Home » Eclipse Projects » Eclipse Platform » Why is saveState(IMemento) in IViewPart only called on shutdown?
Why is saveState(IMemento) in IViewPart only called on shutdown? [message #302181] Fri, 14 April 2006 11:47 Go to next message
Originally posted by: eclipse.bettsockentraeger.de
I created a view and saved its state in the saveState(IMemento) method
of IViewPart. The method is called upon workbench shutdown and
everything works beautifully but when I close the view manually the
method is not called and the state is not saved and can't be restored
upon startup or creation of the view.
SO how can I call the method on closeing of my view so that the state is
preserved?
Thanks for any help
Stefan
Re: Why is saveState(IMemento) in IViewPart only called on shutdown? [message #302193 is a reply to message #302181] Sat, 15 April 2006 15:01 Go to previous messageGo to next message
You need to wire it up yourself....we logged a bug report about this some
time ago...I forget the state of it.
See the Debug Display for an example within Eclipse.
Especially
org.eclipse.jdt.internal.debug.ui.display.DisplayView#perspe ctiveChanged
HTH
Darins
"Stefan Langer" <eclipse@bettsockentraeger.de> wrote in message
news:e1og2t$lig$1@utils.eclipse.org...
> Hello,
> I created a view and saved its state in the saveState(IMemento) method of
> IViewPart. The method is called upon workbench shutdown and everything
> works beautifully but when I close the view manually the method is not
> called and the state is not saved and can't be restored upon startup or
> preserved?
> Thanks for any help
> Regards
> Stefan
Re: Why is saveState(IMemento) in IViewPart only called on shutdown? [message #302215 is a reply to message #302181] Mon, 17 April 2006 08:35 Go to previous messageGo to next message
saveState(IMemento) is about saving view state across sessions. The
user shuts down eclipse, and the user expects to see his views when he
restarts eclipse. The workbench uses saveState(*)/restoreState(*) for that.
When a user closes a view, he deliberatly closed it. It's gone. When
the user shows the view again, it comes up in it's default state.
You have 2 options. Option 1 is to implement ISaveablePart, and when
the view is closed it will get its methods like isDirty() and doSave(*)
called. Of course if you mark your view as dirty, a little '*' appears
in the tab title in 3.2 :-)
Option 2 is to use DialogSettings to persist view information.
Save your view information in the plugin state location.
Later,
PW
Re: Why is saveState(IMemento) in IViewPart only called on shutdown? [message #306177 is a reply to message #302215] Mon, 24 July 2006 15:18 Go to previous messageGo to next message
How do I use DialogSettings to persist view Information? Any pointers is
much appreciated.
> that.
> Later,
> PW
Re: Why is saveState(IMemento) in IViewPart only called on shutdown? [message #306181 is a reply to message #306177] Mon, 24 July 2006 16:17 Go to previous messageGo to next message
You want to create your DialogSettings object, fill it with information,
and then save it ... there's a #save(Writer) method.
You can persist the DialogSettings file in your plugin state location
.... start from Plugin#getStateLocation().
Later,
PW
Re: Why is saveState(IMemento) in IViewPart only called on shutdown? [message #306184 is a reply to message #306181] Mon, 24 July 2006 17:43 Go to previous messageGo to next message
> Later,
> PW
Thanks Paul. I would like to store Objects vs. Strings or primitives.
Re: Why is saveState(IMemento) in IViewPart only called on shutdown? [message #306226 is a reply to message #306184] Tue, 25 July 2006 15:49 Go to previous messageGo to next message
You can do this.
Serialize your objects into file located in Plugin#getStateLocation().
Re: Why is saveState(IMemento) in IViewPart only called on shutdown? [message #306228 is a reply to message #306226] Tue, 25 July 2006 16:49 Go to previous message
> You can do this.
Do you have a sample for this.
Previous Topic:Arrange Items In an Import Wizard other than alphabetical
Next Topic:Eclipse 3.3?
Current Time: Wed Sep 17 11:03:31 EDT 2025
Powered by FUDForum. Page generated in 0.04211 seconds
