Home » Eclipse Projects » Eclipse Platform » Eclipse forms question: How do I swap in/out a Section or a SectionPart
Eclipse forms question: How do I swap in/out a Section or a SectionPart [message #305924] Mon, 17 July 2006 00:35 Go to next message
I have a form editor. Depending on the user's choice, I can swap out a
Section and swap in another Section to take place of the swapped out
Section.
I can't seem to make that work...I use
IManagedForm.addPart()/removePart(). But, that does not work.
I have noticed that creating a SectionPart will immediately put in my
form, one after another.
Please advise.
Re: Eclipse forms question: How do I swap in/out a Section or a SectionPart [message #305987 is a reply to message #305924] Mon, 17 July 2006 10:46 Go to previous messageGo to next message
Have you tried to call some layout method to revalidate those sections'
parent?
Sunny Sun
"AL" <unbonnevie@yahoo.com> ??????:e9f42k$r7p$1@utils.eclipse.org...
> Section.
> Please advise.
> Thanks
Re: Eclipse forms question: How do I swap in/out a Section or a SectionPart [message #305990 is a reply to message #305924] Mon, 17 July 2006 11:11 Go to previous messageGo to next message
Try doing a reflow();
Re: Eclipse forms question: How do I swap in/out a Section or a SectionPart [message #305997 is a reply to message #305990] Mon, 17 July 2006 12:55 Go to previous messageGo to next message
I did the above after doing IManagedForm.removePart(myPart). Still does
not work. :-(
Re: Eclipse forms question: How do I swap in/out a Section or a SectionPart [message #306003 is a reply to message #305987] Mon, 17 July 2006 17:33 Go to previous messageGo to next message
> parent?
> Sunny Sun
>>Hi,
>>Section.
>>Please advise.
>>Thanks
I also tried section.getParent().redraw()...No help. Any more idea?
Thanks.
Re: Eclipse forms question: How do I swap in/out a Section or a SectionPart [message #306004 is a reply to message #305997] Mon, 17 July 2006 18:34 Go to previous messageGo to next message
> not work. :-(
Ok, the swapped out Section MUST be disposed as well to get the things
work correctly...Urggg....Took me a lot of time to find out, unfortunately.
Re: Eclipse forms question: How do I swap in/out a Section or a SectionPart [message #306175 is a reply to message #306004] Mon, 24 July 2006 14:45 Go to previous messageGo to next message
Originally posted by: denpark.cisco.com
An alternative solution would be to set the form's content onto a set of
composites,..these composites can then be hosted on a CTabFolder, and
CTabItems... then based on some selection condition, you can swap using a
stacklayout.
"AL" <unbonnevie@yahoo.com> wrote in message
news:e9h38p$12n$1@utils.eclipse.org...
>> not work. :-(
> unfortunately.
Re: Eclipse forms question: How do I swap in/out a Section or a SectionPart [message #536395 is a reply to message #306175] Thu, 27 May 2010 21:24 Go to previous message
If because of some reason, you can't use the CTabFolder or ScrolledPageBook, than another alternative solution can be search for the Composite in which the section have formpart's and manually dispose all the controls there like
//Get all the controls in the section
// It will be usually 3
Control[] children = getSection().getChildren();
for (Control child:children)
// One child control will be composite in which all the formpart components are present.
if (child instanceof Composite) {
Control[] subChildren = ((Composite)child).getChildren();
for (Control subChild:subChildren)
// dispose all the component.
subChild.dispose();
This approach is definitely very raw, and not suggested and should be used only if you don't have any other work around.
Previous Topic:info ...
Next Topic:attach eclipse source
Current Time: Sun Jul 27 12:53:22 EDT 2025
Powered by FUDForum. Page generated in 0.04492 seconds
