Home » Eclipse Projects » Eclipse Platform » start a plugin programatically
start a plugin programatically [message #305595] Thu, 06 July 2006 10:47 Go to next message
Anyone know how I can load a plugin programatically from another plugin?
Re: start a plugin programatically [message #305597 is a reply to message #305595] Thu, 06 July 2006 11:08 Go to previous messageGo to next message
Originally posted by: eclipse.bettsockentraeger.de
Platform.getBundle("some id").start();
Where some id is the id of the plugin you want to activate.
If you have Eclipse-LazyStart: true it is enough to call a method on the
plugin to get it to start.
Re: start a plugin programatically [message #305600 is a reply to message #305597] Thu, 06 July 2006 11:35 Go to previous messageGo to next message
However there is a problem when using .start(). As I understand it, by
default, if you use bundle.start(), it records this fact and it will
force an automatic start of the bundle immediately on the next restart
of Eclipse, even if not needed. So you should be very careful about
doing this.
The best way is to use Eclipse-LazyStart and just executing a method on
a class from that bundle. That will start the bundle but it won't force
it to be started on the next restart of Eclipse.
Rich Kulp
Re: start a plugin programatically [message #305604 is a reply to message #305600] Thu, 06 July 2006 12:36 Go to previous messageGo to next message
Is Eclipse-LazyStart available before 3.2?
> doing this.
>> the plugin to get it to start.
Re: start a plugin programatically [message #305605 is a reply to message #305604] Thu, 06 July 2006 12:41 Go to previous messageGo to next message
I think it was called Eclipse-AutoStart in 3.1.
>> by default, if you use bundle.start(), it records this fact and it
>> will force an automatic start of the bundle immediately on the next
>> restart of Eclipse, even if not needed. So you should be very careful
>> about doing this.
>> on a class from that bundle. That will start the bundle but it won't
>> force it to be started on the next restart of Eclipse.
>>>> plugin?
Re: start a plugin programatically [message #305610 is a reply to message #305605] Thu, 06 July 2006 14:00 Go to previous message
Works as advertised - thanks to all those who replied.
>>> about doing this.
>>>>> plugin?
Previous Topic:Graphic errors in editor
Next Topic:Contributing an action to the menu
Current Time: Sat Nov 08 11:58:09 EST 2025
Powered by FUDForum. Page generated in 0.03799 seconds
