Home » Eclipse Projects » Technology Project and PMC » SWT Image ... Speed
SWT Image ... Speed [message #30103] |
Sun, 06 October 2002 21:43  |
I have been doing a lot of work lately with the Eclipse workbench and
modifications to it, and a lot of work with SWT.
One major problem I have noticed with SWT is the Image class. Doing a
image read (1600x1200 JPEG) from the file system takes:
500ms in C++/Intel JPEG Graphics Lib
~1200ms in C# with .NET classes
~2000ms in Java using BufferedImageReader
~4000ms in SWT using the Image class and filename name constuctor
There seems to be no way to convert the standard Java Images to SWT images
so I am stuck with the bad performance of swt.Image. Is there anyway to
speed this up? One of the features with the Intel Graphics lib is that you
can (in simple terms) read the image size before loading the image fully
and decide if you wish to only read every 2nd, 4th, 8th, 16th pixel from
the file (which is a great feature when you are generating Thumbnails from
large images.
Is there someone out there on the SWT team that can help with any of this?
(I am prepared to get involved with this myself as well)
Re: SWT Image ... Speed [message #30173 is a reply to message #30103] |
Mon, 07 October 2002 09:27   |
Here's what I'm using for AWT -> SWT image conversion. Seems to work quite
well w/o the JPEG intermediary. (I used to do the JPEG path as well...).
Note that the error processing needs work -- this is still a rough version
so I could get the "real stuff" in my GUI builder to work...
I haven't done any timings (ironically, I don't have time to time it ;) If
you time this let me know how it does...
java.awt.Image awtImage = ...;
int[] pixels = new int[c.getWidth() * c.getHeight()];
PixelGrabber pg = new PixelGrabber(awtImage, 0, 0, c.getWidth(),
c.getHeight(), pixels, 0, c.getWidth());
try {
pg.grabPixels();
catch (InterruptedException e) {
System.err.println("interrupted waiting for pixels!");
return;
if ((pg.getStatus() & ImageObserver.ABORT) != 0) {
System.err.println("image fetch aborted or errored");
return;
ImageData dest = new ImageData(c.getWidth(), c.getHeight(), 32, new
PaletteData(0xFF0000,0xFF00,0xFF));
byte[] data = dest.data;
for (int i = 0, index = 0; i < c.getWidth() * c.getHeight(); i++, index+=4)
int pixel = pixels[i];
data[index] = (byte)((pixel >> 24) & 0xFF);
data[index + 1] = (byte)((pixel >> 16) & 0xFF);
data[index + 2] = (byte)((pixel >> 8) & 0xFF);
data[index + 3] = (byte)(pixel & 0xFF);
Image swtImage = new Image(null, dest);
-- Scott
Scott Stanchfield scott@javadude.com http://javadude.com
Lead author of "Effective VisualAge for Java, Version 3"
http://javadude.com/evaj
VisualAge for Java Tips and Tricks http://javadude.com/vaj
Visit for Java Enlightenment! http://www.jguru.com
"Justin Kilimnik" <justink@au.ibm.com> wrote in message
news:anqore$vbb$1@rogue.oti.com...
> large images.
Re: SWT Image ... Speed [message #30562 is a reply to message #30173] |
Mon, 07 October 2002 19:18  |
Thanks Scott,
I will test this out as soon as possible. With all the Java2D libs out
there it seems like we need some sort of bridge in this area....
Justin
> try {
> pg.grabPixels();
> return;
> return;
> -- Scott
> > large images.
Re: SWT Image ... Speed [message #584205 is a reply to message #30103] |
try {
pg.grabPixels();
return;
return;
-- Scott
> large images.
Re: SWT Image ... Speed [message #584378 is a reply to message #30173] |
Thanks Scott,
Justin
> try {
> pg.grabPixels();
> return;
> return;
> -- Scott
> > large images.
Current Time: Sat Jul 19 01:33:22 EDT 2025
Powered by FUDForum. Page generated in 0.04337 seconds
