Home » Eclipse Projects » Eclipse Platform » How to call forward / back manually?
How to call forward / back manually? [message #303402] Mon, 15 May 2006 08:01 Go to next message
How can I call forward and back actions manually from code? I want to
create my own buttons for those actions into a view and all I want is to
forward the action handling to the eclipse platform. I just can't seem
to find proper places in API to do this.
Thanks.
-Pasi
Re: How to call forward / back manually? [message #303413 is a reply to message #303402] Mon, 15 May 2006 09:28 Go to previous messageGo to next message
It's good if you can find the commands for these actions, usually by
command ID.
In 3.2:
ICommandService service=getSite().getService(ICommandService.class);
Command cmd = service.getCommand(FORWARD_ID).
if (cmd.isDefined()) {
cmd.executeWithChecks(new ExecutionEvent());
In 3.1.2, you can get the ICommandService from IWorkbench, either
getService() or getAdapter().
As for finding the ID, you can search through the Plug-in Registry view
or import binary plugins with linked content and search through the
plugin.xml yourself. The extension is org.eclipse.ui.commands
Later,
PW
Re: How to call forward / back manually? [message #303463 is a reply to message #303413] Tue, 16 May 2006 04:28 Go to previous messageGo to next message
Thanks Paul.
I got it working using "org.eclipse.ui.navigate.backwardHistory" as back
and "org.eclipse.ui.navigate.forwardHistory" as forward. But I wasn't
able to find any constants for those.
> command ID.
> In 3.2:
> Later,
> PW
Re: How to call forward / back manually? [message #303473 is a reply to message #303463] Tue, 16 May 2006 07:12 Go to previous message
Pasi Lehtimaki wrote:
> Thanks Paul.
That's OK, often there are no constants for actions that weren't
specifically designed to be used by client code.
Later,
PW
Previous Topic:Classpath: JUnit tests in Plugins
Next Topic:Frame Embedded using SWT_AWT
Current Time: Mon Jun 09 03:33:54 EDT 2025
Powered by FUDForum. Page generated in 0.24374 seconds
