Home » Modeling » M2T (model-to-text transformation) » Aggregate Concat with a jet function
Aggregate Concat with a jet function [message #30415] Wed, 08 August 2007 07:42 Go to next message
Originally posted by: evaandoli.dodo.com.au
Im looking at doing a aggregate concat with the new value passed to a jet
function first.
Now for some reason I thought you might not understand what I meant by that
so here is an example :-)
<c:setVariable var="csvImportList"
select=" '{$csvImportList},'surroundInDoubleQuotes('{$tempCompoundNod e/@leftOperand}.csv') "/>
all is ok if I take out the function and just have one set of '
select="'{$csvImportList},{$tempCompoundNode/@leftOperand}.csv' "/>
I dont want to have to write another jet function just for this :-)
Any clues,
Stu
Re: Aggregate Concat with a jet function [message #30557 is a reply to message #30415] Wed, 08 August 2007 11:50 Go to previous message
Stu:
The following should work:
<c:setVariable var="csvImportList" select="concat($csvImportList, ',' ,
surroundInDoubleQuotes($tempCompoundNode/@leftOperand), '.csv')" />
In general, I think you should be suspicious of embedding dynamic XPath
expressions (Xpath expressions in {...}) within an XPath expression - these
may always be rewritten with them.
Paul
"Stu" <evaandoli@dodo.com.au> wrote in message
news:f9ca70$uf8$1@build.eclipse.org...
> function first.
> that so here is an example :-)
> Any clues,
> Stu
Previous Topic:Getting Double Quotes in a string
Next Topic:[JET] How modular should JET be?
Current Time: Thu Jul 24 22:44:19 EDT 2025
Powered by FUDForum. Page generated in 0.04610 seconds
