Home » Archived » DSDP - Mobile Tools for Java (MTJ) » An Error during importing nokia sdk into MTJþ
An Error during importing nokia sdk into MTJþ [message #29591] Thu, 21 May 2009 05:38 Go to next message
I have installed eclipse 3.4.1 and mtj. And I installed the
S60_3rd_MIDP_SDK_FP1 of nokia. But when i import device from
'S60_3rd_MIDP_SDK_FP1' , there is exception below.
java.lang.NullPointerException'
So can MTJ integrate with 'S60_3rd_MIDP_SDK_FP1' ,or not?
Please help me to solve this problem.
Re: An Error during importing nokia sdk into MTJþ [message #29611 is a reply to message #29591] Thu, 21 May 2009 09:24 Go to previous messageGo to next message
hi,
which mtj version are you using? are you using windows xp?
gep
Re: An Error during importing nokia sdk into MTJþ [message #30036 is a reply to message #29591] Fri, 22 May 2009 06:28 Go to previous messageGo to next message
I'm also having trouble, leading me to the same question: does MTJ support
the Nokia S60 SDK?
When I installed MTJ from the update site
(http://download.eclipse.org/dsdp/mtj/updates/1.0/stable/) into my eclipse
3.4.1 installation, Pulsar wouldn't install saying it couldn't work out
the dependencies right. But it did install "Mobile Tools for Java".
Then when I try to import the Nokia SDK, it simply thinks there is none
there in the folder where the SDK is installed (I also tried parent and
child directories).
If anyone has gotten this working, can they described the exact versions
of everything they tried?
Re: An Error during importing nokia sdk into MTJþ [message #30491 is a reply to message #30036] Tue, 26 May 2009 07:29 Go to previous messageGo to next message
i did some tests and you guys are right. MTJ cannot import
nS60_jme_sdk_3rd_e / nS60_jme_sdk_3rd_e_FP1.
i was able to use S60_5th_Edition_SDK_v1.0, but i still need to do more
tests (we usually use nokia serie40 sdks during our tests).
gep
Re: An Error during importing nokia sdk into MTJþ [message #30560 is a reply to message #30036] Wed, 27 May 2009 17:41 Go to previous messageGo to next message
I tried the same thing with Eclipse 3.4.2 + MTJ 1.0 RC2. (Nokia S60 3rd
SDK FP1). I don't think it is possible at the moment to work with a
Nokia SDK.
> support the Nokia S60 SDK?
> eclipse 3.4.1 installation, Pulsar wouldn't install saying it couldn't
> work out the dependencies right. But it did install "Mobile Tools for
> Java".
> child directories).
Re: An Error during importing nokia sdk into MTJþ [message #30595 is a reply to message #30560] Thu, 28 May 2009 04:34 Go to previous message
Originally posted by: gercan.NO_SPAM_acm.org
The statement that "it is not possible to work with a Nokia SDK" is not
true. It is only the S60 3rd Ed. FP1 SDK that has a problem. Later S60
SDKs (S60 3.2, S60 5.0 and the late N97 SDK) have no problems.
I have opened a bug report[1] regarding this problem. I also have a
solution proposal please comment/vote on this bug if it is important to you.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=278171
Gorkem
> Nokia SDK.
>> Java".
>> none there in the folder where the SDK is installed (I also tried
>> parent and child directories).
>> versions of everything they tried?
Re: An Error during importing nokia sdk into MTJþ [message #572902 is a reply to message #29591] Thu, 21 May 2009 09:24 Go to previous message
hi,
gep
Re: An Error during importing nokia sdk into MTJþ [message #572929 is a reply to message #29591] Fri, 22 May 2009 06:28 Go to previous message
the Nokia S60 SDK?
child directories).
Re: An Error during importing nokia sdk into MTJþ [message #573417 is a reply to message #30036] Tue, 26 May 2009 07:29 Go to previous message
gep
Re: An Error during importing nokia sdk into MTJþ [message #573498 is a reply to message #30036] Wed, 27 May 2009 17:41 Go to previous message
Nokia SDK.
> Java".
> child directories).
Re: An Error during importing nokia sdk into MTJþ [message #573533 is a reply to message #30560] Thu, 28 May 2009 04:34 Go to previous message
Gorkem
> Nokia SDK.
>> Java".
Previous Topic:Mobile Tools for Java 1.0RC2 is now available
Next Topic:hover issue with MTJ
Current Time: Sun Jul 27 13:02:48 EDT 2025
Powered by FUDForum. Page generated in 0.06784 seconds
