Home » Eclipse Projects » Eclipse Platform » TextViewer and positioning it in the dialog
TextViewer and positioning it in the dialog [message #304617] Mon, 12 June 2006 18:44 Go to next message
I'm trying to set the position of TextViewer in the dialog
which has a GridLayout set.
protected Control createDialogArea(Composite parent)
Composite composite = new Composite(parent, SWT.NONE);
GridLayout layout = new GridLayout(1, false);
composite.setLayout(layout);
Label codeLabel = new Label(composite, SWT.NONE);
codeLabel.setText("&Label:");
codeLabel.setLayoutData(new GridData(GridData.BEGINNING,
GridData.BEGINNING, false, false));
codeTextViewer = new TextViewer(getShell(), SWT.MULTI);
codeTextViewer.getControl().setLayoutData(new GridData(450, 100));
codeTextViewer.setInput(new Document());
I also have this method:
protected void createButtonsForButtonBar(Composite parent)
createButton(parent, IDialogConstants.OK_ID,
IDialogConstants.OK_LABEL, true);
createButton(parent, IDialogConstants.CANCEL_ID,
IDialogConstants.CANCEL_LABEL, false);
The trouble is that TextViewer is always set on the bottom end of the
dialog - under the OK, CANCEL buttons! Label 'codeLabel' sits over
the buttons...
I've tried to move the code of the TextViewer around the
createDialogArea method but it had no effect.
It has expected dimensions, but the position is wrong.
Thanks for your replies.
Piotr Gorny
Re: TextViewer and positioning it in the dialog [message #304629 is a reply to message #304617] Tue, 13 June 2006 03:35 Go to previous messageGo to next message
Piotr Gorny schrieb:
codeTextViewer = new TextViewer(composite, SWT.MULTI);
Tom
Re: TextViewer and positioning it in the dialog [message #304630 is a reply to message #304629] Tue, 13 June 2006 04:22 Go to previous messageGo to next message
>> Hi,
> Tom
Hello again Tom :-)
I'm afraid I've tried this solution earlier.
That's not the clue. I've left the composite and set getShell()
because the first one didn't work.
Piotr Gorny
Re: TextViewer and positioning it in the dialog [message #304633 is a reply to message #304630] Tue, 13 June 2006 06:37 Go to previous messageGo to next message
>>> Hi,
>> Tom
> Hello again Tom :-)
> Piotr Gorny
This code works perfectly for me on Eclipse-3.2 RC6.
---------------8<---------------
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
Dialog dia = new Dialog(shell) {
protected Control createDialogArea(Composite parent) {
Composite composite = (Composite)super.createDialogArea(parent);
GridData(GridData.BEGINNING,GridData.BEGINNING, false, false));
TextViewer codeTextViewer = new TextViewer(composite, SWT.MULTI);
return composite;
dia.open();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: TextViewer and positioning it in the dialog [message #304634 is a reply to message #304633] Tue, 13 June 2006 06:50 Go to previous messageGo to next message
And also on 3.1.0.
Re: TextViewer and positioning it in the dialog [message #304635 is a reply to message #304633] Tue, 13 June 2006 06:52 Go to previous messageGo to next message
thanks to your snippet I've found the reason:
I had:
//Composite composite = new Composite(parent, SWT.NONE);
...but should have:
Composite composite = (Composite) super.createDialogArea(parent);
Unfortunately i don't understand why should I use the latter version :-(
Re: TextViewer and positioning it in the dialog [message #304638 is a reply to message #304635] Tue, 13 June 2006 07:03 Go to previous message
> I had:
> ..but should have:
Well if I replace the super call with the lines below i get the same
result as I got when calling super.
Composite composite = new Composite(parent,SWT.NONE);
composite.setLayout(new GridLayout(1,false));
Tom
Previous Topic:Blank table item on virtual table with DeferredContentProvider
Next Topic:Setting baseTOCS doesn't change TOC order
Current Time: Wed Nov 05 15:10:31 EST 2025
Powered by FUDForum. Page generated in 0.24971 seconds
