Home » Eclipse Projects » Eclipse Platform » "Eclipse Style" PerspectiveBar
"Eclipse Style" PerspectiveBar [message #306174] Mon, 24 July 2006 14:02 Go to next message
Originally posted by: mbo.shift-think.net
Hi all
I would like to add the "eclpse style" perspective bar to my rcp
application. I have successfully added the perspectivebar but it just
shows the normal (non-curved) style.
How is the curved style done.
and yes, this is already set:
PlatformUI.getPreferenceStore().setValue(IWorkbenchPreferenc eConstants.SHOW_TRADITIONAL_STYLE_TABS,
false);
Michael
Re: "Eclipse Style" PerspectiveBar [message #306190 is a reply to message #306174] Tue, 25 July 2006 02:48 Go to previous messageGo to next message
Michael Boeni wrote:
> Hi all
> false);
You should clear your run-time workspace of that very RCP. This setting
is only evaluated the first time and the result is persisted into the
workspace data.
Greetings from Bremen,
Daniel Krügler
Re: "Eclipse Style" PerspectiveBar [message #306221 is a reply to message #306190] Tue, 25 July 2006 14:07 Go to previous messageGo to next message
Hi Daniel
Ah, ok. How do I delete the run-time workspace?
Michael
>> Hi all
>> false);
> workspace data.
> Daniel Krügler
Re: "Eclipse Style" PerspectiveBar [message #306254 is a reply to message #306221] Wed, 26 July 2006 04:22 Go to previous messageGo to next message
> Hi Daniel
In the following I assume that the problem occurs in the RCP
app which has been started by your Eclipse launch configuration,
not your exported/deployed version, is that right?
1) Open Run configuration, tab "Main", ensure that "Clear workspace data
before launching" in the Workspace Data section is selected. Run again.
2) If (1) didn't help, you should use your usual file explorer and go
into the directory described by the launch config's entry "Location" in
the very same Workspace Data section and remove all of its contents
manually. Restart again.
Daniel
Re: "Eclipse Style" PerspectiveBar [message #306317 is a reply to message #306254] Wed, 26 July 2006 14:07 Go to previous messageGo to next message
Hi Daniel
Clearing the workspace works ok, but has no effect on the
perspectivebar. It is still not shown in the "curved" mode as in
eclipse. Is there anything else I have to do?
Cheers from Zürich :)
Michael
>> Hi Daniel
> Daniel
Re: "Eclipse Style" PerspectiveBar [message #306410 is a reply to message #306317] Fri, 28 July 2006 03:45 Go to previous messageGo to next message
The problem might be your chosen point in workbench lifecycle, where
you have written your
false);
To isolate this potential error source you should comment the above
expression in your code and should - at least for this test - add the line
org.eclipse.ui/SHOW_TRADITIONAL_STYLE_TABS=false
in your plugin-customization file. Therefore you have to ensure that
there exists the property:
<property
name="preferenceCustomization"
value="your_plugin_customization.ini"/>
in your current org.eclipse.core.runtime.products ext. pt. If not
existing you also have to create the file your_plugin_customization.ini
in the root of that branding plug-in.
Then repeat the clearage of your runtime workspace and restart: Do
you see the new perspective bar borders now?
Hope that helps,
Daniel
Re: "Eclipse Style" PerspectiveBar [message #306425 is a reply to message #306410] Fri, 28 July 2006 12:12 Go to previous messageGo to next message
Hi Daniel
I have the statement in the ApplicationWorkbenchWindowAdvisor in the
preWindowOpen mehtod, like follows:
public void preWindowOpen()
false);
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
configurer.setInitialSize(new Point(1024, 768));
configurer.setShowCoolBar(false);
configurer.setShowStatusLine(true);
configurer.setShowFastViewBars(true);
configurer.setShowPerspectiveBar(true);
configurer.setShowProgressIndicator(true);
configurer.setTitle("LexisNexis Datafeed");
Will try your tip with the custom file and will post again :)
michael
> false);
> <property
> Hope that helps,
> Daniel
Re: "Eclipse Style" PerspectiveBar [message #306436 is a reply to message #306425] Fri, 28 July 2006 13:33 Go to previous message
Hi Daniel
I tried the config file but to no avail. I tried this:
org.eclipse.ui/DOCK_PERSPECTIVE_BAR=topRight
org.eclipse.ui/SHOW_PROGRESS_ON_STARTUP=true
The VIEWS are correctly shown with the curved tabs, but the perspective
bar still does not...strange...
Michael
Michael Boeni schrieb:
> Hi Daniel
> false);
> michael
>> false);
>> <property
>> Hope that helps,
>> Daniel
Previous Topic:Persist Workbench state
Next Topic:BreakpointView always has Java Exception button
Current Time: Fri Jul 18 19:39:03 EDT 2025
Powered by FUDForum. Page generated in 0.03836 seconds
