specify in your metamodel TM
 Imagine that a3 : TM!ClassC() is in some "other" rule. Then you need the
 resolveTemp() function if you want to say
 att <- a3;
 this will not work then. Because the a3: TM!ClassC() is "somewhere" you need
 to say ATL where he can find this "somewhere"
 so you need to say atl the reference. :-))
 hmmmm well have you copied this code out of your eclipse.??
 Becaue there is some ',' missing.
 But the atl-compiler must have seen this error also.??:-)) hmm
 I mean after your o2: TM!ClassB(att <- a4; name <- 'o_2')  there is no ','
 I have added it right now to your posting. So please checkt it ;-)
 Hmmmm well i guess att <- will get overwrite that's why you only can save
 one reference.
 maybe you can try something like that.
 o1: TM!ClassB(
 att <- a3;
 name <- 'blabla'),
 o2: TM!ClassB(
 att <- a3 -> including(o1.att);
 name <- 'blublub'),
 or try
 att <- a3 -> union(o1.att);
 But this only works if att can save "more" than one reference. And this you
 must set in your metamodel
 Thats what i think.;-))
 Maybe someone else.?;-)
 > // does not work
 > rule C2C{
 >     from
 >       i: SM!ClassA
 >     to
 >       o1 : TM!ClassB
 >           att <- a3;
 >           name <- 'o_1'),
 >       o2 : TM!ClassB(
 >           att <- a4;
 >           name <- 'o_2'),
 >       a3 : TM!ClassC(
 >           value <- i.name)
 > Regards,
 > Franklin.
 Camil
| Re: [ATL] multiple references to an unique target model element [message #4736 is a reply to message #4224] | Fri, 29 December 2006 09:34  |  |
 Hello Camil,
 Firstly, thanks for your effort in understanding my problem and helping
 me:)
 In fact there was an error as you said (missing a comma), but I was only
 trying to simplify my rule that is more complex than that I've posted
 here. So, the error is provenient from the adaptation done directly at the
 text editor:)
 Unfortunately, yours suggestions do not solve my problem because att is a
 mono-valued reference, i.e.,it cannot have  more than one reference.
 I just would like that the same target element (a3) could be used
 as reference value in two others different target elements (o1, o2), as
 shown below. However, as I said, only the last one (o2) is generated with
 the referred value (a3) as contained element (a3 is absent
 from the generated o1 element structure).
 rule C2C{
 from
 i: SM!ClassA
 to
 o1 : TM!ClassB
 att <- a3;
 name <- 'o_1'),
 o2 : TM!ClassB(
 att <- a3;
 name <- 'o_2'),
 a3 : TM!ClassC(
 value <- i.name)
 On the other hand, when I use two different target elements as reference
 value of att for o1 and o2, as shown in the rule below, these two objects
 are generated apropriately. Note that a3 and a4 have the same content
 (what takes me to try use only a single object a3 (as done in the above
 rule) instead of these two different objects.
 rule C2C{
 from
 i: SM!ClassA
 to
 o1 : TM!ClassB
 att <- a3;
 name <- 'o_1'),
 o2 : TM!ClassB(
 att <- a4;
 name <- 'o_2'),
 a3 : TM!ClassC(
 value <- i.name),
 a4 : TM!ClassC(
 value <- i.name)
 Franklin.
 Current Time: Fri Oct 31 05:16:31 EDT 2025
 Powered by FUDForum . Page generated in 0.06078 seconds |
