Home » Eclipse Projects » Eclipse Platform » [Targets]: No targets could be determined for the buildfile
[Targets]: No targets could be determined for the buildfile [message #306134] Fri, 21 July 2006 11:30 Go to next message
Originally posted by: fakeuser.poh.dynalias.org
I am getting the message
"[Targets]: No targets could be determined for the buildfile"
in the external tools dialog and can't pick targets to run.
This is for all targets that run off of a particular build file.
what causes this?
Re: [Targets]: No targets could be determined for the buildfile [message #306138 is a reply to message #306134] Fri, 21 July 2006 16:11 Go to previous messageGo to next message
Unsure...any indication in your error log file?
Which Eclipse?
what VM?
What Ant?
Darins
"Patrick Hart" <fakeuser@poh.dynalias.org> wrote in message
news:e9qrtm$gj9$1@utils.eclipse.org...
> what causes this?
Re: [Targets]: No targets could be determined for the buildfile [message #306163 is a reply to message #306138] Mon, 24 July 2006 08:54 Go to previous messageGo to next message
ant is apache ant version 1.6.5
this is from the error log.
eclipse.buildId=M20060629-1905
java.version=1.5.0_07
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file
C:\eclipse-workspace2\.metadata\.bak_0.log
Created Time: 2006-07-19 07:59:34.515
Error
Mon Jul 24 08:50:00 EDT 2006
Internal error occurred retrieving targets
java.lang.ClassCastException: org.apache.xerces.parsers.XML11Configuration
at org.apache.xerces.parsers.SAXParser.<init>(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.<init>(Unknown Source)
at org.apache.xerces.jaxp.SAXParserFactoryImpl.newSAXParser(Unk nown
Source)
at org.apache.tools.ant.util.JAXPUtils.newSAXParser(JAXPUtils.j ava:205)
at
org.apache.tools.ant.util.JAXPUtils.getNamespaceXMLReader(JA XPUtils.java:163)
at
org.apache.tools.ant.helper.ProjectHelper2.parse(ProjectHelp er2.java:193)
at
org.eclipse.ant.internal.ui.editor.utils.ProjectHelper.parse (ProjectHelper.java:526)
at
org.eclipse.ant.internal.ui.editor.utils.ProjectHelper.parse (ProjectHelper.java:631)
at org.apache.tools.ant.taskdefs.ImportTask.execute(ImportTask. java:140)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
at
org.eclipse.ant.internal.ui.model.AntImportNode.configure(An tImportNode.java:70)
at
org.eclipse.ant.internal.ui.model.AntModel.resolveBuildfile( AntModel.java:501)
at
org.eclipse.ant.internal.ui.model.AntModel.parseDocument(Ant Model.java:326)
at
org.eclipse.ant.internal.ui.model.AntModel.reconcile(AntMode l.java:263)
at
org.eclipse.ant.internal.ui.model.AntModel.getProjectNode(An tModel.java:1383)
at
org.eclipse.ant.internal.ui.model.AntModel.getProjectNode(An tModel.java:1393)
at org.eclipse.ant.internal.ui.AntUtil.getTargets(AntUtil.java: 236)
at
org.eclipse.ant.internal.ui.launchConfigurations.AntTargetsT ab$7.run(AntTargetsTab.java:493)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:763)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:760)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2283)
at
org.eclipse.ui.internal.progress.ProgressManager$5.run(Progr essManager.java:1130)
at
org.eclipse.ui.internal.progress.ProgressManager.runInUI(Pro gressManager.java:1126)
at
org.eclipse.ant.internal.ui.launchConfigurations.AntTargetsT ab.getTargets(AntTargetsTab.java:510)
at
org.eclipse.ant.internal.ui.launchConfigurations.AntTargetsT ab.initializeFrom(AntTargetsTab.java:619)
at
org.eclipse.debug.ui.AbstractLaunchConfigurationTabGroup.ini tializeFrom(AbstractLaunchConfigurationTabGroup.java:86)
at
org.eclipse.ant.internal.ui.launchConfigurations.AntTabGroup .initializeFrom(AntTabGroup.java:46)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.displayInstanceTabs(LaunchConfigura tionTabGroupViewer.java:655)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer$6.run(LaunchConfigurationTabGroupVi ewer.java:548)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.inputChanged(LaunchConfigurationTab GroupViewer.java:565)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.setInput(LaunchConfigurationTabGrou pViewer.java:529)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleLaunchConfigurationSelectionChanged( LaunchConfigurationsDialog.java:928)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$4.selectionChanged(LaunchConfigurationsDia log.java:547)
at
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:839)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
at
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:837)
at
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1578)
at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:38 4)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.doInitialTreeSelection(LaunchConfiguration sDialog.java:587)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.initializeContent(LaunchConfigurationsDial og.java:1034)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.createContents(LaunchConfigurationsDialog. java:434)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1124)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.create(LaunchConfigurationsDialog.java:363 )
at org.eclipse.jface.window.Window.open(Window.java:785)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:1086)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:37 5)
at
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:379)
at
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:321)
at
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
> Which Eclipse?
> what VM?
> What Ant?
> Thanks
> Darins
>> what causes this?
Re: [Targets]: No targets could be determined for the buildfile [message #306168 is a reply to message #306163] Mon, 24 July 2006 10:04 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=143008
See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=143008#c6
for possible workarounds
HTH
Darins
news:ea2ft2$tss$1@utils.eclipse.org...
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Error
> Source)
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.ant.internal.ui.model.AntModel.reconcile(AntMode l.java:263)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Which Eclipse?
>> what VM?
>> What Ant?
>> Thanks
>> Darins
>>> what causes this?
Re: [Targets]: No targets could be determined for the buildfile [message #306171 is a reply to message #306168] Mon, 24 July 2006 11:40 Go to previous message
> See
> HTH
> Darins
>> Error
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> Which Eclipse?
>>> what VM?
>>> What Ant?
>>> Thanks
>>> Darins
>>>> what causes this?
Previous Topic:How do I get the Source (and Javadoc) for SWT in Callisto
Next Topic:How can I build eclipse R3_2 Platform on Windows(please help me!)
Current Time: Thu Oct 16 01:48:28 EDT 2025
Powered by FUDForum. Page generated in 0.20701 seconds
